02-25-2020, 01:40 AM | #1 |
Rep 118
Found solution for B58 engine whining??
I have had this noise since I purchased it ten months ago. To this day I could not find a solution but the noise disappeared completely.
Here is the funny part. I always thought it was related to drive belt-pulleys etc. I purchased the royal purple fuel system cleaner because I wanted to try it. I had used techron a couple of times, not that it would fix the noise but to keep my fuel system healthy as a newbie. I am not sure that royal purple fixed it but this is the only thing that I put into the engine other than the engine oil. It does not even make sense that a product like this would be the solution for a noise issue. These snake oils usually make negligible differences but this is what I think might have happened and maybe one of you guys can try this and see for yourselves. $15 is pretty cheap if it actually fixes this annoying issue. If you guys think that I am imagining things than I do no know what to tell you. Cheers and be safe on the road! |
03-07-2020, 01:49 PM | #2 | |
Rep 118
The whining was present every single time once the engine got up to optimal temperatures. Dealers did not even move a finger (I took to 4 different ones in the area). I honestly do not know if Seafoam will work but maybe you can come to a conclusion if you compare the products or maybe someone else may weigh in here. |
