08-31-2017, 02:09 PM | #23 |
Rep 6,783
These 18x8.5 ET38 ARC-8 wheels fit the F30 perfectly.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
09-25-2017, 03:21 PM | #25 |
Rep 6,783
Thanks for the message! For the F30 we recommend the 17x9" ET42 with 245/45-18 tires as a square setup.
Here are some photos: Hope this helps! Let us know if you have any additional questions.
09-25-2017, 05:08 PM | #27 | |
Rep 6,783
Since you have the wheels already though, it would be worth a quick test-fit to be sure! For example, here's another photo of 8.5" ET35 wheels. the 9" ET30 would stick out 11mm further than this setup: Hope this helps! Let me know if you have any additional questions.
12-11-2017, 02:34 PM | #28 |
Rep 6,783
TIRES NOW AVAILABLE
Add tires to your ARC-8 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
04-26-2018, 09:30 PM | #29 |
Rep 232
I want to run a 18x9 Setup? Is this possible on F30? What spec's/tire size would be best.
2013 Jet Black Sport Line 328i: H&R Springs, 12 & 18mm Spacers, 335i Exhaust conversion.
04-27-2018, 02:20 PM | #30 |
Rep 6,783
Thanks for the post! We recommend the 18x9" ET42 with 245/40-18 tires as a direct fit with no spacers or modifications required.
05-14-2018, 01:10 PM | #31 |
Rep 6,783
Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
07-09-2018, 09:16 AM | #33 | |
Rep 465
What is the choice for the widest 18 inch staggert set up for 340i with the stock ride height and -3.2 Front/2.0 Rear negative camber? Thanks
"Racing is life. Anything before or after is just waiting." Steve MCQueen
07-09-2018, 01:14 PM | #34 | |
Rep 2,650
We have had a ton of success running our old M-Sport F30 on track with this 245 width 9" square setup Due to the fender clearances on the F30, we would recommend the following staggered fitment for this chassis: 18" Staggered: Front: 18x8.5" ET35 - 235/40-18 Rear: 18x9.5" ET43 - 255/40-18 Best, Max
07-09-2018, 04:12 PM | #35 | |
Rep 465
Don't you think that with negative camber I mentioned in my previous post with lower aspect ratio, 255/35 not 40 and 265/35 will fit this car with the stock ride height?
07-10-2018, 12:08 AM | #36 |
Rep 2
Just purchased a F30 335i M Sport Xdrive, was wondering how wide of a square tire/wheel combo could be ran with the 18x9 et30 ARC 8's or if the 18x8.5 et38's would be a better choice; and if so, how wide of a tire could be ran without fitment issues?
07-10-2018, 11:54 AM | #37 | ||
Rep 6,783
--Dylan
Datka450.00 |
08-28-2018, 06:33 PM | #38 | |
Go Fast Dont Die!
407
Rep 472
Drives: '12 328i Sport 6MT
and math is based off my 397 wheels at 18x8 ET34 I love the concave ARC-8 Last edited by FastActionJax; 08-28-2018 at 06:49 PM.. |
08-29-2018, 01:22 PM | #39 |
Go Fast Dont Die!
407
Rep 472
mMm lets see
08-29-2018, 01:53 PM | #40 | |
Rep 6,783
If that's the case, this looks like a pretty solid fitment for the F30 platform, as long as narrower 245 tires are used up front. Because it's such an aggressive fitment up front, we suggest being prepared to add camber plates to prevent any possible rubbing if necessary, and to just be aware that some tires run a bit wider than others. Aside from that, be sure to post some photos when you get them mounted! --Dylan
08-29-2018, 03:47 PM | #41 | |
Go Fast Dont Die!
407
Rep 472
09-24-2018, 02:13 PM | #43 | |
Rep 6,783
--Dylan
yoandry695.50 |
09-24-2018, 08:24 PM | #44 |
Rep 2,077
What about just a rear set?
