12-22-2019, 08:06 PM | #1 |
Gettin It Figured Out
1820
Rep 2,669
What is your preferred Wheel Brush?
Alright detail ninja's...just as the title states, what is/are your go to detail wheel brush(s)? .
12-22-2019, 08:41 PM | #2 |
Rep 2,197
It takes a village!
https://www.autogeek.net/speed-maste...olies-kit.html https://www.autogeek.net/daytona-mini-wheel-brush.html https://www.autogeek.net/ezdebrfca.html https://www.autogeek.net/boars-hair-...ing-brush.html https://www.autogeek.net/low-profile-tire-brush.html
12-24-2019, 04:15 PM | #3 | |
Rep 6,696
Drives: F30 340i
12-26-2019, 10:42 AM | #4 |
¯\_(ツ)_/¯
945
Rep 1,762
I use these two
https://www.amazon.com/EZ-Detail-Lit...7378486&sr=8-5 https://www.amazon.com/Wheel-Woolies.../dp/B00R3YEKSY
ronanz1819.50 |
12-26-2019, 12:49 PM | #5 |
Rep 1,425
https://www.detailedimage.com/Wheel-...iece-Kit-P651/
https://www.detailedimage.com/TUF-SH...re-Brush-P550/
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
ronanz1819.50 |
12-27-2019, 09:44 AM | #6 |
Cheapskate
4447
Rep 4,993
Thanks for linking the Wheel Woolies. I always see people using them but never knew where to buy. Looks perfect for cleaning the barrel.
01-13-2020, 08:54 AM | #7 |
Rep 849
Drives: BMW 435i
I use a Speedmaster brush like was already mentioned for the barrels and between spokes. I also have a soft wheel brush I picked up at WalMart for the faces of the wheels.
After using wheel brushes from several sources to include the ones offered by Mother's, I found the generic brush sold at big-box stores to be softer, more durable, and cheaper. Go figure....
01-14-2020, 06:19 PM | #8 |
Rep 358
Use the same combo on my car and cars we get through the business, definitely takes an arsenal, 1 size brush does not fit all. And obviously the wheel design plays a large part in your choices.
https://www.autogeek.net/speed-maste...olies-kit.html : for getting in between spokes, nice kit for different sized brushes https://www.autogeek.net/mothers-tir...brush-kit.html : the long brush is for the wheel wells, medium size brush for the wheel faces, shorter brush for the tires https://www.autogeek.net/tuf-shine-tire-brush.html : my go to and favorite for just tires https://www.autogeek.net/daytona-spe...r-brushes.html : to get the barrels and in between spokes the woolies dont get to https://www.amazon.com/Master-Detail...9047413&sr=8-6 : to clean sensitive areas, tighter areas like bolt holes and if you like using your hands and not tools, or you are able to fit your hands in there, you can just use an old wash mitt that you don't care if it necessarily gets dirty, or microfiber towel. some people don't like messing around with all the tools if they can just use a towel instead.
ronanz1819.50 |
01-22-2020, 05:31 AM | #9 |
Rep 3,865
Generally speaking, "detailing" and "brush" rarely belong in the same sentence!
With the exception of soft brushes for detailing engine covers, air inlets/outlets, grills, etc, you don't use brushes! They DO scratch. I use a MF cloth for the wheels. It has a slightly rougher backside. You should not be scraping the dirt off - if it does not come off with a MF, you need chemical products, not a brush.
01-22-2020, 06:01 AM | #10 | |
Cheapskate
4447
Rep 4,993
Secondly, most of the wands that are being posted have microfiber bristles. They are just better suited to reach and clean between wheel spokes than a rag. |
ronanz1819.50 |
01-22-2020, 08:07 AM | #11 |
Rep 849
Drives: BMW 435i
The brushes I use on my wheels are very soft.
