07-13-2020, 10:51 AM | #155 |
BMW CCA Member
488
Rep 808
kern417 - thank you for your input. No measurements from before. Stock was a funky -.08 and -1.01 with stock hats.
I'm waiting on the new strut bearing and rubber boot to do a reinstall (hoping to fix that low rattle/knock) and then do an alignment. |
08-22-2020, 02:27 AM | #157 |
BMW CCA Member
488
Rep 808
Checking back in. I pulled the Millway camber plates to chase down a low-speed rattle around town... I have been running the stock mounts the last month. Yes, all is quiet now but my tires are rubbing the fender wells again. Whee!
I recently did the steering rack repair and got rid of the dreaded F30 clunk! (Pretty stoked about that still. The steering feels like new.) But it got me thinking, the steering rack uses a tan, plastic block... easily 4oz of weight. The clunking noise issue with a lot of stock F30s is that block rattling around inside of the steering rack. Some Millway owner's say there's some noise (NVH, rattle, etc.) around town... and other's who claim it's as quiet as OEM. How many of you have swapped out that steering rack piece? How many have not? And is there a noise or rattle present with the camber plate install? Oddly when I ran the Millway Race and Poly versions, they both made a similar rattle at low speed, which makes me wonder if my rattle was actually that steering column block. I still have the Millway plates and will probably reinstall to test the idea/theory. And yes, clearly the stock rubber mount hide a multitude of noises! |
08-24-2020, 06:41 AM | #158 | |
Cheapskate
4447
Rep 4,993
exE36M3487.50 |
08-24-2020, 11:42 AM | #159 | |
BMW CCA Member
488
Rep 808
I should be under my car this week and will report back my findings. I'm waiting on those stupid fires out here in NorCal to calm down so I can open my garage and get the work done. |
08-24-2020, 10:48 PM | #160 |
Rep 681
I had about 68k miles or so when I sold mine. I had some clunking from the rack but my bearings also needed replacing in my top mount. There was a significant amount of play in them.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
exE36M3487.50 |
09-19-2020, 12:56 AM | #161 |
BMW CCA Member
488
Rep 808
OK just checking in. I was hunting down a rattle and theorized that the clunking was from the known steering rack clunk and knock.... and thus transmitting noise through the camber plate. Well I replaced the steering rack block... still getting low speed knocks/rattling from the camber plate.
But overall, I'm still pretty happy with these camber plates. The rattle is of a frequency that you have to have the radio off, no air/fan, and windows up and doing less than 25mph around town with bad roads to even hear it. If you freeway it 90% of the time, have great roads, and use the radio/HVAC... you won't notice the rattle as much. |
09-19-2020, 02:06 AM | #162 | |
Rep 1,291
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-19-2020, 09:34 AM | #163 | |
Rep 271
Just got my rack fix kit because mines gone too. Also my front control arms are leaking bad. So maybe check those too, I can see where the outer edge of my drivers side one has come into contact with the subframe. |
09-19-2020, 03:12 PM | #164 |
BMW CCA Member
488
Rep 808
Strut nut...
I torqued it down with the proper tools I only wish this was the rattle. Control arm has been replaced less than 10K miles ago. Steering rack bolts might be an idea. I'll check that next time I am under the car. |
09-19-2020, 06:07 PM | #165 |
Rep 891
I finally am going to be able to install the steering thrust repair kit to my car tomorrow. I'll take a look at the bolts mentioned above while I am under there. Thanks for the tip.
Edit: Repair kit DOES NOT fit earlier racks with the 17mm bolt, the top nut in the repair kit is a few mm more in diameter.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
exE36M3487.50 |
09-21-2020, 02:31 PM | #167 |
BMW CCA Member
488
Rep 808
Yep, sway end links and mounts are all tight. So I was doing some reading... how about this one!
"Ball joint for the front tension strut, bolted directly to the wheel carrier/steering knuckle A loose or worn ball joint can cause a lot of strange problems including knocking noises, tire wear, and poor handling. A ball joint can wear out in numerous ways. The most common type of ball joint wear is when the ball joint itself wears in its housing and a gap develops. This causes play and can create looseness in the front suspension." I'm at 66k miles. They say these guys last 70k to 100k. But I don't recall ANYONE replacing a ball joint. This could explain the disparity of people with properly torqued suspension components - with some with no camber rattle and some with the rattle. At $150 for a new pair, tempting to give it a try. Last edited by exE36M3; 09-21-2020 at 03:58 PM.. |
09-21-2020, 02:37 PM | #168 | |
Rep 3,539
exE36M3487.50 |
10-12-2020, 01:30 PM | #169 |
BMW CCA Member
488
Rep 808
kern417 - so I found a guy with Millways on his 435i with 86k miles. He claims zero chatter. Same set-up as my suspension with one exception, he's still on stock control arms while I am on the monoballs. Are you still on all stock suspension save the Millway camber plates?
UPDATE: Local race shop retorqued all suspension components. Nothing loose or worn. |
10-12-2020, 01:46 PM | #170 | |
Rep 3,539
10-12-2020, 02:42 PM | #172 |
Cheapskate
4447
Rep 4,993
haha yeah, i have the spl arms now and still no rattles. but it wouldn't hurt to swap and see if it goes away.
10-14-2020, 01:33 AM | #174 |
Rep 9
Hey guys, anyone in here uses the Millway camber plate with Ohilns R&T coilovers? I found out the the strut nut for Ohlins is 21mm which is bigger than the OEM and other coilovers at 18 mm. I couldn't find the strut nut socket that is thin enough to tight the nut down. Anyone faces the same issue? Thanks!
10-14-2020, 03:54 AM | #175 | |
Rep 1,291
10-26-2020, 09:56 AM | #176 | |
Rep 271
Threw my phone under the car and recorded video, the bracket that holds the brake line was clicking against the bracket that holds the brake sensor in the chassis. Maybe yours was rubbing too and started a rattle. Video: http://https://youtu.be/ovwrIEbnTNw Last edited by blumagic; 10-26-2020 at 10:02 AM.. |
