01-16-2022, 09:09 AM | #2048 |
DisplacementReplacement
409
Rep 1,100
i'm thinking anything under 2000 psi is cause for concern so agree...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
arvi60461.00 |
01-16-2022, 09:23 AM | #2049 | |
Rep 1,010
Yeah noticed that but timing and timing correction are ok, the ECU will close the throttle or pull timing if something not right.
But as I said it's a 2nd gear log I would like to see a proper 4th gear log for better judgement. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
01-19-2022, 05:40 AM | #2050 |
Rep 22
Adding mine here.
3rd and 4rth - https://datazap.me/u/bmwest/4th-5fth...=11&zoom=24-67 4-5-7 - https://datazap.me/u/bmwest/test?log...-46&zoom=26-68 Missfires and Check Engine - https://datazap.me/u/bmwest/ce-missf...18-19-20-21-22 Seems like last replacement of spark plugs was not going well. Last edited by MeByName; 01-19-2022 at 05:53 AM.. |
01-23-2022, 05:19 AM | #2051 | |
Rep 1,010
In terms of safety and performance logs are good, some corrections here and there but nothing dramatic.
Most probably the DTM light and missfires are a result of very low fuel rail pressure not spark plugs, could be a sign of HPFP failure. Other than DTM light and missfires are you noticing any long cranks ? Quote:
01-23-2022, 05:48 AM | #2052 | |||
Rep 22
I have replaced spark plugs to the correct ones(NGK) and gapped them to 0.5mm. Some time ago I have also replaced fuel injectors, though that might be a reason as well. HPFP is TU oem, it's 1 year old. I will try to test it again, after snow will stop here. |
01-23-2022, 05:51 AM | #2053 | ||||||
Rep 22
01-23-2022, 07:28 AM | #2054 |
Rep 1,010
No, fuel pressure drop occurs in gear.
Check what fault code the DME registered.
01-23-2022, 07:29 AM | #2055 |
Rep 22
Pretty easy. Recorded them.
01-23-2022, 07:49 AM | #2056 |
Rep 282
hpfp behavior is normal , post shift your rpm drops , so output aswell , the quantity valve adjusts and comes right back up . although the resolution of your logging seems low , or is it normal in mg flasher ?
once again why gapping ?
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
01-23-2022, 08:13 AM | #2057 | |
Rep 22
Thanks |
01-23-2022, 08:21 AM | #2058 |
Rep 282
maybe some users with xp in mg flasher can help
putting your units into psi is easier to read , because its mainly used overhere https://datazap.me/u/thomas/stg2-hpf...ata=3-17-18-20 this is how its looks in mhd , yours is too rough
01-23-2022, 09:03 AM | #2059 |
Rep 1,010
It's not post shift it's in gear, hover to 5000 RPM in the log below, fuel pressure drops from 20 mpa to 11 mpa:
https://datazap.me/u/bmwest/ce-missf...&data=11-14-15
01-23-2022, 09:19 AM | #2060 |
Rep 282
its paints a different picture
anyway i would start with oem plugs and gaps anyway and relog forget the gap bs
01-23-2022, 01:00 PM | #2061 | |
Rep 22
01-23-2022, 10:29 PM | #2062 |
Rep 25
Hi Guys, I have a Stage 2+ 340i using BM3 OTS 93 Oct tune and brand new TU pump.. Just wondering whether you can give some inputs to my data-logs as there are some "knock detected" -- during normal driving and some on WOT. Is this troublesome?
I see that Cylinder 5 continue to see the biggest timing correction mostly, is this a cause of concern? How much timing correction will start being a problem, >5 degree? Logs on normal driving: https://www.bootmod3.net/log?id=61e2...729b3b8e49702c https://www.bootmod3.net/log?id=61eb...729b3e67787c7a Logs on WOT (through several gears): https://www.bootmod3.net/log?id=61eb...90c640becd3103 https://www.bootmod3.net/log?id=61eb...729b40366d4ec5 Just wondering whether its the bad fuel octane, bad spark plugs (it is only 10k kilometres old) or heat? |
01-24-2022, 03:05 AM | #2063 |
Rep 1,010
If Fuel pressure target also drops I would say yes.
Try re-gapping the spark plugs to original gap, if it didn't work buy another new set from a different source.
01-26-2022, 01:30 PM | #2064 |
Rep 204
Hello!
Could someone please explain me what is "ignition angle" (vs timing correction), and what value is considered normal? Thank you!
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
01-26-2022, 05:32 PM | #2065 | |
Rep 25
Any help or input for the below will be much appreciated guys, I am considering to bring down my tune to Stage 2 91 Oct if you guys think this is NOT safe.
01-26-2022, 09:53 PM | #2066 |
Rep 298
Base Map E85 logs with Vargas GC ...car felt a bit faster than my 93 map but nothing crazy. A few more degrees of timing up top (2-3 degrees) but similar boost to 93 tune ... thoughts???
https://www.bootmod3.net/log?id=61f1...90c609919ff44e https://www.bootmod3.net/log?id=61f1...90c60c0769c69a |
01-28-2022, 07:38 PM | #2067 |
Rep 947
Everything about this data log is garbage
My timing pull is terrible
My HPFP is dropping during a pull My boost is off target My AFRs are fine Is all of this because of my HPFP dropping off? I have terrible fuel here in Utah (91 Octane) but I did dyno tune this car in the summer with PJ. This is stock turbo, stock fuel pump. https://datazap.me/u/wrxtobimmerguy/...39-40-41-42-43 This is dyno revision 3 https://datazap.me/u/wrxtobimmerguy/...39-40-41-42-43 Last edited by WrxToBeamerGuy; 01-28-2022 at 07:44 PM.. |
01-30-2022, 03:00 PM | #2068 |
Rep 204
Bump!
