11-21-2018, 09:46 PM | #45 |
Rep 16,079
+1. Techron is probably effective in cleaning the fuel delivery system from the tank to the injectors but it doesn't clean the intake valves with direct injection engines. That requires intake valve cleaner.
11-28-2018, 09:03 AM | #47 |
Rep 387
Techron is legit. I noticed a huge difference when I used it on my old Jeep, and also noticed an increase in mileage when I switched to Chevron gas in all our cars. While it’s true that the valves in our DI engines won’t reap the benefit of fuel system cleaners like Techron for cleaning the valves, don’t forget that piston tops develop carbon buildup too, so Techron can still help in that regard; not to mention helping keep injectors clean as well.
So far as valves go, walnut blasting seems to be the primary solution. I do plan to use that CRC GDI cleaner before my next oil change. I have an endoscope and will try to take some before and after pics when I do. I’m really curious to see if that stuff works. If it does, it can save us a lot of hasssle. Last edited by IraHayes; 11-28-2018 at 09:26 AM.. |
sspade2464.50 X2 Monstah301.00 |
11-28-2018, 12:04 PM | #50 |
Rep 5,456
Drives: F30
FWIW...
I user a bottle of Techron on my last fill up before oil change (every 5k). No issues, car runs like an absolute top. |
12-06-2018, 12:57 PM | #51 |
Rep 718
I put a bottle of Techron in my 328 and my wife's 128 this past weekend. I noticed a considerable improvement in the 328's throttle response and it seems the injectors are much quieter also. The 128i seems to run smoother, but that is a silky-smooth, easy-revving car anyway. Haven't noticed any change in MPG yet, but I'll be watching it over the next few fill-ups.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
06-28-2019, 08:21 AM | #52 | |
Rep 433
09-07-2019, 12:44 AM | #53 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
its the ONLY thing that can clean the deposits off an e46 SULEV fuel sender (the tanks are 100% sealed, so fixing a non working fuel level sender or pump means an 8K tank plus labor) and restore it to operation. When mine gets wonky (we only have shell stations), i add TWO bottles, fill the tank and let it sit over the weekend, invariably the level starts working again on monday. when i first bought it i had to do this two tanks in a row, but it works now and works reliably for 10-12 months before i have to do it again.
09-18-2019, 05:43 PM | #54 |
Rep 1,045
I been using only chevron 94 octane with 0% ethanol, so I get a good dose of the techron addictive with every fill up. Always ran fine, instead of buying techron separately, why don't you just get chevron 94 gas ? It comes with techron generously added already. From what I read, it's better to do it this way because you are cleaning it long term rather than just cleaning it once with a bottle then starts the buildup again. Also, ethanol is extremely bad for our cars, in case somebody reading this but doesn't know.
Mods: Dinan Tuned, Intake, Catless DP
09-28-2019, 10:39 AM | #55 | |
Rep 387
10-01-2019, 01:31 PM | #56 | |
Rep 849
Drives: BMW 435i
10-02-2019, 08:16 PM | #58 |
Rep 2,196
Welcome to the definitive list of stations that sell pure, ethanol-free gasoline in the U.S. and Canada! https://www.pure-gas.org/
10-04-2019, 05:09 PM | #59 |
Rep 1,045
Well, I got a Chevron station a block from my house, I'm in Vancouver BC, but I see you're in cali, so I have no idea
01-15-2020, 05:35 PM | #60 |
Mini Cooper, Present F15 Owner
Rep 90
I first used Techron in my first 320i (back in the old days - it was an '82). Chevron would also sell it as an additive in their pump fuel. Can't find a Chevron station anymore but I like it in my Mini Coopers and will probably give it a try in the Countryman we just bought.
My Bimmer is a 328d so I'm not aware of any magical elixers for the D's. |
01-19-2020, 08:49 AM | #61 | |
Rep 10,351
Redline Si-1 also has a lot of PEA and consequently is a comparable alternative to Techron. For a different type of cleaner there's Berrymans B-12 is probably worth using every 10k-15k miles even with today's highly additized. gasoline. It's a fairly strong solvent. Diesels: Techron-d is just one of many for the diesel market.
"Drive more, worry less. "
chevron, fuel consumption, fuel injectors, fuel system cleaner, techron |
