01-21-2021, 04:56 PM | #6139 | |
Rep 4
01-21-2021, 05:03 PM | #6140 |
Rep 265
Direct from the Andream AliExpress seller "Andream Official Store". I cannot upload a larger version. desktop view should work.
01-21-2021, 07:49 PM | #6141 | |
Rep 11
As @rimsilva has experienced, I also was not able to downgrade my MCU from 20.10.22.16 to 20.06.02. The file is named upgrade.bin but it cannot be read by the MMI, I tried renaming it to NMCU.BIN (same name when I applied 20.10.22.16) but that did not work either. |
01-22-2021, 03:35 AM | #6142 | |
Rep 31
01-22-2021, 04:31 AM | #6143 | |
Rep 42
Then I guess that we can omit a bad FAT32 format of USB memories as a root cause. I just managed to successfully update to BR115, while took some pictures of the update process, Hopefully @Firefly1337 can figure out a solution for the "Burn Failed" error. |
01-22-2021, 05:28 AM | #6144 |
Rep 54
For who has Android Auto and Andream Box, is the sound with bluetooth working fine?
Everytime i hit next song, or choose another, no sound: https://www.dropbox.com/s/c94n3xvqfq...e5fN0lusE&dl=0 Thanks |
anyuser15.00 |
01-22-2021, 12:49 PM | #6146 | |
Rep 36
01-22-2021, 02:29 PM | #6147 | |
Rep 10
Everything installed correctly. Power is running to the MMI unit. There is no image displayed on the screen. Dip switches are correct. Optical cable transfered. All plugs firmly inserted. Reverting back to the standard iDrive unit results in immediate restoration of the image to the screen. Vehicle - BMW M2 F87 2015-2016 with NBT system Last edited by ///Matt2; 01-22-2021 at 02:42 PM.. |
01-22-2021, 02:47 PM | #6148 |
Rep 63
Hi, I continue with problems with the Andream unit A version with USB, it crashes and return to the main menu after 20 minutes more or less. I have tested it with two different firmwares, custom one from Bimmertech and the Andream original. I am little lost, I will try to test with other iPhone, mine is IPhone 11 with iOS 14.3. I hope it won’t be a hardware problem in my unit, it is strange because only occurs with wired connection, with wireless, is slower but never crash. Thanks in advance, regards!!
01-22-2021, 02:55 PM | #6149 | |
Rep 11
I understand BR115 has the AA Widescreen Fix. That's my main envy Last edited by fdaw750; 01-22-2021 at 03:14 PM.. |
01-22-2021, 04:55 PM | #6150 | |
Rep 42
My unit came with BR111, I updated to BR112 using the corresponding file in Post 3, then the Road Top support team sent me MCU 20.10.22.16, I updated the MCU and finally I updated the CUST software to BR115. Regarding your problem of receiving "Burn failed", I thought a bit and by looking at the PCB pictures available in Post 4, I realized that the unit (if Andream and Road Top hardware are the same) uses a non-volatile Flash memory of 2 GB (soldered on the bottom side of the PCB). The writing procedure into this memory shall be like this: it writes a piece of data (let's say 64 KB) and then reads that piece of data to make sure that the data has been written correctly. If for any piece of data the read and write values differ even for 1 bit, I guess that this "Burn failed" error message will be displayed. One question, do you get this "Burn failed" message when the progress bar has been completed (all the way to the end), or it happens in the middle of progress bar to the end? Last edited by Rasoul77; 01-22-2021 at 05:19 PM.. |
fdaw7509.00 |
01-22-2021, 05:07 PM | #6151 |
Rep 15
Hi. I have flashed firmware to Universal version CIC from first page, but Android Auto doesn’t work, I can’t connect neither wired or wirelessly. CarPlay works nice. My MMI is Andream A CIC. Everything worked fine on original software. Do you have some ideas what is possible problem? Thanks
01-22-2021, 05:31 PM | #6152 | |
Rep 11
Is there any way to reset the device to factory? I'm suspecting some cache partition may have become corrupted and won't let the update happen. Last edited by fdaw750; 01-22-2021 at 05:49 PM.. |
01-22-2021, 06:21 PM | #6153 | |
Rep 1,217
https://f30.bimmerpost.com/forums/sh...postcount=6142 |
01-23-2021, 12:57 AM | #6154 |
Rep 313
Drives: 2014 bmw640gc 2015Mercedes e40
Odd because I thought this was a android problem.. I'm having the same issues now that I upgrade to the note 20 ultra .. previous phone (note 8) once i figured out the quirks and updated the firmware it ran great . Always connected and never disconnected.. but since I changed over to the note 20 all of a sudden it hardly ever self connects and once in a while it just disconnects itelf .I'm thinking of trying to downgrade my firmware and see if that helps ...
01-23-2021, 01:56 AM | #6156 | |
Rep 4
Anyone get this to work? After trying to update, I now get an all black startup screen. Better than stock, but no dice on the BMW logo. I'm using Andream CIC B-Version. Last edited by tarven; 01-23-2021 at 02:19 AM.. |
01-23-2021, 03:15 AM | #6157 | |
Rep 18
I also replaced the Carplay icon |
01-23-2021, 03:57 AM | #6158 |
Rep 12
I posted about this same issue some pages back. I have the same issue with my iPhone with a Carlinkit unit. Never connects wirelessly so I now always used a wire. Others posted that they have similar problem. I also have an Android phone and that connects wirelessly every time...
01-23-2021, 04:49 AM | #6159 | |
Rep 313
01-23-2021, 05:15 AM | #6160 | |
Rep 54
Tried with BT's car, and with Andream BT's, same issue. Seller says i need to use AUX Cable to have sound, but having more cables inside is pointeless for me... Wich version is mine? A or B? View post on imgur.com Last edited by Primax; 01-23-2021 at 05:34 AM.. |
andream, android, android auto, apple, carplay, mmi, retrofit |
