BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
      10-14-2018, 05:49 AM   #177
haris_k
Drives: mg F30 328i
So my install is finally finished (thanks a lot to everyone's contribution in this thread) but with some glitches.
I mounted the control module in the trunk temporarily since I am still wating delivery of the bracket to put it in the oem position.
I VO coded 2VB and got RDC error when starting the car.
I then used rheingold to clear the fault memory and performed initialization.
Few minutes drive and my tire pressures and temps were showing in the CIC screen.
Now starts the fun.
Got back home, happy for my achievement.
Next day I start the car, and I get the same RDC error in the combi and CIC screen and it would not display the pressures, neither initialize the reset procedure through idrive.
I connect my laptop, start rheingold, clear the fault codes and initialize the RDC controller again and all my pressures come back to the screen looking all normal.
I even tried to switch off the car for a few minutes, lock it and restart it and it seemed fine. It would not lose the tpms.
The car was parked for a few hours and when I went back to drive it, boom the RDC error again.
This thing is driving me nuts.
Anyone got a clue why this is happening? Or could I be missing something in the coding process?
Thanks in advance for your help.
      10-23-2018, 01:47 AM   #178
haris_k
Drives: mg F30 328i
Hey there.
I checked with ISTA-D once more regarding the logged errors.
To my understanding, it seems that the unit cannot be coded due to it being a second hand unit which has already been paired with another vehicle.
If the above is correct, is there any way to reset the unit or do I have to buy another one?
As a reminder, after clearing the errors in ISTA+ I can see pressures and temperatures in my CIC screen.
      10-23-2018, 06:37 AM   #179
atzebmw
Drives: Tesla Model 3
Originally Posted by haris_k View Post
I VO coded 2VB
Did you also code the RDC ecu?
No, not correct.
The ecu can be coded.
      10-25-2018, 12:33 AM   #180
haris_k
Drives: mg F30 328i
Yes the RDC ecu was also coded after adding 2vb to the VO.
Apparently I am doing something wrong coding, though I cannot understand what that is.
Do you think you can guide me through?
      10-25-2018, 06:15 AM   #181
atzebmw
I think you did everything right.
If you mark the RDC ecu and push the button "Code" (not FDL code) the ecu will be coded refering to the loaded VO.
But one more question.
Does the RDC ecu have a CAFD with a green dot or hook?
      11-16-2018, 02:25 PM   #182
Apples12
Drives: 520D LCI auto
Hi
I retrofitted successfully but when I changed to winter wheels which had sensors which were working in an f10 it stopped showing the correct pressure and temp
In ista my rdc doesn’t have the cafd line
How do I inject cafd?
      11-16-2018, 02:54 PM   #183
atzebmw
Originally Posted by Apples12 View Post
Hi
Mark the ecu and then „Detect CAF für SWE“.
      11-17-2018, 08:39 AM   #184
Apples12
Hi
I do this and then it brings up a long list of files/folders
Do I have to match this my istep or just select the newest/closest one?
This should work for all modules which haven't got a cafd right?
I retrofitted reverse module too but no coding parameters available as no cafd
Thanks
      11-17-2018, 09:42 AM   #185
atzebmw
Hi
Thanks
Choose the newest or the best match to your i-step.
It doesn‘t matter.
And yes, this should work for all modules.
But think of that not all modules got a cafd.
      11-18-2018, 01:01 PM   #186
Apples12
It doesn‘t matter.
Thank you thank you thank you!
All sorted, cafd injected, Tpms working correctly
      11-27-2018, 05:19 AM   #187
Davef30hull
Drives: 2013 F30 msport
Just a quick one regarding the part numbers. I have the control unit 6876227 and now looking for the sensors 6856227 but there seem to be variations of this part ie 6856227-01, 6856227-02, 6856227-03, 6856227-04.
Is there any difference? Does it matter which one I choose?
      11-27-2018, 12:12 PM   #188
atzebmw
No, that doens't matter.
-04 is a little bit newer revision than -03, but it's no problem.
      12-04-2018, 08:10 AM   #189
TeaAndBiscuits
Drives: 325D F30 M SPORT
Ordered mine - will fit to the can bus wires under iDrive controller as someone mentioned earlier in this thread, so I don't need to touch the FEM as it's a pain accessing that.
Will mount the control unit in the tyre-well area in the boot, hopefully that is far back enough to get the correct signals transmitted, that said, I guess I need to figure out a way of getting the wires to the boot lol!
      12-14-2018, 11:00 AM   #190
TeaAndBiscuits
Does anyone know if control unit RDC 36 10 6881474 is compatible with 6856227 Sensors?
(I have F30)
      12-18-2018, 06:49 AM   #191
haris_k
Drives: mg F30 328i
atzebmw
Thanks for your message. There is no CAFD in my RDC ecu.
Could you please guide me on how to inject it? I already have the latest esys and psdzdata installed.
Thank you.
      01-03-2019, 09:08 AM   #192
Davef30hull
atzebmw
Thank you.
atzebmw
Thank you.
I have the same problem RDC ecu is showing but with no cafd to inject. When I select detect caf for swe I get the following error! Anyone know what this is about?
      01-03-2019, 11:30 AM   #193
atzebmw
The problem appears when the ecu is from another car series.
Do you know from which car series it is?
      01-03-2019, 11:31 AM   #194
Davef30hull
Alas no I don't. The ecu and the sensors both end in 227 and were working very breifly
      01-03-2019, 01:49 PM   #195
atzebmw
The ...227 should come from an F10.
So you can try the following:
Start E-Sys and connect your car as an F10.
Then the usual read FA and read VCM.
After that mark the RDC ecu and try to "detect caf for swe".
If it works without errors choose a CAFD and hit OK.
BUT NOW DON'T CODE THE ECU!!!
Don't close E-Sys but disconnect the connection.
Connect again as your car series.
and again read FA and VCM.
The RDC should now still have the assigned CAFD.
Now only code the RDC ecu with the assigned CAFD.
If that doesn't work you also can flash the RDC ecu and after that you should also be able to assign a CAFD.
I hope that was understandable.
      01-03-2019, 02:36 PM   #196
deneyer
Belgium
35
Is it normal that i cant code or inject a CAFD in my RDC module?
If i clcik inject CAFD i get error
No CAFD-mapping for base variant RDC found [G090]
      01-03-2019, 03:02 PM   #197
atzebmw
No, not normal.
Maybe you also can try to flash the ecu.
      01-03-2019, 03:14 PM   #198
deneyer
Belgium
35
No, not normal.
Its the part number for an f34 (usa build) cause didn't found a europe version łaybe thats the problem
no idea on how to do that and i also have the light version of pdsz and not the full
