01-29-2025, 06:52 PM | #1 |
Rep 26
HPFP - 2 bars over - Thoughts anyone? Is this normal?
So I have been struggling to figure out why my long term fuel trims(LTFT) have been sustained at 30% more fuel. It turns out my hpfp is pushing 2 bars higher pressure across the rev range.
My question is this. As anyone else had an issues with the hpfp over pressurizing, or over fueling. The car is a N55 M135i 2014 with 127k km on the clock. Is the hpfp on its way out? Should I be changing it? I mean, don't we want the higher pressure, especially seeing that I have a map on the car (bootmod3). I just changed the injector profile to Nostrum stage 2 to compensate for the higher fuel input, and everything is working out well at the moment. Just not sure if I should keep it this way, or get the fuel pump changed. I mean is this a good thing or not? lol Datalogs for confirmation https://www.bootmod3.net/log?id=665b...62d16a7f179256 https://www.bootmod3.net/log?id=665b...62d16a7f179257 https://www.bootmod3.net/log?id=665b...62d16a7f179258 Last edited by shervi; 01-30-2025 at 08:44 PM.. Reason: Added Datalogs |
01-31-2025, 03:47 PM | #3 | |
@lbb_kev
552
Rep 602
If the Nostrum Stage 2 config (highly recommend not running this config without the injectors btw) is helping then maybe you have some leaky injectors.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
01-31-2025, 06:43 PM | #4 |
![]() 1442
Rep 3,697
Uhm..
If you don't have the nostrum injectors.. change it the fuck back 😆 🤣 Also, you have serious throttle closures. Take a log with the correct injectors setting and post it. What mods and what map are you using?
2017 m240i xDrive 10.40@132.87mph w/bm3
03-04-2025, 01:40 AM | #5 | |
Rep 26
This is with he car just idling. On the stock injector and stock hpfp profile. https://www.bootmod3.net/log?id=67c5...cad113a347dda7 Just a stage 2 bootmod3 map, decatted and an AFE momentum intake. If I put the old one back, which I have tried before the overfuelling goes down by 15% In the past we have put a new DME (old one was fried). Everything was working well until one day about a year later this thing popped up. The car has a new pre throttle map sensor Maf Sensor Fuel rail pressure sensor Pre and Post O2 sensor NEw Valve cover New coil and injectors ( spark plugs changed as well to 1 stop colder) Both vanos solenoids If I remove the oil cap the fuel trims go back to normal. So I just changed the pcv valve in case by some miracle it had broken down. Could anyone post there car at idle, so I can compare logs? I am really confused here. |
fuel dme, fuel trims, hpfp, ltft, m135i, n55, stft |
