09-22-2020, 02:19 PM | #3433 |
Rep 965
Drives: 2016 F36 435x MSport
Unfortunately not with the aem kit . That's probably where the more pricy kits like torqubyte shine.
I'll have to read up on mixtures. As i understand it, a bit more water will add cooling and less octane while the opposite is true if you add more meth |
09-22-2020, 02:34 PM | #3434 |
Rep 7,606
Correct, and less fueling with less meth, i just don't know if you can spray "too much" water.
09-22-2020, 03:03 PM | #3435 |
Rep 62
Anyone else raspberry pi WiFi agent stop connecting after ios14? It connects to WiFi but the app can’t find the agent. Works fine on laptop. I don’t think they added the code to allow access to local networks
09-22-2020, 04:59 PM | #3436 |
Rep 965
yep makes sense and I'm a complete ding dong I just realized I could effectively change the duty cycle I could just increase the max PSI for full flow since it's a progressive system. I had it set to 15 PSI but just changed it to 20 since technically the BM3 tune shouldn't really get near that . would be an interesting experiment to see how the timings look and the richness.
09-22-2020, 05:04 PM | #3437 | |
Rep 7,606
09-22-2020, 06:15 PM | #3438 | |
Rep 1,079
09-22-2020, 10:55 PM | #3439 |
Rep 7,606
It is too bad indeed you cant test. There was one guy on here who switched from BM3 to MHD and was happy he did... forgot who it was tho would have to check my PMs.
thatBimmerBloke872.50 |
09-22-2020, 11:01 PM | #3440 | |
Rep 1,079
https://www.bootmod3.net/log?id=5f6a...90c60f5fef7a9c |
09-22-2020, 11:06 PM | #3441 | |
Rep 7,606
Your timing looks great there though. |
09-23-2020, 03:24 PM | #3442 | |
Instagram: @bmwdriven_
51
Rep 119
He said, "All cars experience some knock from time to time. It may just be that the fuel ratio is just a little bit off to one way or the other. The timing variance is actually not a whole lot. It's within a couple of degrees which is well within the DME control range". |
09-23-2020, 05:01 PM | #3443 | ||
Rep 1,079
09-26-2020, 08:31 AM | #3444 |
Rep 965
Finally got to do a few runs with reduced duty cycle on the WMI. Basically set "full" to 30psi which should theoretically give me about 50% DC .
Timing doesn't look as "great" as the last few logs. but i can see the STFT is a bit more relaxed than pegged full rich on the earlier logs: Earlier Logs (Full WMI): https://www.bootmod3.net/log?id=5f67...90c6479ba8739a https://www.bootmod3.net/log?id=5f67...0b4333bb1a495a Estimated 50% DC: https://www.bootmod3.net/log?id=5f6f...0b430910877730 https://www.bootmod3.net/log?id=5f6f...90c62fc576e336 https://www.bootmod3.net/log?id=5f6f...0b43091087773c
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
09-26-2020, 02:19 PM | #3445 |
Rep 965
So here is how crappy the 93 octane is around me i guess:
AEM controller set to "full blast" at 35 PSI (progressive, base at 7psi) https://www.bootmod3.net/log?id=5f6f...90c63fc775ee75 30PSI https://www.bootmod3.net/log?id=5f6f...0b4374521e756a 25PSI https://www.bootmod3.net/log?id=5f6f...729b1c3b23d508 20PSI (finally timing smooths out at the top end ...) https://www.bootmod3.net/log?id=5f6f...0b4374d8e63d70
09-28-2020, 11:26 AM | #3446 | |
Rep 643
another variable you could adjust is %meth so you could still spray at 100% duty cycle. you could potentially cut the boost juice with distilled water to reduce meth content. just don't over do it since cooler temps are coming and could potentially freeze your lines. and lastly, you could go with the smaller nozzle and keep your meth%.
M235i rwd 6mt
09-28-2020, 02:10 PM | #3447 | |
Rep 7,606
09-28-2020, 08:55 PM | #3448 | ||
Rep 965
Might have to just roll with this as I dont want to worry about mixing. Rather keep it as simple as i can with the boost juice. Quote:
10-05-2020, 11:17 PM | #3449 |
Rep 479
2014 335i Xdrive Stock Tune 59k miles
VRSF 5inch HD intercooler VRSF Charge Pipe OEM Plugs/Coils gapped to .030 with 5k miles on them AFE Pro dry drop in air filter Running 4 Gallons of 93oct gas and 2 Gallons of 100oct gas I've confirmed fuel quality is my issue. The new logs are the car running BM3 Stage 1 93oct with 4 gallons of 93 and 2 gallons of 100oct. These logs look perfect to me. All timing corrections have been fixed and the knocks are gone. Logs arent the cleanest due to autolog not working but still look good none the less. New logs Mix of 93/100oct fuel: https://www.bootmod3.net/log?id=5f7b...0b4379a0b36d26 https://www.bootmod3.net/log?id=5f7b...90c66c1601a111 Old logs on just 93oct fuel: https://www.bootmod3.net/log?id=5f6f...0b4374521e76b9 https://www.bootmod3.net/log?id=5f6f...729b1c3b23d66b |
10-06-2020, 10:26 AM | #3450 | |
Rep 7,606
TK335iMSPT299.00 |
10-13-2020, 08:15 AM | #3451 |
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
10-13-2020, 03:07 PM | #3452 |
Rep 1,079
Does it make sense to upgrade the HPFP to be able to run the new Stage 2+ E30 map or even get a custom tune for E50 without upgrading the stock turbos for EWG N55? I believe it should give a decent bump in power? Plus in case I do upgrade the turbo later on I'll already have the supporting fuel system?
10-13-2020, 03:50 PM | #3453 | |
Rep 7,606
10-13-2020, 03:54 PM | #3454 |
Rep 1,079
Yes that would be one way of putting it I believe with Stage 2 E30 map I'm making somewhere around 360-370whp. Will the 2+ E30 with just upgraded HPFP take me beyond 400whp? And will I benefit from custom E50 or will the stock turbo be a limiting factor?
