View Poll Results: Zimmerman 2 Piece Rotors... Real or Not? | |||
Legit - Save the money | 2 | 40.00% | |
1 Piece - Savings but not as advertised | 3 | 60.00% | |
F*** it, buy the real Genuine BMW parts. | 0 | 0% | |
Voters: 5. You may not vote on this poll |
07-19-2019, 11:44 AM | #1 |
Rep 106
Drives: 2014 335i xDrive M Sport
Zimmerman Two Piece Rotors?
Has anyone bought these and can confirm that these are indeed a two piece design similar to the stock 335i rotors (340mm not 370mm)?
https://www.fcpeuro.com/products/bmw...nn-34106797602 I contacted FCP Euro about them and questioned that the photo for the listing was the exact same photo as for the M Performance rotors that cost 3x as much but the response I received was a typical canned response and didn't build much confidence. If they actually are as claimed, then I've got to say this would be a no brainer when I replace my rotors, but if, as I suspect, they are a solid 1 piece with zimmerman coatings then I am not so sure. |
07-19-2019, 12:10 PM | #2 |
Rep 1,827
Hmm, based on this, this could be an incredible find!
https://www.turnermotorsport.com/p-3...m-sport-s2nha/
07-19-2019, 12:15 PM | #3 |
Rep 1,499
Those are not two-piece per the Zimmerman website.
http://ows-cdn.tecdoc.net/otto-zimme...22f14a94f205fa If you go there catalog you can serach for p/n 150.2906.20 and find this info.... General Article Number 150.2906.20 Article Status Normal Packing Unit 1 Quantity per packing unit 2 Criteria Brake Disc Type Internally Vented Machining High-carbon Brake Disc Type Slotted Drilled dimples Surface Coated Outer diameter 340 mm Thickness 30 mm Min. thickness 28,4 mm Height 73 mm Hole Pitch / Number 6/5 Bolt Hole Circle Ø 1 120 mm Hub Bore Ø 79 mm ABE No. KBA 61364 Weight 10,9 kg What you want is part number 150.2906.32 General Article Number 150.2906.32 Article Status Normal Packing Unit 1 Quantity per packing unit 2 Criteria Brake Disc Type Internally Vented Machining High-carbon Brake Disc Type Slotted Drilled dimples Surface Coated Outer diameter 340 mm Thickness 30 mm Min. thickness 28,4 mm Height 73 mm Hole Pitch / Number 6/5 Bolt Hole Circle Ø 1 120 mm Hub Bore Ø 79 mm Weight 10,9 kg Supplementary Article/Info 2 Two-piece Brake Disc Quality Alu-Topf genietet Alu hub riveted
FaRKle!4016.00 |
07-19-2019, 12:39 PM | #4 |
Rep 1,499
Additionally, if you have the M Sport brake (S2NHA) you could get Zimmerman part number 150.2905.32 which is a 2-piece rotor, slotted and dimpled and carried by FCP
https://www.fcpeuro.com/products/bmw...nn-34106797603
07-19-2019, 10:59 PM | #6 | |
Rep 106
07-22-2019, 09:45 PM | #7 |
Rep 5,393
07-22-2019, 09:54 PM | #8 | |
Rep 5,393
True big brake kits such as BremboGT use "floating" two-piece rotors which allows for the different heat characteristics of the two different metals used for the rotor hat and the rotor braking surface. |
07-23-2019, 10:58 AM | #9 | |
Rep 1,523
I have both the BMW and Pagid branded simple and slotted rotors. Both are made in Italy and both are physically the same in apperance. Only difference is that the hub (aluminium part) is uncoated on the BMW rotors and coated on on the Pagid. |
07-23-2019, 04:05 PM | #10 | ||
Rep 5,393
07-23-2019, 04:33 PM | #11 | |
Rep 1,523
Picture of the m performance rotors when new. You can clearly see the rotor is coated (except for the bare aluminium hub) https://c1552172.ssl.cf0.rackcdn.com/612641_x800.webp |
07-23-2019, 04:44 PM | #12 | ||
Rep 5,393
07-23-2019, 05:06 PM | #13 | |
Rep 1,523
07-23-2019, 05:07 PM | #14 | |
Rep 3,539
M4_GTS1152.50 |
07-24-2019, 12:09 PM | #16 |
Rep 106
So I sent a bunch more emails back and forth with Kevin at FCPEuro and he advised that the part number "150.2906.32", is the part listed on the site and the Zimmerman reference number on the FCPEuro site is incorrect. So these are the 2 piece rotors despite the confusion.
I am going to risk it and order a set in the next week. I'll post an update with pictures. If they are not as claimed they'll go straight back. |
07-24-2019, 04:23 PM | #17 | ||
Rep 1,499
Hey that's good to know. Hopefully they will update their website. I've been in communication with Kyle at FCP to see if they can start carrying the rear versions.
My email to Kyle... Quote:
07-24-2019, 07:27 PM | #18 | |
Rep 1,523
07-25-2019, 12:29 PM | #19 |
Cheapskate
4447
Rep 4,993
Because you have to pay for the next set from Rock Auto haha. Go FCPEuro for all wear items if at all possible.
07-25-2019, 12:36 PM | #20 |
Rep 106
I live near enough to the border that the extra shipping costs from Rock Auto to get it to Canada ($180 CDN shipping + guaranteed duties and taxes = ~$250) don't make sense over the free shipping from FCPEuro to my US address. Rock Auto charges $50 to ship to my US address and doesn't carry the other parts I am looking to order at the same time from FCP.
07-27-2019, 01:34 AM | #21 | |
Rep 1,523
07-27-2019, 03:16 PM | #22 |
Rep 1,934
These 370mm and others are only semifloating two piece. All are steel faces with aluminum hats. ECS makes one that saves you about 2lbs in the aluminum hat piece. The dimensions we can fit don't allow for a true floating two piece rotor.
Littlebear3509.50 |
