BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Oil all over my spark plug cylinder 4
proTUNING Freaks
      05-02-2021, 06:05 PM   #1
Sleeper340i
Drives: BMW 340i
So I'm just took out my spark plugs and every single spark plug is good besides cylinder 4 spark plug.
Do you guys have any guesses what the main culprit is? Been having oil leak problem for a while, even though it hasn't leaked in a month from what I've seen it's been on average .5L a week to two weeks lost.
Also Mechanic did testing on my PCV and the testing came out good so not sure what it could be.
      05-02-2021, 11:09 PM   #2
Sleeper340i
Drives: BMW 340i
Guess I'm going to start with a valve cover gasket, even though my PCV testing came out fine. Do you guys recommend replacing the valve cover too?
Also, is there any DIYs I can use from N55 or N54 to replace this? None on B58s I can find and not really trying to pay a grand or more unless I have to.
      05-03-2021, 05:29 PM   #3
Wires
Drives: 2016 340i xDrive
Any other signs of oil around that plug? Could have been an "oops" during an oil change and it ran into that hole.
      05-04-2021, 01:31 AM   #4
Sleeper340i
Drives: BMW 340i
There was some oil inside on the left side deep inside near where the spark plug goes inside. Besides that, was relatively clean everywhere else that I saw including when swapping the plugs out.
      05-04-2021, 07:25 AM   #5
Wires
Just wondering. I had a similar issue on my N54, and it was from me spilling oil when refilling which ran into the one plug bore.
      05-04-2021, 07:50 AM   #6
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
Do a compression test on cylinder 4.
Youtube/Instagram/TikTok: @kern417
      05-04-2021, 11:22 AM   #7
weehe126
Drives: 2017 340i
The oil is above the threads. It's from a VC gasket leaking down onto it. Or from pouring oil on it as mentioned above.
kern4174446.50
      05-05-2021, 07:58 AM   #8
kern417
Cheapskate
4447
I thought I was going crazy because I couldn't see oil on the tips but I made an assumption
      05-05-2021, 11:43 AM   #9
mike082802
Drives: 2010 135
good catch
      05-05-2021, 08:42 PM   #10
Sleeper340i
Drives: BMW 340i
Thanks for the help everyone will be changing out my valve cover gasket shortly down the road.
