BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19 tyres size questions (RWD)
      10-22-2020, 02:39 AM   #1
manghong
manghong's Avatar
80
Drives: BMW F30 328
Hi all, recently purchased a set of for my RWD F30 lowed with coilovers with the following spec
19 x 8.5 ET36
19 x 9.5 ET36
I know that 235/35/19 and 255/35/19 would run without any rubbing issue, however I would like to have beefier rear tyres, does anyone know what is the largest size that I can run without rubber issue? thank you!
2012 BMW F30 328i
      10-22-2020, 01:17 PM   #2
thejeremyman9
thejeremyman9's Avatar
1433
Drives: 2015 BMW 335i
Not sure about the max size for rear, but you should definitely do 245/35/19 front instead of 235/35/19, i went from the stock 225/35/19 to 245/35/19 even on the OEM 8'' wide 19'' wheel.
      10-22-2020, 10:18 PM   #3
manghong
manghong's Avatar
80
Drives: BMW F30 328
Do you have any photos of the front?
2012 BMW F30 328i
      10-23-2020, 12:28 AM   #4
thejeremyman9
1433
https://f30.bimmerpost.com/forums/sh....php?t=1678451
Aloha posted some of another car, and if you scroll down, you see my before and after albums.
      10-26-2020, 09:26 AM   #5
jadis
Drives: 335xi
19 x 8.5 ET36
19 x 9.5 ET36
The simplest conversion that will provide you extra beef is 235-40-19 and 265-35-19. This will also have a very low change in speedo error, if even recognizable, which it won't be. I am adding these to my car now. This combo will add more beef front and rear and keep front and rear at almost identical overall diameter.
      10-29-2020, 09:28 AM   #6
manghong
manghong's Avatar
80
Drives: BMW F30 328
Thank you for the input, I have finally decided to go with 225/40/19 and 255/35/19, here is the rear wheels 9.5J ET36 255/35/19 tyres with loading in the back, no rubbing at all
2012 BMW F30 328i
