10-17-2020, 02:58 PM | #68 |
Rep 413
The retrofit harness you bought is fitted with a connector to plug directly into the REM but you have spliced onto the existing indicator cable going to the outer light.
Remove all coding and then just change the bulb type to LED - job done
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
10-17-2020, 03:54 PM | #69 |
Rep 71
Okay I removed all coding & I got the messages rear fog light & reverse light failure. I then coded the bulbs to LED, still not working. But it no longer says those error messages.
10-17-2020, 04:22 PM | #70 | |
Rep 413
I followed this guide and like you was sent short cables that wouldn't reach the F36 REM.
If you have no inner lights at all I would say the harness is faulty. I'd expect some of the lights still to work though if the harness was incorrectly wired. Quote:
10-17-2020, 04:54 PM | #71 |
Rep 71
I'm unsure whether to buy an OEM harness or take it to somebody that knows more than I do.
Can anybody reccomend a specialist that could get this sorted for me? |
10-17-2020, 05:03 PM | #72 |
Rep 3,863
10-18-2020, 02:48 AM | #74 | |
Rep 3,863
I found this pic of cable I replaced , all I did took old one out and fit retrofit cable in , coded then worked Is this how you did you it as well ? Can’t you find someone local who can sort this for you and code ? Where abouts you exaclty see if I can find someone locally to you mate |
10-18-2020, 06:50 AM | #75 |
Rep 71
I never replaced that cable, I still have the pre LCI cable in my car.
I just bought this adapter harness so I could plug the inners in. The instructions said to route the long white wires around to the REM & tap into certain pins but I did what Mick.86uk did from eirlier in this thread & I tapped into the same wires he tapped into, like this... I have read in another thread that a guy who had the same adapter harness couldn't get it to work either, turned out he had a faulty harness adapter, he bought a new replacement LCI loom, coded & it worked. I'm going to phone the dealers on Monday to price up an LCI loom as I think my adapter harness is no good. FortyThirtyFive was kind enough to message me back, he sent me pictures of his set up & looked at my pictures & also said that the harness must be at fault. |
10-18-2020, 06:53 AM | #76 |
Rep 71
That cable on your carpet looks like it just replaced the wires that goes into the white middle plug of the REM?
My wires are tapped into wires on the left & right plug & I've seen another wired into there but I can't find out what wires to tap into. |
10-18-2020, 07:00 AM | #77 | |
Rep 271
See photos below of my posi tap connections on F36.
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
OcTag3n27.50 |
10-18-2020, 07:01 AM | #78 | |
Rep 3,863
Problem with these aftermarket cables are most of times faulty and last thing you need is having faulty cable while you working on the car Yes I would say get refund and order new one , I think I paid £100 or just over for it speak to Elliot at Harry Fairbairen dealership in Scotland, tell you you got his details from F30 forum then he will give you discount no point paying retail prices |
OcTag3n27.50 |
10-18-2020, 07:14 AM | #79 |
Rep 71
10-18-2020, 07:21 AM | #80 |
Rep 271
Yours looks correct, not sure why you aren't getting any of the inner lights working on both sides?
Are the harness plugs pushed in all the way? If both harness are faulty I would cut the indicator wires near to the adaptors and send them back for replacements and just rejoin the indicator wires to the new harness adaptors.
10-18-2020, 07:22 AM | #81 | |
Rep 71
UKF302524.00 |
10-18-2020, 07:26 AM | #82 | |
Rep 71
10-18-2020, 07:30 AM | #83 | |
Rep 3,863
Sounds about right but it’s lot of work involved when you fit OEM harness , you will literally have to take full tailgate trims off and remove wire harness I will try to find old pics and share later today mate |
10-18-2020, 07:36 AM | #84 | |
Rep 71
How far down does the headliner have to come down? I only needed to pull it down a bit so I could tuck the white wires under & thread through the rubber boots. |
10-19-2020, 02:37 AM | #85 |
Rep 71
UKF30 When you ordered the OEM loom, did it replace & plug into where the white centre plug goes on the REM, leaving the black plugs on the left & right of the REM intact?
10-19-2020, 04:05 AM | #86 | |
Rep 3,863
For life of me I can’t remember shit it was two years ago lol |
10-20-2020, 04:51 AM | #87 |
Rep 71
New loom in. No coding. The inners power up! Yes! No indicators though, so...
Re-coded everything to the T again from the coding provided by UKF30 (thanks again for that) as it was coding that made everything work properly. Everything working perfect now = happy days! Now I need to recoupe some money back for this crap ebay harness but overall I'm chuffed to bits now it all finally works. Thanks to everyone who helped. |
UKF302524.00 |
10-20-2020, 06:14 AM | #88 | |
Rep 3,863
Mate that’s very good news I was going to ask today if all worked Glad it’s all sorted so shall I PM you my address for cheque Share pic if your car if you can mate |
OcTag3n27.50 |
