09-27-2018, 06:48 AM | #2 |
Rep 68
Drives: 340i M-sport
09-27-2018, 08:17 AM | #3 |
Rep 109
09-27-2018, 12:36 PM | #8 |
Rep 109
Look up Zed coding on Facebook he does it remotely. Really straight forward to do and he guides you though the process. He also give you a list of codes he can do for your vehicle.
Give him a try |
09-28-2018, 09:26 AM | #9 | |
Rep 8,471
The Alpina map may not be ideally suited to the 30d. A few hundred rpm could make the difference with the engine dropping back to just below the ideal shift points.
09-28-2018, 12:56 PM | #10 | |
Rep 3,967
I did read somewhere that the Alpina flash makes the 35d change up a little earlier (which some people prefer), so it may well be ok on the 30d, it just depends if it revs beyond 4500/4600rpm in certain gears or not. If it hits 4700/4800rpm max then it's not ideal for the 30d as in my opinion anything above the stock max gear change points is too high for them and going out of the optimum power band. 330d changing from 4th>5th Sport+ and DS mode Last edited by Hooded; 09-28-2018 at 01:05 PM.. |
09-28-2018, 01:11 PM | #11 |
Rep 7,028
Drives: 335xd Msport +
It works better with a remap - the increased power band matches the shift up points- as per an Alpina which is basically a tunes up 335d engine.
Can improve the mpg as well.
09-28-2018, 01:20 PM | #12 | |
Rep 3,967
We need to know the max rev shift up points on the Alpina flash though before we can say the same about the 30d. The 30d power falls off a cliff after 4500/4600rpm even with a good remap unfortunately. |
09-29-2018, 03:27 PM | #13 | |
Rep 7,028
Don’t know the figures myself. If you give Rick at Unicorn he may well know the answer.
11-09-2018, 06:07 PM | #14 |
Rep 87
1.Make a copy of VO, SVT and ECU
2.Add to VO: 920, 9XA Production date 1211 or higher Typeschlussel XA71 for F10 or 3E51 for F30 Factory ilevel 11-09-507 or higher 3. Follow "How to change FA" guide to modify and upload new FA 4.Follow "ECU flashing" guide and flash EGS 5.Then in TAL-PROCESSING: Uncheck all Check just EGS procedures - BLFLASH, SWDEPLOY, CDDEPLOY |
