10-16-2020, 05:05 PM | #221 | ||
Rep 241
Delrin subframe bushings and wavetrac in the back |
10-17-2020, 07:03 PM | #222 |
Rep 233
Im not sure if this answers your question but I took my front spacers off when I installed the M3 LCAs and TSs. I only run spacers in the rear now. Fronts were poking too much with spacers, LCAs, and TSs
10-30-2020, 08:48 AM | #223 | |||
Rep 241
So, clearly its not from the TS! |
11-03-2020, 04:09 PM | #224 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Has anyone tried just installing the thrust arm to adjust the caster?
For some reason I got really positive caster on my F30 after lowering it on Bilstein PSS10 and using KMACs adjustable bushing for the lower arms. Try to stay away from camber plates. |
11-03-2020, 04:33 PM | #225 | |
Rep 833
Drives: BMW F36, E36, E93
Are you driving staggered wheels?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
11-03-2020, 04:43 PM | #226 | |
Rep 1,291
I removed the arms altogether, put millway street camber plates instead.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
11-03-2020, 05:01 PM | #227 | |
Rep 3,539
KMAC makes a tension strut monoball that allows you to adjust caster and move it back.
itsrichierich186.50 |
11-03-2020, 06:05 PM | #228 | ||
Rep 241
11-04-2020, 11:00 AM | #229 |
Rep 833
Then I am not worried :-) With my standard 225 the effect will only be half as bad :-)
Such Fun
01-22-2021, 02:43 AM | #232 |
Rep 35
It seems like this F80 LCA & TS does have a lot of different feedback, some are perfectly fine with it, but some are not. I did the LCA only and i do love the streering feel now but i do have rubbing issues on the left wheels, the right is totally fine. Anybody faces this kind of issue? I have order a pair of TSs to go with it and see will it correct the caster issue.
01-22-2021, 03:57 AM | #233 | |
Rep 833
Wheel and tire size, and where doese the wheel touch? Fender liner or wing?
Such Fun
01-22-2021, 04:07 AM | #234 | |
Rep 1,291
Tension strut is a waste of time not going to change anything
01-23-2021, 12:27 AM | #235 |
Rep 35
Well, mine is rubbing on the left side, but my tires are slightly oversize at 235/35R20 on the fronts. Anyway, I've gotten a pair of TS which have yet to be install, will install that and see how it goes. I do have ohlins n millway camber plates, but still wanna have a f80 arms as it does give a lot better feedback on the front end, the car feels a lot nicer to drive. Btw for the spacers use, I've seen ppl mentioning using 2mil & 15mil, should we use alloy or steel spacers in this case?
01-23-2021, 02:01 AM | #236 |
Rep 35
03-07-2021, 04:22 PM | #237 |
Rep 203
I have bought the Lemforder LCA and TS as well as the spacers and the headlight rod. I’m having second thoughts if to go ahead because of the following:
I run 19” M4 wheels with 255/35/19 front tyres - car is lowered in Bilstein dampers and Eibach springs. There is no tyre rubbing at the moment. Will this mod cause my tyres to run? Anyone done the mod with my wheel and tyres setup? Secondly having less thread on the tie rod arm is a concern, is the F8x rod longer? If so would this fit and get around the issue of less thread in the tie rod end? |
03-27-2021, 05:06 PM | #238 | |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
Cheers |
03-27-2021, 05:09 PM | #239 | |
Rep 754
Cheers |
03-27-2021, 08:05 PM | #240 |
Rep 1,148
I see people say m3 TS doesn't correct the caster much; some say it does, I don't mind extra castor, I just don't want to rub, anyone know with just m3 arms, If my 403m 19's with 245 would rub, lower on ST-XA not dumped
05-13-2021, 02:05 PM | #241 |
PsyD
102
Rep 156
Drives: 2016 340i M-sport
So I'm interested in doing something regarding the LCA/TS for my F30. I'm running F80 ZCP springs in rear and Eibach front springs with F80 ZCP bumpstops. I'm also running 437m with a 245/35/19 in front and 275/30/19 in rear. I daily my 340i but love a good mountain run.
I wondered if the F80 LCA/TS would be a good setup for me, but I'm also seeing that it might need a spacer, which wouldn't be good because the 437m already sits pretty flush. I also saw reviews that the Turner monoball solution isn't great for a daily. I'd love to hear any feedback on what you guys think would be the best setup to pursue. |
07-01-2021, 08:57 PM | #242 |
Rep 31
