07-30-2022, 12:55 PM | #23 | |
Rep 3,406
I bought my VAC UCA and LCA monoballs from Kies Motorsports. Same price as VAC directly but Kies paid for shipping.
alohasurftoad3076.50 |
07-30-2022, 01:04 PM | #24 | |
Rep 706
I see. SoCalCarGuy said it’s powerflex urethene, so i thought that was the one. I didn’t know you have to replace the bushings and the arm as a whole set instead of bushings only.
Yeah at $500 a set, i may have to replace slowly since i am buying suspension as well. Quote:
07-30-2022, 01:36 PM | #25 | ||
Rep 5,393
07-30-2022, 10:54 PM | #26 | |
Rep 706
For the LCA, i read that the f8x LCA is also monoballs. My car is RWD. Comment from FaRKle!
Would it be ok to use the f8x LCA? I can find brand new LCA F8X for $200, so a set is $400, save over $150 from the vac monoballs. https://www.realoem.com/bmw/enUS/sho...diagId=31_1123 Part number 31122284529 and 31122284530 item 11 from diagram. Also, would you recommend the aftermarket one like delphi ? i can get them for even cheaper, lol https://www.fcpeuro.com/Parts/?keywords=31122284529 Fcp euro sells both oem and delphi Quote:
07-31-2022, 07:39 AM | #27 | ||
Rep 5,393
FaRKle! may have been discussing bushings in his video, but the problem is that the F80 and F30 control arms themselves are not identical. Guys who track their F30 cars have been messing around with F80 control arms for years before monoball bushings were available for the F30. The F80 bushings are considered an early version, designed many years ago before the F80 was introduced. The newer VAC monoball bushings are actually better. |
07-31-2022, 12:11 PM | #28 | |
Rep 4,325
more specifically, it increases positive caster and has a similar effect to adding negative camber. there are pros and cons to increasing positive caster. some cons are increased steering effort, increasing turning radius (due to increased wheel base) and the possibility of the outer tire shoulder rubbing the front of the fenderwell liner at full lock, especially if you decide to run wider tires. the bottom line is it changes suspension geometry and opens up another can-of-worms. as a tracking consideration, sure...for a daily, nah. just keep OEM LCA stock for now and save for VAC UCA. its expensive but worth it, in terms of time. super easy install, no alignment required. . Last edited by alohasurftoad; 07-31-2022 at 12:18 PM.. |
johnung4528.00 |
07-31-2022, 12:43 PM | #29 |
Rep 706
Alright. I wonder if Kies does a Black Friday sale, i will pounce during that sale, few more months to go.
Just curious, what is the lifetime for the thrust arm and lower arm when it’s due replacement? Last edited by gameson; 08-01-2022 at 01:17 AM.. |
