06-16-2020, 05:13 PM | #1 |
Rep 540
Hello,
I'm trying to add a back up camera with wireless kit purchased from avin to my andream CarPlay system. I've got the wiring of the transmitter and camera in the trunk done and I believe everything is correct because the transmitter turns on when in reverse. I connected the receiver to the andream but I nothing happens when in reverse. I tried to hard wire it as well bypassing the wireless transmitter and receiver, but still nothing. My car is manual and I think I'm missing something but I'm not quite sure what. Any help would be appreciated. |
06-17-2020, 08:31 AM | #2 |
Rep 843
You need to connect the yellow wire, to the blue wire on the transmitter.
Plug in the rca to the back rca on the andream loom. Then in the settings on the MMI, go into reverse select aftermarket and then turn off line detect. |
06-17-2020, 11:49 AM | #3 |
Rep 540
This what I did: connected yellow wire to blue wire on receiver. Nothing happens. System works when tested with a TV. Rear camera is displayed on tv when put in reverse
06-17-2020, 02:29 PM | #7 |
Rep 540
06-19-2020, 06:49 AM | #10 |
Rep 540
I'm confused about the purpose of connecting the 12v reverse (yellow wire) to the blue receiver wire. When I put the car in reverse, I'm measuring a voltage drop from 9v to 5v on the blue wire. Wouldn't this work as a trigger to tell the unit to switch to the camera display by connecting it to the purple wire?
Now I tried making that connection, but I think it's not working because maybe purple wire needs to register a 12v signal. Any thoughts? |
11-28-2020, 06:11 PM | #12 |
Rep 540
The connections were made correctly. The issue was resolved with updating the Andream unit
lateapex'er123.00 |
11-28-2020, 06:41 PM | #13 |
Rep 286
11-28-2020, 06:43 PM | #14 |
Rep 540
I did end up ditching the wireless transmitter and just ran the wires straight. But it did work with the wireless transmitter. What settings do you have on your andream?
11-28-2020, 07:48 PM | #15 | |
Rep 286
UPDATE: MCU update solved the problem! Thanks! |
10-17-2021, 01:35 PM | #16 |
Rep 2
Andream reverse retrofit
Hi, I am having difficulties connecting my andream reverse camera retrofit and have read in here that sometimes it that you need to upgrade the software or firmware. Can someone tell me how to do that ?
10-17-2021, 01:37 PM | #17 |
Rep 2
