01-24-2022, 03:33 PM | #1 |
Rep 676
Compression test - how much psi is considered to be a healthy engine?
I did a compression today. Under dry test the numbers are as follow:
Cylinder 1 - 230 Cylinder 2 - 240 Cylinder 3 - 245 Cylinder 4 - 245 Cylinder 5 - 245 Cylinder 6 - 245 Under wet test they are around 270 - 275 psi. Also I see some white smoke coming out from the spark plug hole on cylinder 6 when I did the wet compression test. Is this due to the burning oil? |
