BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Turbo Inlet Recommendations
      02-03-2025, 09:57 PM   #1
bzstxF30
bzstxF30's Avatar
Drives: 2013 335i F30
2013 F30 N55 and my turbo inlet is starting to fall apart on me. I’ve got 163,000 and what looks to be the stock plastic one so it’s lived it’s full life I think.
I’ve been looking for recommendations on an upgrade because if I’m going to spend $150 on the part, I’d rather get an aftermarket silicone or aluminum one for $200 and feel like I made an improvement while swapping it.
Based on what I’ve read, CTS seems like the one I want but they are on back order. I emailed them and they think end of February they’ll have them back.
MST is offered by KIES, but only version 2 which is implied not for stock turbos.
I’ve seen recommendations for BMS on this site and they are in stock. They have 2 options (aluminum or silicone), both a little more than CTS. Not sure which is better, the aluminum normally costs more but is on sale for about the same price. Somebody on here reviewed a silicone one last summer, but didn’t mention they have a metal one (or maybe I missed it.)
I also wanted to see if anybody had any other brands I’m missing or additional input.
I can wait for the CTS, but if one of the two BMS options is considered much better I might pull the trigger on it now.
Links:
BMS aluminum
https://burgertuning.com/collections...w-intake-inlet
BMS silicone
https://burgertuning.com/collections...235-335-435-m2
CTS, back order
https://www.ctsturbo.com/product/cts...bo-inlet-pipe/
      02-03-2025, 11:20 PM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
a plastic or silicone inlet pipe will mitigate heat-soak much better than aluminum, thus provide better performance, although i'm not sure how much better in "real world".
i'd get the BMS or Turner if silicone
FTP motorsport, MAD or a plethora of others are available in aluminum and they'll all work similarly.
      02-04-2025, 12:18 AM   #3
f30_335i_ca
f30_335i_ca's Avatar
Drives: 335i
1990 Mustang 5.0 su ...  [0.00]
2012 335i  [0.00]
2003 M3  [0.00]
Some in depth threads on this:
https://f30.bimmerpost.com/forums/sh....php?t=1765289
https://f30.bimmerpost.com/forums/sh....php?t=1656337
The stock inlet necks down quite a bit with its inlet seal, I have seen aftermarket ones do this as well which would seem to be a restiriction.
See this: https://f87.bimmerpost.com/forums/sh....php?t=2088620
Side note, the PCV hose becomes very brittle, so be careful when you replace the inlet pipe or be prepared with a new one.
      02-04-2025, 09:41 AM   #4
AmuroRay
AmuroRay's Avatar
3286
Drives: M235i
MST V2 or BMS silicone. The BMS is the biggest.
Mods: Yes.
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      02-04-2025, 10:57 AM   #5
Slumped335
Sergeant
Slumped335's Avatar
Drives: 2015 BMW 335ix
  [0.00]
+1 on BMS Silicone Inlet. I really like mine so far and it is one of the biggest on the market for inlet size.
Usually sleeping or Lurking around
MHD 2+ XHP 3 Mods: -FTP: Charge/Boost Pipe
-BMS: Intercooler(6.5")/Silicone Inlet
-CTS: Intake/Catless Downpipe
-TurboSmart: Dual Port VR9 BOV
      02-04-2025, 10:30 PM   #6
bzstxF30
bzstxF30's Avatar
Thanks for this, I think I saw the top link but not the bottom 2.
Replacing the PCV after my a valve cover job is when I first noticed how degraded my inlet pipe was. The screw stripped the threads on the inlet pipe on reinstall. I hope the pcv is new enough I don’t need another one, but I might grab a reserve just in case.
      02-04-2025, 10:31 PM   #7
bzstxF30
bzstxF30's Avatar
I’m leaning towards the BMS silicone after the confirmation here, appreciate everyone’s responses.
Not sure why BMS has an aluminum one that costs more, was that just their first version and this was the next? And that’s why they have them on sale now.
      02-04-2025, 11:50 PM   #8
bzstxF30
bzstxF30's Avatar
The turner one Aloha suggested is on sale for $160, is the BMS silicone $40 better?
https://www.turnermotorsport.com/p-6...tock-location/
      02-05-2025, 07:37 AM   #9
AmuroRay
AmuroRay's Avatar
3286
Drives: M235i
Yeah, that 2 pieces and no comment on if it's a larger than the stock diameter. If it's the same as stock, it's not even an upgrade. I would do BMS, it's the biggest inlet on the market.
Mods: Yes.
      02-05-2025, 07:41 AM   #10
alohasurftoad
the BMS is not $40 in performance better, however because it is one piece, full silicone and has the largest diameter inlet to the turbo, the BMS is the one to get.
i'm value driven as much as most of us are, but $40 is not that much more to put the best part on.
AmuroRay3286.00
      02-05-2025, 10:14 AM   #11
bzstxF30
bzstxF30's Avatar
That’s the kind of confidence I like to read. BMS silicone inlet is ordered and on its way.
Thanks y’all
      02-06-2025, 10:14 AM   #12
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Thanks y’all
Congrats
https://x-ph.com/sale/
Phone number 702-494-9435
      02-17-2025, 08:50 PM   #13
bzstxF30
bzstxF30's Avatar
Post install update:
Very happy with this product. Buy the BMS silicone inlet with confidence.
One thing I was worried about that ended up being a positive was the way the PCV connection is done. In the pictures online it’s not clear if it’s a plastic or metal insert, but I can confirm it’s metal and creates a really snug connection. Much better than oem plastic.
I also really appreciated that it came with all the hardware I needed, 3 hose clamps and a small screw for the pcv. One small thing the hardware baggy could’ve used was a 8mm(?) nut that attaches the inlet to the turbo, but mine was thankfully still in good shape to reuse so I didn’t need it.
      02-18-2025, 09:55 AM   #14
lllRazorlll
lllRazorlll's Avatar
55
Drives: 2014 435i
MST fits on stock turbo since I can vouch for it
      02-18-2025, 11:03 AM   #15
mike@x-ph.com
