BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > LL-04 or the new LL-12 for my oil change
      04-01-2022, 05:14 AM   #45
Nrodriguez
Switzerland
Drives: F31 330 xd
Always used ll04 no problem at all
POBEP365.50
      10-13-2022, 11:12 AM   #46
tru-jack
Drives: 2016 328d touring m sport
POBEP and andreigbs
The PP Euro LX 0w-30 is available locally to me for great price, and with Canadian winter coming, it seems like the ideal choice, however, it doesn't list BMW LL-? on the bottle. is it still ok to use? thanks
POBEP365.50
      10-13-2022, 07:23 PM   #47
POBEP
POBEP's Avatar
Drives: E70 E90 E91
Originally Posted by tru-jack View Post
POBEP and andreigbs
Yes - should be perfectly fine.
It does not have BMW LL- approval, but appears to be much better choice than BMW TPT LL-12FE anyways. Relevant MB, Porche and VW approvals are there, GTL based, German made.
I went with TPT LL-04 for my X3d as it rarely sees temps below 0C (360 days a year above 10C). Previously on TPT LL-12FE it had turbine noises and questionable UOA results.
When my excessive TPT LL-04 stock runs out I'll switch to PP Euro LX 0w-30 for X3d and PP Euro L 5w-30 for 335d & x5d
      12-05-2022, 11:07 AM   #48
ssf556
ssf556's Avatar
38
Drives: 2018 328d
Valvoline 0w30 per the back of the bottle is recommended for LL-01, LL04, LL12FE.
Comes out to $8.16 a bottle.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Delivery estimated at the end of January, I ordered 2 boxes.
2018 328d
      12-07-2022, 12:46 PM   #49
POBEP
POBEP's Avatar
Drives: E70 E90 E91
It does not concern you that:
- it has no single BMW approval (recommended != approved)
AND
- covers 3 different BMW certifications in the same bottle?
ssf55638.00
      12-07-2022, 02:13 PM   #50
ssf556
ssf556's Avatar
38
Drives: 2018 328d
AND
Not at all...I have been in the diesel commercial business for 25 years and recommending, approving or endorsing or not taken lightly in the oil business. As you know this is a topic that is discussed ad nauseam on the internets.
Just look up the wording from some of the Big Commercial diesel engine manufactures, you will see all 3. Even then an oil that is on an Approved or Recommended list still has an asterisk by it. The oil manufacturer submits data to a company like Detroit Diesel and based on that Detroit Diesel will add that oil to their "approved" list. It is actually the responsibility of the oil manufacture to make sure the oil works. Just like Detroit Diesel, BMW has not "tested" all of their approved or recommended oils in their engines. It is really sort of a game at the end of the day.
Again the use of LL01, 04 and 12 in this situation apply to diesel engines. I do know that there is some concern with these oils on gas powered vehicles.
I am curious to see what is actually on the bottle when I receive it. I will let you know.
It also checks the MB229.51, VW 507 and Porsche c30 spec boxes as well. Maybe too good to be true?
https://sharena21.springcm.com/Publi...0-48df3793b338
2018 328d
POBEP365.50
      12-07-2022, 10:54 PM   #51
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
N
The 5W-30 flavor of this oil (Valvoline European Vehicle Full Synthetic XL-III) is on BMW's list of approved oils.
That said, if it's officially approved as VW 507.00 spec, then that should be good enough. It's a low-SAPS/low-ash spec for VW TDIs. There are few N47's on this forum using a that spec of oil. In fact, the HTHS specs for both LL-04 and 507.00 are the same at 3.5 cP minimum.
POBEP365.50
      12-08-2022, 12:30 AM   #52
POBEP
POBEP's Avatar
Drives: E70 E90 E91
Thanks, I agree.
(Also muting approved/recommended marketing topic)
- I do not believe that LL01 is fine for diesel with DPF
- LL04 works for both diesel (M57 & N47/N57) and gasoline (ULSG) (N51/N52/N53/N54/N54/N20/N26)
- LL12FE is officially 2016MY+ for N47
- VW 507.00 is close or better than LL04
Hence, using above scale, yes the above Valvoline should work where LL12/LL04/LL01 is appropriate.
I'd like to see UOA report (new and, maybe 8,000mi run) on N47
My N47 UOA results came far better after switch from LL12FE to LL04
ssf55638.00
      01-06-2023, 01:38 PM   #53
happyhippo
Poland
Drives: BMW F30 LCI
I am using ll04 in eu region and engine is in perfect condition after 100k miles. I would stay with Bmw recommendations, just change it more often
POBEP365.50
      01-13-2023, 07:43 PM   #54
ssf556
ssf556's Avatar
38
Drives: 2018 328d
Received the Valvoline Oil...confirmed the bottle says LL01 - LL012
2018 328d
      02-01-2023, 03:02 AM   #55
Tommo3
Drives: 2018 F31 318d
Originally Posted by mafatbhai View Post
You should be good. 0W30 means its good for 0 to 30 deg C weather.
5W30 means its good for 5 deg c to 30 deg C weather.
it all relates to viscosity of oil at that temp. and all this FE or fuel efficiency means oil has to be less viscous (Ford drove that requirement).. Now since oil is less viscous, it flows better at 0 deg C. Hence they changed it to 0w30 to get some more brownie marketing points.
What a load of rubbish you write. The viscosity is not a temperature.
