10-23-2019, 09:58 PM | #2531 | |
Rep 2,639
1st to 4th gear, 2k to 6500rpm, then stop the logging. If you leave it on and drive around, it's cluttered and we can see anything. always keep the logs below 20 seconds. Here's an example: http://www.bootmod3.net/log?id=5d7d6aa0c090c61952111c00
10-24-2019, 05:26 PM | #2532 |
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
hardparker299.00 jmack548.50 |
10-25-2019, 12:33 PM | #2533 |
Rep 1,862
Version 8.0 N55-PWG172X OTS maps update now released:
https://f30.bimmerpost.com/forums/sh....php?t=1663702
hardparker299.00 |
10-25-2019, 02:23 PM | #2534 | |
Car Hypochondriac
335
Rep 901
10-25-2019, 11:59 PM | #2535 |
Rep 141
https://datazap.me/u/tsa8151/log-157...1&mark=158-321
Couldn't manage to get a decent log but that's a 5th gear pull from the new pwg stage 2 e30 ots. Car pulled great. |
hardparker299.00 |
10-26-2019, 08:43 AM | #2536 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Thanks for all the new maps proTUNING Freaks! I'm enjoying the 8.0 E30 PWG map.
What I'm really looking forward to are "hats" for the Raspberry Pi agent. I'm hoping for: Relay hat - custom on/off output control for fuel pumps, etc. PWM hat - control for port and WMI injection, etc. POE hat - custom repin OBD to Ethernet cable to supply power to Pi. All controllable via OBD parameters as inputs. Set custom in-app WMI maps referencing IAT and boost, for example. Control port injection based on DI injector duty cyle and throttle, etc. Import ethanol content from sensor/ECA. I'm sure people will come up with nice combinations. A custom hat with all of those features and a custom pinned OBD cable for POE would be a winner!
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
designatedposter175.00 |
11-04-2019, 08:22 PM | #2537 | |
Rep 552
I downloaded the latest OBD agent and reflashed Stage 2 ACN91. This time, I went from cold starts disabled to cold start OEM @ 950rpm. Been almost 3 weeks now and the hidden O2 code has not popped back up at all. |
11-05-2019, 01:31 PM | #2538 |
Rep 1,862
UPDATE: Map configuration screen descriptions for all settings and values available.
This should help those using the screen for the first time get a sense of what the values are if or when they may not be clear. I realize some of you will enjoy these being added right in the screen even though all of them are documented in the actively maintained bootmod3 User Manual.
11-06-2019, 07:57 AM | #2539 |
Rep 1,499
Why is it recommended to leave cold start RPM to OEM? I have cold start on but RPM set to 900 so it's not so loud. I've had it set like this for almost a year and no issues. Turning cold start off resulted in unpredictable throttle response at tip-in and turning cold start on seemed to resolve this issue.
Insane435476.50 |
11-06-2019, 08:29 AM | #2540 |
Respect My Authoritah
368
Rep 873
Cold start is too loud with Dinan exhaust and ER catted DP. I have neighbors and it's just obnoxious, especially when it completely quiets down afterwards.
Turning cold start off results in Jared's previous post. Turning down cold start RPM helps, but it's still too loud. My solution is to have cold start off and use the gas pedal to hold RPM around 1800 for 3-4 seconds. Guess I don't get to use the GTS startup roar. I can't wait until I don't have neighbors.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
11-06-2019, 06:02 PM | #2541 |
Rep 252
Drives: 2017 Model S P100D
To anyone running the ots e30 maps, is there a substantial difference from the stage 2 map? I was looking around on the PTF faq and saw an n55 m2 with approx 20whp/20trq, is that typical? It was 413whp/448trq
E85 is available fairly close to where I live and i'm craving more power |
11-06-2019, 08:32 PM | #2542 | |
Rep 552
They seem to only recommend cold start on at OEM according to these new details. User manual explains "Custom RPMs will range from 660-1200 RPMs. This function is used to reduce the high idle RPMs when the vehicle is first turned on" |
11-06-2019, 10:32 PM | #2543 | |
Rep 1,115
If you're planning on trying it, buy one of those E85 test graduated cylinders on Amazon and confirm that it's E85 and not more or less. The E85 pump here puts out E90 so I scale back the mix to compensate. You might run into prolonged cranking to start and other issues when its cold out, my car hates E30 when it's below 10-15c. |
11-08-2019, 06:18 PM | #2544 |
Rep 2
someone wants to sell me his bootmod3 license he says he never instal how to know if a license is new so that I can sell it to someone else
because a license his 2 times maximun that can resell it |
11-08-2019, 06:34 PM | #2545 |
Rep 141
11-11-2019, 01:45 PM | #2546 |
Rep 11
F25 BM3 paddles fixed on Trans flash
Just got off a session with Serge. They loaded an updated TCU flash via eSys and it fixed the paddles not working with the trans flash. All good now!
No crankshaft or other codes either. |
11-11-2019, 08:14 PM | #2548 |
Rep 384
11-11-2019, 09:50 PM | #2549 | |
Rep 192
11-11-2019, 10:39 PM | #2550 |
Rep 931
11-12-2019, 04:29 AM | #2551 | |
Rep 384
In my country, many people won't even consider using sport+ because of the road condition. |
11-12-2019, 02:44 PM | #2552 | |
Rep 1,286
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
