BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Exhaust Flap Actuator Fuse
      01-30-2015, 10:47 AM   #1
R_C_S_//M3
Launch Control Specialist
R_C_S_//M3's Avatar
Drives: 2018 Mineral White BMW M3 CP
So after many issues with my exhaust it seems my actuator may not be functioning. Any idea where the fuse that handles actuator is on a 2015 F36 435i Gran Coupe?
      01-30-2015, 09:45 PM   #2
CG Precision
CG Precision's Avatar
Drives: 2013 BMW 335i
The fuse should be in the same location on your grand coupe as it is on our shop F30. It is located in the middle of the trunk underneath the removable trunk cover. There should be a small piece of paper folded up in the fuse box cover that shows the exact location of the exhaust flap fuse. Good luck resolving your issue.
CG
      02-11-2015, 11:01 AM   #3
kaybe
Switzerland
Drives: 435i - F36
Same thing - 435i GC
I have the same problem - it looks like the flap don't open at all: warm engine / hight rpm / sport or sport+ mode... the left exhaust outlet is clean like new..
Today I talk to my BMW service partner - they say that the exhaust flap don't have a separate fuse.
Actually I can't really belive that so I will go next week to the service partner to check the car..
If you have any news, please let me/us know
      02-11-2015, 11:07 AM   #4
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
I actually need to bring that up with the dealer when I go there in a couple hours. I have chunks of ice in the left tip, so clearly its not opening, because exhaust heat should melt ice instantly.
      02-11-2015, 11:31 AM   #5
R_C_S_//M3
R_C_S_//M3's Avatar
Let me know what they say. I am almost 100% positive my flap is not functioning. I need to get a GoPro to be certain it seems. The dealer has been no help.
      02-11-2015, 11:44 AM   #6
kaybe
Switzerland
Drives: 435i - F36
I used a paper ball made of an old newpaper - press it in to the left tip - if the flap opens it will shoot out the ball (try it with the right one).
My was after 5min. driving still inside (warm engine / sport+ mode)
      02-11-2015, 12:28 PM   #7
R_C_S_//M3
R_C_S_//M3's Avatar
That was a hell of an idea. My flap does open. Shot the ball out the driver tube when stepped on it.
      02-11-2015, 02:05 PM   #8
Mike_L
Dealer was no help. They didn't even look at it. Made me make an appointment with a loaner so they could check it more thoroughly. We'll try again in 2 weeks when that appt is.
      01-25-2016, 06:31 PM   #9
venom4065
Drives: 2013 F10
Any update on this, I have same issue.
      11-22-2016, 11:16 AM   #10
MattOz
MattOz's Avatar
Drives: Alpina F31 D3
2011 E90 M3  [0.00]
I have the same issue as some of you guys. My flap doesn't appear to open at all, regardless of comfort/sport/sport+ mode or revs. BMW tell me that the flap moves when they plug in diagnostics, but it doesn't work at all during normal operation. It's going back in again to try and resolve.
      12-15-2017, 01:32 AM   #11
harry26
Drives: 2016 X6
https://www.ecstuning.com/b-genuine-...r/18308632154/
Read the product details.... most likely your actuators are dead !!
      12-15-2017, 06:13 PM   #12
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
the flap will open above 2k rpms and during cold start. you should hear the flap close like a minute or two after the cold start. I too have had the same issue with ice build up on the left tip and thats because i was in comfort and not over 2k to open the valve.
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      12-17-2017, 06:00 PM   #13
ultim8drivingmachine
Drives: 2017 340i xdrive
Flap has now been permanently open by the dealer! The Canadian cold winters don't leave us much choice. Unless you have a heated garage, that's the way to go!
      12-18-2017, 03:17 AM   #14
perryo91
perryo91's Avatar
Uganda
307
Drives: 335
My flap (perf exhaust) opens after a minute or two after a cold start.
Hi
      04-06-2018, 03:01 PM   #15
BimmerFan
Drives: 2014 335i M Sport EB
My flap stays open full time and since I have a full catlessturboback exhaust system, cold starts can be quite loud. I replaced the actuator with a new one, but this did not resolve the issue. Does anyone know where this darn fuse is located so I can check it? Thanks!
Vorsteiner VFF 103s 19/8.5 +30; 19/10 +45; JB4+PTF BEF; JB4 bluetooth connect kit; CG Precision DR-1 race DP, CG Precision Exhaust; AFE Momentum CAI; ATM FMIC; ER Charge Pipe; Pure STG 2 Turbo+Hi Flo inlet; GFB DV+; Fuel-it Platinum PI kit; Fuel-it STG 2 LPFP; N20 TMAP; AFE fsb and rsb; Koni Yellows; Dinan lowering Springs.
      05-22-2018, 03:30 AM   #16
iVeBlink
Drives: F30 LCI
Me to always open. Who know what that?
      05-22-2018, 11:07 AM   #17
jebs2k
Drives: 2016 435
flap is fuse 146 (shared with park assist)
in the trunk
http://tunjul.com/wp-content/uploads...s-adorable.jpg
left column, 4th fuse down
i unplugged mine with the flap open, so flap is always open
2012 335
2016 435
2019 440 GC
haagm58542.50
      05-22-2018, 03:45 PM   #18
iVeBlink
Drives: F30 LCI
Mine fuse number 146 is correct. Problem is different, because flap never close. I go in eco and comfort mode and she always open. I like loud exhaust, but my baby no... I dont know why she dont close...
      06-22-2018, 09:14 PM   #19
EggoEspada
Drives: BMW 340i '18
Iím actually having the same issues, so Iím trying to figure this out also. Not a fan of keeping it always open
      07-06-2018, 11:45 AM   #20
Ducati182
Drives: BMW 340i X
Fuse for exhaust valves
I tried to disconnect my exhaust valve on my 2018 340 but the wires on very tight and I dont want to break the clips.
Does anyone know which fuses to pull to disconnect the valves?
      07-08-2018, 01:27 PM   #21
Jnat
DisplacementReplacement
Jnat's Avatar
Drives: 2015 M235XI
I can confirm the exhaust flap is open when car is cold and not started. I simply put a small screwdriver in top of connector and pulled backwards, it disconnected with a little effort and then I zip tied connector as high as I could. Seems fine and very open.
2015 M235XI - MHD E20 STG2+ - XHP STG3 ***
      08-10-2019, 08:30 PM   #22
DrGadget
DrGadget's Avatar
36
Drives: M140i F20 LCI-2
Open and close exhaust flap
This is my suggestion to opening and closing the exhaust flap without losing Parking Assistant by pulling fuses 146 and 147 (the two with a red line shown below), or disengaging the plug to the actuator.
https://f30.bimmerpost.com/forums/sh...6&postcount=35
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
