06-29-2022, 11:14 AM | #1 |
Rep 68
My car is a 2013 328i xDrive M Sport. Do KW Street Comfort offer the highest ride height of any other coilovers at their highest setting? Are their any other brands that offer a higher maximum ride height? I am looking to buy some coilovers. I get a lot of snow where I live in the winter (I live 1 mile away from the base of a ski area) and would like to set them as high as possible for 3-4 months every year.
06-30-2022, 09:13 PM | #2 |
Rep 1,934
Bilstein has a streetKomfort version as well.
The other basically stock height coilover is ohlins RT. They have an xdrive version now too.
06-30-2022, 10:48 PM | #3 |
Rep 68
07-25-2022, 11:59 AM | #4 |
Rep 310
What did you end up finding / going with?
I'm due to replace my shocks/struts and also live in a high snow area. The car is unstoppable on the snow/ice, until the snow level gets too high, getting an extra inch or two of ground clearance would be huge. |
07-25-2022, 03:43 PM | #5 | |
Rep 68
At this point I think I'm going to go through one more winter at stock xdrive height. I bought a set of summer rims about a year ago and they have just been sitting in storage. I thought I was going to be able to buy some tires and dial in a set of coilovers before the summer got too far along but it dosen't seem worth it at this point. I'll probably wait till next spring to get it all sorted out and just slowly buy the tires and a set of coilovers over the winter. Even though I do get a significant amount of snow where I am, my commute is non-existent because I live directly above the shop I work at. And the mountain I go snowboarding at is a 15 minute walk. With this in mind I have also considered the (somewhat taboo) route of just buying springs and continuing to use my adaptive shocks. |
07-25-2022, 04:33 PM | #6 | |
Rep 5,392
You should contact KW and other coilover manufacturers and discuss with them. I did an experiment with my 2015 335i XDrive a few years ago with some snow drifts before the plows arrived. My car is lowered in front by 0.8" with Eibach springs. I drove straight into snow drifts until the car got stuck and then measured the snow height. It could handle up to 6" of unplowed snow despite being lowered. It's not really a concern for me because I live in suburban NJ so it's not likely that I would be driving in unplowed snow higher than 6". When it snows more than that no one drives. Note: Besides possibly gaining height from your suspension choice, you can also gain clearance height through your winter tire size selection. For example, say you went with a Blizzak WS-90 tire which is great in heavy snow. The stock 225/45-18 tire is 25.9" in diameter. But if you choose a 225/50-18, that is 26.9" in diameter. It maintains the thin tread width to cut through the snow (rather than hydroplane on top of it) but the higher sidewall actually raises the car by 1/2" and it cuts a 1/2" of tire/fender gap for appearance. So you gain 1/2" of clearance under the car. Hope this helps! |
Kirby8677.50 |
07-25-2022, 04:53 PM | #7 | |
Rep 68
In the summer I plan on running 20x9 ET35 square with 245/35zr20 tires. I really want to fix the reverse rake and remaining fender gap by lowering very slightly. 05-22 Eibachs would solve this perfectly. However I would be stuck at that height all winter. If I could find coilovers that would only lower the back by 0.6 inches from stock xdrive height and slightly more in the front like 1.2-1.4 inches that would be ideal. Hence, why I am wondering the highest (rear) ride height of any coilover available for xdrive F30's. |
07-25-2022, 05:19 PM | #8 | ||
Rep 5,392
Kirby8677.50 |
07-25-2022, 09:07 PM | #9 | |
Rep 68
07-26-2022, 05:31 AM | #10 | |
Rep 2,048
Anyway, with modern tyres they're designed to sit on the surface and compress the snow to bond to it with all the sipes but there's clearly a point where this becomes less helpful. It would be interesting to see some testing to determine the ideal width for a tyre at given loads, that way you could actually determine the best performing tyre size for your car. |
07-26-2022, 10:00 AM | #11 | ||
Rep 5,392
