01-26-2021, 12:44 AM | #1 |
Rep 18
Is It Possible (At All) To Do An LED/HID Conversion in a "Post-LCI" F30?
So my car was a dealer demo. It's been great, perfect, the best car I've ever driven.
But it also has, bar none, the worst headlights of any car I've ever driven. They are measurably worse than a 1991 Mazda Protege I used to own. Had I known they were this bad, I literally would have purchased another vehicle with HIDs from the factory. I had no idea going back to halogens would be so dramatic, especially since I have family members with BMWs that have decent halogen lights. Here's my problem: three mechanics, including a BMW custom shop, told me that absolutely NO LED bulbs (yes, including H7 bulbs that, according to headlight websites, are fine) will fit in my 2016 320i xDrive because it's a post-LCI vehicle and there is no physical room for the bulbs with the heat sink and wider end at the connector. I was willing to buy the DEPO light assembly, no matter the cost, but it turns out that is only for "pre-LCI" vehicles as well. Is there ANYTHING I can do about this? I absolutely love this car but the lights are horrendous, to say the least. It stuns me that they're even making $43,000 cars with halogen lights to begin with, especially when my old Land Rover from 2008 had HIDs standard. But that is beside the point. I have driving to do, and I'd rather not crash. Any advice would be appreciated, aside from trading it in for a new car. Last edited by TurboDan737; 01-26-2021 at 12:57 AM.. |
01-26-2021, 05:39 AM | #2 |
Rep 356
Buy oem headlights and have em coded in. I know it’s possible to retrofit. Might not be cheap though.
2016 340i | M-Sport | Mineral Grey | Coral Red | Bone Stock
01-26-2021, 07:01 AM | #3 |
Rep 844
Couple threads on this recently, a quick search will help you out. It is possible. Worth it? Depends who you ask. You also might want to check the focus of your headlights before you full out swap them. When I got my 2016 340 i had the same problem as you. Headlights were god awful. When I checked their focus they were WAY OFF. Once I got the lights properly focused it was a night and day difference, no pun intended lol
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
01-26-2021, 07:52 AM | #4 |
Rep 327
I have LCI LEDs that only auto aim and I too had to adjust them when I first took delivery. The intensity was there, but they were aimed a bit too low and not casting far enough. I think they are excellent now.
Tangentially related, and I think I know the answer, but anybody know if I can simply install Icon Adaptive LEDs without needing the additional fancy camera integration? I don't care for auto high beam or the anti dazzle feature but I do wish for steering angle swiveling in corners as I have on our other cars. Was wondering if I could simply plug & play + coding for just that portion and call it a day. OP, I think perhaps you could at least get by with installing the standard LCI LEDs? Coding will be necessary & probably a harness modification from halogens, but I don't think you would need an external cameras (someone feel free to correct me). I spent most of the 2010s obsessing over xenon projectors so I get your pain. Last edited by jnj2455; 01-26-2021 at 08:15 AM.. |
01-26-2021, 07:55 AM | #5 |
Rep 356
I raised my 340 headlights about 2 turns each and they are much better now. Whenever I drive my wife’s edge with halogens I have to check that the headlights are on... they are that bad.
01-26-2021, 10:06 PM | #6 | |
Rep 18
I'm resigning myself to selecting a better halogen bulb (Osram?) and living with it for the next 7-8 years that I have the car and praying along the way that they come out with new DEPO assemblies or equivalent to fit the LCI models. The worst part is that, as much as I'd like the lights to look nicer, that really isn't the issue. They're genuinely the worst headlights I've ever had. It amazes me that they made this beautiful car (with full LED rear lights, FWIW) and stuck headlights from a 1980s minivan in there. Last edited by TurboDan737; 01-26-2021 at 10:25 PM.. |
01-27-2021, 10:31 AM | #8 |
Rep 216
Adjust your headlights. When I bought my 2016 340i it was incredible how bad the lights were. I found a wall in an empty parking lot and had to adjust mine about 3 turns up and 1/2 turn out each to get them to where the should be. Once adjusted they're amazing. It blows my mind how BMW doesn't adjust the lights from factory cause they're not even close. My fog lights went further down the road than my headlights did.
My high beams were worse than my 97 540i low beams. Not anymore though, they're amazing lights when adjusted properly. Edit: I thought you had LED headlights, I can't read apparently and skipped over where you said halogen lights. I thought LED were standard on the LCI models or is it just the 340i that they're standard? |
01-27-2021, 11:54 AM | #9 | |
Rep 1,508
01-27-2021, 12:11 PM | #10 |
Rep 895
LED is also standard on LCI F32/33/36 (US market)
01-27-2021, 01:21 PM | #12 |
I want to drive a Zamboni
1128
Rep 5,556
Drives: 13 E93 M3 18 F80 M3 16 K71
Are you referring to LED or adaptive version? The adaptive requires additional module's in order to make it headlight's swivel when steering wheel is turning. Not a cheap solution better off when order the car with this option rather than upgrade at a later time.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
01-27-2021, 03:15 PM | #13 |
Rep 18
I've been wondering the same thing. I'm going to contact Kies Motorsport, which seems to be their primary retailer (I also have a connection with someone who works there) and see what the deal is. Will report back.
01-27-2021, 11:40 PM | #15 | |
Rep 18
That's actually how this all began – a simple attempt to replace the (terrible) halogen bulbs that came with the car. Then I discovered that all H7 bulbs do not necessarily fit in these cars. |
01-28-2021, 06:20 AM | #16 |
Rep 216
I've seen ones on the dealer lot that desperately needed to be adjusted. Someone at BMW isn't doing their job if that's the case
01-28-2021, 07:01 PM | #17 |
Rep 18
That seems like an issue at the assembly point. My F30 was produced in South Africa. My X3 is from South Carolina. Volkswagen once had horrendous quality control issues with their assembly facilities in Mexico – I hope BMW is keeping better tabs on their international network.
01-28-2021, 07:29 PM | #18 |
Rep 1,058
You buy led headlights + modules (look for oem) and a halogen to led harness (people make them on eBay). Code in your led lights and you should be good to go.
This thread should help greatly. https://f30.bimmerpost.com/forums/sh....php?t=1141545 https://f80.bimmerpost.com/forums/at...8;d=1490600365
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block |
01-29-2021, 12:43 AM | #19 | |
Rep 18
01-29-2021, 07:53 AM | #20 | ||
Rep 1,058
You could also go bayoptiks and this route: https://bayoptiks.com/products/f30-h...complete-units
01-29-2021, 08:09 AM | #21 |
Rep 500
Do you have fog lights? It's not the same for sure(!) but better bulbs there might give you better visibility? You can code them to be on with the headlights so you don't have to do anything extra.
01-29-2021, 03:25 PM | #22 |
Rep 4,876
OP, I'd SERIOUSLY advise you to try the LED's at night before going down this route. They look sexy from the front of the car, but light output is BRUTAL!!!
I didn't realize why everyone was complaining so much until I took a job that made me drive a 2-lane highway in the country at night. Going to low beams you are just blind. ZERO range. |
