BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Beep when locked while engine running
      07-23-2021, 11:40 PM   #1
awschubert
Drives: BMW 328i
A little while back I had some coding setting changed on my car for some LED lights I had put in my car. In the process some how some of the things I had in my car vanished. One of them was the alarm beeps/chirps when I locked my car while the engine is running. For some reason now, my car doesn't do that. Does anyone know what I need to code back in or change to get that to be back on? I have esys and BimmerCode so I can make the changes but I don't know what to look for. I don't want the horn to beep twice cuz that's what find in the basic settings of BimmerCode, but I don't want that, I want the alarm chirps like it did before? Can anyone help?
      07-24-2021, 03:19 AM   #2
atzebmw
Drives: Tesla Model 3
FEM, 3040 ClMaster,0D
CLM_HORN_AT_SECURE
set it to aktiv
      07-24-2021, 09:06 AM   #3
awschubert
Drives: BMW 328i
CLM_HORN_AT_SECURE
set it to aktiv
Not the horn that I want. It's the beeps from the alarm system. This is the one I tried and it makes the horn honk.
      07-24-2021, 11:49 AM   #4
atzebmw
I'm not sure if i understand.
You want the horn when you lock the car and the engine is running or you want the beep when you lock the car?
For the beep when you lock the car...
HU_NBT, 3000_HMI, 96
ACOUSTICAL_LOCK_CONFIRM
After coding activate it in the iDrive menu
      07-24-2021, 12:16 PM   #5
awschubert
Drives: BMW 328i
I want the beep not the horn. My car already beeps when I lock it when the ignition is off, but for some reason it stopped beeping when I press lock when the ignition is on. It used to but it's not anymore after some of my bulbs were coded to led. Trying to figure out why. I'll check those parameters and see if that fixes it.
      07-30-2021, 06:49 PM   #6
bendeyo
Drives: 2013 BMW F30 N55 335XI
I thought that was an idrive setting, not a coding setting.
      04-20-2022, 03:16 PM   #7
TommyF30
Drives: F30 328i
Hate to revive an old thread but I’m having the exact same issue. Did you manage to find a fix? I’ve tried everything on Bimmercode. Didn’t have this issue until I had my car serviced and it updated my software…
      04-20-2022, 10:37 PM   #8
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
They probably wiped that option when they updated the software. I won't let a dealer even get near my car for just this reason.
