09-05-2016, 09:17 AM | #1 |
Rep 82
JB4 - Logs Show Low Boost on E15 and Map 5
Hi, I'm relatively new at all of this so thanks in advance for reading.
I have a 2012 335i MT with JB4 and ER Chargepipe. Yesterday I filled up with about 3.5 gallons of E85, and the rest of the way with 93 octane. I set the JB4 to map 5 and did a couple of logs on the highway. It felt like the turbo wasn't fully performing. It's felt that way on Map 1 a couple of times too. I'm starting to suspect I might have a leak somewhere or a bad plug. The two attached logs are from pulls in 1st, and then 3rd gears. Both look like the map changed from 5 to 4 and back to 5 (which looks odd). And even my targets look really low (in addition to the boost levels looking low given the throttle levels). Is this just user error on my part? What are some next steps to diagnose if there is actually any problem? |
09-05-2016, 09:32 AM | #2 |
Rep 389
Drives: '13 F30 335i MSport
Don't see any logs attached. Also, you shouldn't be running anything higher than Map 1 without a DP.
2013 GSM 335i MSport
09-05-2016, 09:52 AM | #3 |
Rep 82
09-05-2016, 01:00 PM | #5 | |
Rep 82
http://www.n54tech.com/forums/showth...038#post495038 |
jgoens3787.50 |
09-06-2016, 04:17 PM | #7 |
Rep 82
09-06-2016, 04:56 PM | #8 |
Rep 5,776
Looks like Terry got back to you and said to fix your settings. Have you done that?
Last car: 2011 335i Msport. JB4. Vrsf CP |
09-07-2016, 08:48 AM | #9 |
Rep 115,999
09-07-2016, 01:19 PM | #10 |
Rep 191,065
Its safe to run map 5 on a stock car