Snow in the Northeast US is damp. Skiing can be quite frightening since it's pretty much skiing on ice and hurts like hell when you fall. Smacking the ice hip first is the worst. Major bruises. You learn quickly to ski with your weight more forward and dig your edges sharply into the ice surface to have any control. Snow in the western US is totally different. Lack of humidity creates a wonderful soft powder. Skied Lake Tahoe, Squaw Valley, etc once. It was such a joy to ski without knuckle whitening fear. Falling was like being a kid playing in the snow again. Learned quick to ski with my weight back to keep tips up and avoid catching them in the snow. Funny story. In the afternoon shade fell on this one small slope at Squaw Valley and made it icy. It was really just a 90 degree right turn, a 30 yard down slope and then a 90 degree left turn. But it was dangerous to fly out of bounds. Well it brought out a giant portion of the ski patrol. Folks who grew up on western powder had no clue how to not kill themselves on ice. The ski patrol set up a line to teach each person in order what to do. The folks in my group were all veterans of icy slopes in NY State and Vermont so we just breezed through in a few seconds. Felt bad for those feeling that icy terror for the first time. Alohasurftoad has posted some things about the relationship between wheel width and tread width. Ideally for best handling, tread width should be same as or within 0.5" less than wheel width. That's where the TireRack measured values can be important. There's an automatic tendency for guys to think that the widest wheel is always best. But that often stretches the tire leaving the expensive wheel rim unprotected. And it can mean choosing a tire size with less than ideal performance. So the best method is often to choose tire model and size first, then determine the ideal wheel width and offset. |
Kirby8677.50 alohasurftoad3078.00 |
07-29-2022, 09:58 AM | #12 | |
Rep 10,256
07-29-2022, 10:39 AM | #13 | ||
Rep 5,392
07-29-2022, 11:32 AM | #14 | |
Rep 10,256
The suspension behavior can be best described as slightly stiffer than stock, little or no body roll, with the small road imperfections absorbed with confidence while maintaining comfortable ride. Larger road imperfections produced a more noticeable / jarring response in the suspension which I over time began to ignore - not much could be done about it. KW V3 coilovers offer independently adjustable rebound and compression controls. I would select KW V3 coilovers to tune a more responsive compression cycle but the lowering range was more than I was willing to accept since the OEM suspension height has been the original goal. |
07-29-2022, 11:58 AM | #15 |
Rep 4,327
i've read one option is to do springs only with adaptive? if so, consider eibach 4-22 which is 0.8" front, 0.6" rear. it is the least low spring drop but still enough to get rid of the hideous x-drive gap. it also fixes the reverse rake. pair this with f80 bumpstops if going this route.
https://eibach.com/us/1948/E10-20-03...xDrive-pro-kit another reason for eibach 4-22. for next summer, since you are planning 245/35/20 which is 26.8" tall, compared to oem(26.0") the wheel gap will reduce 0.4" just due to tire diameter by itself, so you need not lower it as much to tighten the x-drive gap. the link below has an F31 with 245/35/20 notice how the gap is reduced and also how close the top of a 26.8" tire is to the spring perch. there is no relative movement, so it would never rub, but still... https://f30.bimmerpost.com/forums/sh...d.php?t=849595 regarding winter tire size upgrade, on the stock 18", consider 235/45/18 which is 26.3". i understand that narrow is better for snow, but with current winter tire technology(tread patterns and compounds), the extra 10mm width over a 225, should not be a problem*. https://f30.bimmerpost.com/forums/sh...&postcount=162 https://f30.bimmerpost.com/forums/sh...1634952&page=2 https://f30.bimmerpost.com/forums/sh....php?t=1844734 *disclaimer, i'm in hawaii, where the only snow possible is at the top of 14000' mauna kea during winter so take my winter tire advice like a grain of salt. ADDED: this member has 245/45/18(26.7"). this size can also fit on your OEM 18x8 https://f30.bimmerpost.com/forums/sh...&postcount=212 . Last edited by alohasurftoad; 07-29-2022 at 12:45 PM.. |
johnung4528.00 |
08-01-2022, 03:19 PM | #16 | |
Rep 68
08-02-2022, 11:48 PM | #17 | |
Rep 68
Which is supposedly the American equivalent to the European 05-22 springs. Can you elaborate any further? |
