BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > How to: TorqByte CM5-LT Meth System Install
European Auto Source (EAS)
      04-21-2019, 08:26 PM   #45
M235SDCA
M235SDCA's Avatar
Drives: 16 M235 Vert
Originally Posted by harkes View Post
Hey
I ran out of meth on purpose. Check it out
Thanks for posting. That's a good video! Also good to see that the AFR says low as the failsafe kicks in. So I take it your MHD tune is working OK with your turbo?
16 M235 Cabrio - BM3, ER CP, Wagner DP & IC, Dinan Intake, MPE
18 340i F30
      04-21-2019, 10:57 PM   #46
harkes
harkes's Avatar
China
769
Drives: M135i, NSX and AE86
I was running a MHD PS2 BETA-map in the video. My tuner is still working on my custom map. So far the BETA-map is working great but only made for 91 pump so not really super powerful.
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      09-22-2019, 05:51 PM   #47
chetrickerman
ECUTek Master Tuner
chetrickerman's Avatar
Drives: F80 M3 YMB
2016 BMW M3  [0.00]
Thank you for posting this how to. I will be using it for my meth install on my F80
Are you still not running an anti-siphon solenoid and instead running the 20 psi check valve?
Torque is a measure of an engine's ability to do work; Power is the rate at which work is done
      09-22-2019, 08:22 PM   #48
harkes
harkes's Avatar
China
769
I had a solenoid before with the BMS kit but it is just another component to fail. You loose a bit of flow with the check valve but it is more reliable.
(A Dane in China)
      09-22-2019, 09:08 PM   #49
chetrickerman
ECUTek Master Tuner
Drives: F80 M3 YMB
2016 BMW M3  [0.00]
Thank you. I like the lack of the solenoid, it simplifies the system.
      12-05-2019, 03:39 PM   #50
insane11
Drives: 435i GC
Sorry for bringing this thread back.
But do you used a methanol inline filter with your kit? If so where do you put them since you have bms stealth tank?
      12-06-2019, 03:25 AM   #51
harkes
harkes's Avatar
China
769
Mine is sitting after the pump but that does not make sense hehe. I suggest to install it before pump.
Good you mention it. I have not cleaned mine for +2 years or so
(A Dane in China)
      12-06-2019, 08:57 AM   #52
insane11
Drives: 435i GC
But on the bms stealth tank.. The connection before the pump is so short.. How can you even fit the filter in.. I have the bms tank and planning to put the filter after the pump as well
      12-06-2019, 09:25 PM   #53
harkes
harkes's Avatar
China
769
Sorry, I dont know the stealth tank. I believe you can get a in-tank pickup filter....but that will probably not be accessible hmm. Just put the filter where you can then.
(A Dane in China)
      03-10-2020, 10:22 PM   #54
SpeedFried
Drives: 17' M2 Mineral Gray with DCT
This is a great thread and thanks for sharing your setups! I'm looking into the torqbyte setup for my N55 M2.
I have the Fuel-It direct port methanol kit installed which uses (6) 550cc injectors. Does the torqbyte controller have 6 GPO's or must you splice the injector wires together?
Also, will the boost solenoid failsafe work with the EWG N55?
2017 BMW M2 in Mineral Gray DCT Transmission
Speedtech Stg 3 (8374) l BM3 Jordan Tuned l AA Intake l ER Chargepipe l ER FMIC l Stage 3 LPFP l EOS Pump Controller l XDI-35 HPFP l NGK 97506 l Ohlins R&T l SPL Suspension Parts l RE-71 Rís l BMW M Performance Kidney Grills, Mirror Covers, Spoiler, Rear Valence l Full PPF Wrap l 35% Tint l
      03-11-2020, 03:04 AM   #55
harkes
harkes's Avatar
China
769
You must run all injectors on the same GPO. Check how many amps the GPO can handle. EWG does not have a boost solenoid but I would assume you can do the same as I do and cut ground to the EWG.
Have fun
(A Dane in China)
      03-11-2020, 09:44 AM   #56
SpeedFried
Have fun
Sounds good thanks for the information. Iíve been emailing with Alex at Torqbyte and will ask about the GPO amperage. Otherwise I think this controller can be a good solution for my system.
      03-14-2020, 10:21 PM   #57
HKD126
Drives: 2014 335i XDrive MSport
I used the BMS EWG harness to wire in the boost cut failsafe. Made it as plug and play as possible and simplified the install.
