12-01-2014, 07:31 PM | #1 |
Rep 221
Fuel Pump left me stranded. Anyone else have this happen?
Hi,
So I'm driving, and from a stop light after taking off a little hard, i get a Drivetrain Malfunction Warning on the screen and the car had just enough juice left in it for me to pull over as it died on me. Once it died, it would not start again after many attempts. Had it towed to the dealer and they had to replace the fuel pump. Car has only 2800 miles and is a 2014. WTF? Car has an intake and had a bms stage one for 1,000 miles before this incident. Would a stage 1 cause the stock pump to not keep up. I mean an increase of 3.5lbs of boost isn't much to work the pump that hard, correct? Just really disappointed right now and lost confidence in the car. The tune has not been plugged back in for now. Just not really sure if this would happen again if it was put back in. Are stock fuel pumps on these new 335's an issue like the N54? TIA Last edited by WickedC5; 12-03-2014 at 09:53 AM.. |
12-01-2014, 11:42 PM | #2 | |
Rep 1,060
12-03-2014, 09:56 AM | #5 |
Rep 221
12-03-2014, 12:40 PM | #6 |
Rep 1,961
Actually, the part number changed starting with 11/14 builds, so they may have changed something.
12-04-2014, 11:10 AM | #7 |
Rep 168
It's still garbage. It's hard for me to get consistant clean pulls. Maybe it is just the really cold outside temps but I'm having major fueling issues!
VO_1M on IG!
2011 Valencia Orange 1M - Stoptech Trophy BBK, KW Clubsport, JB4 MHD Backend, TFT, TIAL Q, MMP, ATM, Akra Dps, Lightweight Ti, Rogue, iND, R888 2015 435i Msport - 6MT, RWD, Fully loaded, FBO JB4 - gone 2011 335i 6MT JB4, AR Dp, Cpe Cp, AFE, E85 map 7 -gone |
12-04-2014, 11:12 AM | #8 |
Rep 168
Mine was built in August actually i can't comment on 11/14 builds... Hopefully they fixed it and do a recal??
VO_1M on IG!
12-04-2014, 07:36 PM | #9 |
Rep 1,060
I have the same problem! My HPFP was just replaced last month and the car feels really laggy and down on power. Even with the MPPK and MPE, after the pump was replaced, the car doesn't feel the same at all. Sometimes it's quick and other times it hesitates. It NEVER behaved this way before the replacement HPFP
09-09-2015, 07:52 AM | #10 |
Rep 4,323
wasn't this a recall?
09-09-2015, 10:50 AM | #11 |
Rep 2,210
Drives: '17 jackrabbit on crystal meth
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
09-09-2015, 11:46 AM | #12 |
Rep 368
I had the exact same problem using bms stage 1!
Initially thought it was blown chargepipe but exact same scenario as OP; stop light, took off hard, limp.
2016 340i XDrive: Bootmod3. And stuff.
09-10-2015, 11:02 AM | #13 |
Rep 190,804
Its just a bad fuel pump. It should be able to keep up with no problem
09-10-2015, 11:11 AM | #14 |
Rep 115,980
09-10-2015, 01:45 PM | #15 |
Rep 368
09-10-2015, 03:57 PM | #16 |
Rep 190,804
You need to use your Jb4 with BMS data cable to log
09-10-2015, 10:22 PM | #17 | |
Rep 100
2014 Mineral Grey 335xi ZMM, ZPP, ZCW, ZDA, ZTP.
Performance: FBO; MPE, Brembo M BBK, ER CP, ER DP, Phoenix IC, JB4, KW V2, Mechunik Front Tower Strut Brace, Michelin PS AS3+, JL Audio W6 10" HO sealed/ported box, and a bunch of other stuff you probably don't care about either. |
