04-13-2021, 05:41 PM | #1 |
Rep 1
b58 Mhd throttle issue
Hi, I have a 2018 340i with the B58 motor with an mhd stage 2 93 octane tune. Under low to medium load at low rpms my car will start to surge as if the throttle is opening and closing. I data logged(Can provide if needed) while it was happening and the throttle is actually opening and closing quickly causing the surging. Does anyone have any idea on what might be causing it or how to fix it?
04-14-2021, 08:07 AM | #2 |
Rep 282
i experience the same issue . but i yet have to log it when it happens ,
it feels like lots of wastegate action to me , but if you have logs to share pls do it happens when i use comfort mode and mild to low acceleration without downshifts
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
04-14-2021, 03:06 PM | #3 |
Rep 282
04-19-2021, 01:49 AM | #4 |
Rep 1,452
Oscillating overboost. Your boost PSI is constantly over target, then the DME tries to correct by closing the throttle. It repeats over and over.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 Last edited by G.Newt; 04-19-2021 at 05:17 PM.. |
04-19-2021, 02:33 AM | #5 |
Rep 3,861
@G.Newt
Caused by what...?
04-19-2021, 08:32 AM | #6 |
Cheapskate
4447
Rep 4,993
Could be poor boost control in the tune but if it just started happening then i'd check for boost/vacuum leaks, damaged wastegate actuator, etc.
04-19-2021, 02:41 PM | #7 |
Rep 3,187
I have the same issue. Only happens below 2500rpms and 30-40% throttle. Pretty sure it is just poor boost control from the OTS maps. When it happens I just give it a little more/less throttle
04-19-2021, 02:51 PM | #8 |
Rep 3,861
And MHD wouldn't know/bother, if it is a widely
spread tune issue....? 🤔
04-19-2021, 04:11 PM | #9 |
Rep 282
im waiting on a testmap from fabian to resolve the problem , on an fb page from mhd , the testtune worked well with someone who had the same problem , mhd prolly update their ots later on after some more feedback upon the problem , make sure to send them a message if you have the same problem
04-21-2021, 04:46 AM | #10 |
Rep 282
https://datazap.me/u/thomas/ots-osci...ata=3-20-24-33
this is a lot better already , surging feeling is negligible . might be between the ears aswell
04-21-2021, 06:09 PM | #11 | |
Rep 1,452
Your last log didn't show problems until 2,800 rpm lol.
04-22-2021, 05:45 AM | #12 |
Rep 282
the problems are noticable at low load in comfort ,
i dont think people drive wot all the time , that was already written a few posts ago
04-22-2021, 09:17 AM | #14 |
Rep 282
its a testmap , i will receive more ,
then they will rollout a new ots maps after decent feedback from many clients
04-27-2021, 07:48 AM | #15 |
Rep 282
https://datazap.me/u/thomas/ots-osci...=1&data=3-4-20
update with test map 2 , three logs , low to mild boost levels
Hollandazedd3.00 |
04-30-2021, 03:19 AM | #17 |
Rep 3,861
Good job - both from you and MHD!
I am more and more attracted to trying out MHD soon.
05-02-2021, 01:35 PM | #18 |
Rep 146
05-03-2021, 06:37 AM | #19 |
Rep 282
i have some wifi disconnects too when im using the monitor .
it will be resolved over time
05-03-2021, 09:12 AM | #20 |
Rep 146
MHD stated the problem is caused by using my ak motion display at the same time.
However i had everything working together before flashing. Ill try a few things out and we’ll see Edit: switching off the ak motion display solved the problem. Last edited by bartbes; 05-03-2021 at 09:50 AM.. |
02-11-2022, 08:45 AM | #21 |
Rep 30
I'm having this same surging issue that's no better with the updated MHD Map. I've read that there's a setting in the JB4 related to load or something else, that when changed (doubled), it eliminates the surging (I can't find the thread that I read it in). It seems that if MHD had the same customizable setting, that might solve the issue. Is there anything in the OTS tune that I can alter to replicate what the JB4 is doing?
02-11-2022, 09:27 AM | #22 |
Rep 3,861
How about contacting MHD directly and sharing a log with them to diagnose the issue….?