08-03-2022, 12:55 AM | #18 | |
Rep 4,327
my eibach knowledge is mostly from this forum and other internet searches. i don't believe there is an american equivalent and use eibachshop.com to determine the eibach spring recommended. eibach/US seems less reliable. johnung has an Eibach/KoniSA combo and is way more informed about it all. he has also contacted eibach, koni and FaRKle!(suspension guru) more than a few times. personally, i would follow what eibachshop.com recommends, which is the 4-22. the 5-22 spring rates are probably higher and may not work as well for your 328i. hopefully johnung can chime in and inform us more. sorry i cannot provide a better answer but i'm still learning new things as well. https://eibachshop.com/index.php?p22...-springs-bmw-3 |
Kirby8677.50 |
08-05-2022, 08:14 PM | #19 | |
Rep 68
08-05-2022, 08:57 PM | #20 | |
Rep 4,327
the taller the tire, the less you need to lower it to reduce gap. since your planned summer setup is a quite tall 245/35/20(26.8"), your wheel gaps will still be nice and tight with the 4-22. |
johnung4528.00 |
08-06-2022, 08:26 AM | #21 | ||
Rep 5,392
08-06-2022, 09:52 AM | #22 | ||
Rep 5,392
Below is my typical methodology. I've gained my knowledge from researching, and also learning from and continuing to learn from FaRKle! I look to Eibach as a manufacturer first because they have a comprehensive selection of products that they tailor to specific vehicles. Other spring manufacturers tend to have kits that they specify for too wide a range of cars with very different axle weights which doesn't make sense. I don't even look at the Eibach US catalog anymore. It only contains a small subset of information. I use the Eibach European catalog which shows all of their products for all of the BMW worldwide models. And it shows the details as to which front and rear spring part numbers are contained within an Eibach spring kit. LINK TO EIBACH GERMANY CATALOG http://web2.carparts-cat.com/default...004&12=100 Always enter the exact information for your car to retrieve the Eibach spring kit recommendation. You'll see kit part number, estimated front & rear drop for your car (which turned out to be very close for my own car), and the individual part numbers for the front & rear springs contained in the kit. It shows individual specs for those springs. I wish it listed spring rates, but Eibach Tech Support will give them to you over the phone. They have been excellent for me. But I encourage you to do your homework first. Research the Eibach part numbers and specific questions you have. If you just call like a newbie and say "hey what Eibach spring should I put on my car", you're going to get the same response/part number that you could have looked up yourself in their catalog. But if you do your homework and ask intelligent questions, they will provide technical information that will be helpful. If you are in the US and you desire an Eibach part number that is difficult to find in the US, then try Tunershop. They are worldwide and ship to the US. Their Tech Support has been excellent too. NEVER look at a listing in the catalog that was done for another model/type car, and assume that it applies to your car. People often do this with drop estimates. A drop estimate is based on a specific car. If your car is different then that spring set will likely have a different drop on your car. People often forget spring rates. If the spring rates of a spring set are different from the spring rates intended for your car, then the car is likely to handle differently, possibly worse than your expectations. A car's suspension is actually complex. It's made up of many parts that form a system. Changing one component can very much effect the entire suspension system positively or negatively. Often Springs should be the first consideration when upgrading/modding a suspension because the spring rates effect the choice of dampers. And spring rates effect the choice of sway bars. FaRKle! has done a tremendous amount of research and hands-on suspension testing. I encourage folks to check out what he has published in his posts and on his YouTube channel- which is excellent! Here's the link to his channel: https://youtube.com/user/FaRKle0079 This video is pertinent to our conversation here: Hope this helps! |
