07-13-2021, 04:09 PM | #1 |
Rep 54
Question re: catted dp, CEL, and Bootmod3
I am considering upgrading to a high-flow catted downpipe. However, we all know that even a catted downpipe will throw a code and cause the Check Engine Light to come on.
I understand that Bootmod3 can be programmed to eliminate the CEL. My question is: how exactly does it eliminate the CEL? Does the Bootmod3 programming allow for accurate reading of the exhaust through the O2 sensor but change the parameters within the DME as to what are acceptable readings in the exhaust? Or does it "trick" the DME into reading cleaner exhaust gasses? Or does it allow the O2 sensor to read accurately but it just overrides the DME's attempt to go into "limp" mode? or is it none of these? Forgive my ignorance if none of these are legitimate possibilities. I'd appreciate some clarification on how the CEL is eliminated. Thanks!
2016 328i XDrive N26 8AT: K&N Drop-In Filter * GPlus FMIC * ER Chargepipe * DinanTronics Sport Tuner (Race +4psi) * AWE Midpipe (2nd Cat Delete) * Dinan Axleback Exhaust * Dinan Sport Springs * Megan Racing Front Strut Tower Bar * Cross-Drilled Rotors * Hawk HPS 5.0 Brake Pads * StopTech SS Brake Lines
07-26-2021, 12:11 PM | #2 | |
Rep 1,171
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
07-26-2021, 12:33 PM | #3 | ||
Rep 1,934
If your state allows monitor(s) to be in the "Not Ready" but not "failed" state, then you can pass as long as your "not ready" count is below that state threshold. For eg. Many NE states like NY and MA allow 1 monitor in the "not ready" state. If the cat is the only monitor in this state you will pass. This is assuming that they don't attach anything to the muffler and do a sniff test, or have grounds to do a visual inspection under the hood.
07-26-2021, 02:36 PM | #4 |
Rep 73
I passed emissions with it in "Not Ready" state. Works quite well.
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
07-26-2021, 02:46 PM | #5 |
Rep 472
I have a 2015 328i (n26 motor) with an ER catted downpipe and bm3. I dont use the BM3 option to block the CEL and I have only had a CEL one time after pushing the car really hard. I cleared the code and it never came back. I have passed NY inspection with the catted downpipe. Just my two cents.