The Speedmaster, despite having nylon bristles, are long and very soft. I've been using it for years and never experienced any issues with the finish on my wheels. Also, the wheel brush I use on the wheel faces is also very soft. The bristles ends are split to make them easier on any wheel finish. One thing I found interesting was the really cheap wheel brush I use on facing surfaces comes from WalMart and has much softer bristles and is more gentle on wheel faces than those found from auto detailing stores
kern4174446.50 |
01-22-2020, 08:44 AM | #12 |
Rep 224
Late here but below is my arsenal:
Long Handle Tire/Well Brush: https://www.amazon.com/Carrand-94039.../dp/B002G29KLK Dressing Applicator: https://adamspolishes.com/products/a...BoC2KUQAvD_BwE Wheel Brush: https://www.autogeek.net/ezdebrfca.h...BoC21UQAvD_BwE Wheel Woolie: https://www.carpro-us.com/brushes-bo...hoC9uwQAvD_BwE Lug Nut Brush: https://www.autogeek.net/lug-nut-bru...RoC2KsQAvD_BwE Sorry for the long links. |
01-22-2020, 08:49 AM | #13 |
Rep 224
Ah, almost forgot my most important wheel cleaning tool. The "Green Monster" towel from Klin Korea. Yes, it really is THAT good. https://detail-division.com/products/kl-n-green-monster
01-22-2020, 09:56 AM | #14 | ||
Rep 3,865
The clearcoat on your rims is just as easy to scratch as on your car. It is not a "special" type. It is just more difficult to see given its nature and shape. The easiest way to scratch them is to use a brush. Not only through the brush itself but by unintentionally rubbing the plastic (or even worse - metal) structural parts of the brush. This said - there are of course brushes and brushes. My point however is that there is absolutely no need for a brush. Chemistry + a suitable MF is all a Detailer needs to maintain clean wheels! I consider myself into detailing and I have never needed a brush for neither of my 4 sets of wheels. There are small, suitably-shaped MF rags specifically for wheels. With a rougher textile on the back side, should you need to apply some pressure. Furthermore - if you really want to maintain your wheels as clean as possible for as long as possible and facilitate washing them - there are waxes and ceramic coatings on the market. Again - no brush required. Ever. Same way you never use a sponge to wash your car, even if your grandpa did. Here some food for thought: Fine, small brush only used for the bolt cavities and/or inner side.
01-22-2020, 11:06 AM | #15 |
Rep 224
Skyhigh I kind of agree and kind of disagree. Alloy wheels are clear coated and it is typically much thicker/harder than paint. Much like you would use a boar's hair/ synthetic (ie Detail Factory) brush to clean your badges and emblems without fear of scratching the paint, you can do the same with your wheels. The underlying silver/alloy color is also much harder to see scratches/swirls in than, say, black sapphire metallic. Not saying it's impossible. With proper lubrication, one should not fear a wheel woolie/speedmaster. Heck, even a microfiber wheel towel will scratch the wheels if you rub it dry.
kern4174446.50 |
01-22-2020, 12:52 PM | #16 | |
Cheapskate
4447
Rep 4,993
And a lot of wheels don't have clear coats. The powdercoating on most wheels will withstand a lot of abuse. |
01-22-2020, 01:32 PM | #17 |
Rep 3,865
Why did you assume I don't drive hard?
M Sport brakes on one (known for lots of dust), ATE Powerdisc + EBC on the other. 4 very different sets of wheels ranging from 17" to 19". Never had any problem with removing dust, as long as you don't wait a year to wash them! IronX, Tuga, etc. - chemistry made specifically for you to not wash like our grandparents used to - with sponge and brush. Not trying to convince anyone, but my advice - drop the brush, buy proper chemistry and a suitable MF. Example: https://www.chemicalguys.com/microfi...r/MIC_403.html P.s. And I am a lazy "detailer" - I wash on demand, by far not every week! When I do it though, I do it properly.
01-24-2020, 11:42 AM | #18 | |
Rep 849
Drives: BMW 435i
Even on my winter wheels which are new and ceramic coated, they still get spots which are hard to remove simply because the weather doesn't allow me to clean them often and the stuff builds up. I have to work at them pretty good to get it off. There may be some strong wheel cleaners which might eat though the heavier grime without much mechanical effort being needed, but I've seen that stuff cloud or haze the clear coat on wheels. I'd much rather use a milder cleaner and a quality brush or two.
01-24-2020, 01:46 PM | #19 | |
Cheapskate
4447
Rep 4,993
