09-08-2016, 08:57 PM | #1 |
Rep 47
Will it be a conflict between MPK and modified ECU?
I have a question about the modified Ecu, beacuse the my N55 engien already tuned with the M power kit. If I go with other ecu improvement, will it conflicets mpk?:大声笑:
09-09-2016, 12:14 PM | #2 |
Rep 190,805
No you will be fine ... Your tuner will re-write a new map over the remap you already have
09-09-2016, 12:21 PM | #3 | |
Rep 115,980
Mike |
cailas31.00 |
09-10-2016, 12:36 AM | #6 |
Rep 47
09-10-2016, 05:51 AM | #7 |
Moon Parasite
654
Rep 1,336
If you have someone overwrite or reflash your current ecu that has the MPPK in it with a different tune, then yes you will loose the MPPK tune / flash.
If you have them change out your current ecu with a different one that has another tune in it then the MPPK will be retained in the old ecu.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
09-10-2016, 09:15 AM | #8 |
Rep 115,980
09-10-2016, 07:55 PM | #9 | |
Rep 47
09-10-2016, 10:00 PM | #10 | |
Rep 190,805
If you buy another ECU yes
09-11-2016, 06:44 AM | #11 |
Moon Parasite
654
Rep 1,336
mike@x-ph.com24190.00 |
09-11-2016, 12:28 PM | #12 |
Rep 4,323
The PPK DME, if you were upgraded, is compatible with flash tunes, but will be written over when it's flashed.
Some things aren't impacted, like the burble for instance, but other things are...I've done it, no big deal.
