BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Any Other High-Mileage 328d's Out There?
      06-27-2017, 09:07 AM   #23
graphicjunkie
Drives: 2016 535d Msport Xdrive
In most cases, staggered wheels is just a difference in width, having the rear wheels/tires wider than the front. For a while there, like in the case of the 330ci, they would +1 size the rear wheel. This shouldn't affect this as long as the overall diameter remains the same. Example: (225/45ZR17 F, and 225/40ZR18 R)
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport -
Kerma Tune, CF rear spoiler
      06-27-2017, 11:56 AM   #24
PabloK
PabloK's Avatar
49K Transfer case blew on mine for the 2nd time (1st time at around 32K)
$5,000 repair covered under warranty.
Lots of hesitation during acceleration.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
2019 GMC AT4
      06-27-2017, 12:27 PM   #25
Gabreigns
Gabreigns's Avatar
439
Drives: F3x
Holy crap! 2 transfer cases? Wow
      06-27-2017, 01:16 PM   #26
Uber Commuter
Uber Commuter's Avatar
523
Drives: 2014 328D xDrive
Sweet mother o' jeebus...
      07-03-2017, 11:12 PM   #27
rocksnap
Drives: 2014 328d
Update of my post of 500 miles ago
Transfer Case was replaced under warrantee @ 41,000 miles. No computer codes were thrown. Just me noticing some very subtle issues with the drivability. When going thru a medium sized corner and under low/mid acceleration, I could feel the car doing a "stutter". Disconnect the TC, the issue went away. It seemed to be making a subsonic noise/rumble that was masked by the long on tooth stock tires.
      07-05-2017, 07:47 AM   #28
Uber Commuter
523
Was the noise it was making a rhythmic humming sound? Like on/off, not constant? My car is doing this, thought it was the tires originally but after my last service the noise didn't change any (assuming they rotated tires during service...).
      07-05-2017, 03:22 PM   #29
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Mine is creeping up on 60K, had the transfer case and rear diff replaced (under warranty) around 52K
2016 F23 M235 xDrive Convertible Dinan Stage 2 AA IC Apex EC-7 MPE
2016 F31 328 xDrive Sport Wagon Dinan Stage 1 Vorsteiner V-FF 105 BBK 34 Hours 35 Minutes NY to LA
2006 E46 330ci ZHP Convertible Apex ARC-8
      07-11-2017, 07:02 AM   #30
jdr78569
jdr78569's Avatar
136
Drives: F31 328d sport wag
Originally Posted by mjship2001 View Post
How much did it cost to replace it?
Sorry for the delay! the part was about 4500 at BMW install was another 2k so about 6500
Since then havent had any problems and im back to loving my 328D lol
      07-11-2017, 07:03 AM   #31
jdr78569
jdr78569's Avatar
136
well seems transfer case is coming up more often then i know. When mine went out i couldn't find much info on others going out.
      07-11-2017, 07:08 AM   #32
jdr78569
jdr78569's Avatar
136
Originally Posted by 5hift View Post
That is part of their diagnostic procedure. The service manager told me this is how they proved to the agent of my extended warranty, which was third party, that the transfer case was already defective at 54k miles. I was also advised to get a square set-up for my wheels and tires if I want my transfer case to last longer this time around. I'm not taking any chances.
Yeah I stuck with the same size rims when i swapped mine out just to be safe. Although now I have 8.5 in stead of 8's. I was told and looking it up, no changes to im happy with my set up now
Originally Posted by FaRKle! View Post
I wonder what the proportion of T-case failures between square vs staggered wheel setups is.
Trust. You would not want to see or chance that after you feel the wrath of the transfer case bill. Take our advice young grasshopper
      07-11-2017, 07:10 AM   #33
jdr78569
jdr78569's Avatar
136
Originally Posted by CleanKM View Post
Just hit 70K miles on my 2014, only had to get a NOx sensor replaced at 30K. And the oil pan because the last dealer service under warranty stripped the pan...
So far, so good.
So did you have a CEL for the NOX sensors? Mine has been lit up but im not sure which sensor it is. Ive been riding it out till my DEF runs out. I was told it could be the DEF I used since it was close to a year being stored. IDK but ill try it out since the sensors are 600+ each and i dont know which one is triggering it
      07-11-2017, 12:41 PM   #34
Uber Commuter
523
Just broke 50,000 on my 2014; had a wheel hub replaced at 49,600 due to whining noises
(from the hub, not me )
      07-11-2017, 12:48 PM   #35
FaRKle!
Drives: '17 328d Sport Wagon
Oh, I have no intention on going staggered (I like being able to rotate my tires and the BMW 405m 18" wheels I have don't have a staggered option). Just wondering what the risk profile looks like for square setups.
      07-11-2017, 02:36 PM   #36
js 84
js 84's Avatar
81
Drives: F30 2012 320d
Mine is 320d with ~115k miles since Nov 2012. No issues so far.
      07-12-2017, 06:51 PM   #37
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
So far, so good.
Mine sat idle for a month in the winter with snow and ice build up on it throughout that time. When I returned back to it is when the light came on. I took it to the dealership and they performed a software update on it and said it could be issues with software (showed me the repair manual process and it stated it in BMWs own documentation). Said to come back if it came on again. Sure as hell it came on again a week later then they replaced the sensor and there hasn't been any issues with it since.
      07-12-2017, 07:48 PM   #38
Adamr916
Adamr916's Avatar
Drives: 2014 328d
I doubt it sitting had anything to do with it, I just refilled my DEF tank for the first time in 2 years (it was last filled on the last free oil change) I never had a issue with it. My NOX sensor went out on the test drive at 25 miles. It's an issue with the actual part, not the DEF.
      07-16-2017, 09:23 AM   #39
5hift
5hift's Avatar
Drives: 2014 328d M Touring
      07-16-2017, 09:25 AM   #40
5hift
5hift's Avatar
You can take your chances. If it happens to your xdrive, your pocket is not going to be very happy unless you have a lot of cash to burn. I don't...
...and a square setup helps to turn the car better.
      07-24-2017, 07:31 PM   #41
PabloK
PabloK's Avatar
Will an OEM staggered setup accelerate the transfer case failure?
How is this any differenent from other staggered setups on x-drive cars? is it a diesel issue?
2017 Alpina B6
2019 GMC AT4
      08-14-2017, 08:39 AM   #42
graphicjunkie
I'm very curious as to how a staggered width set up vs square as it's been put here, can cause failure to the transfer case?
I can completely see a circumference variance causing problems, as it would cause bind on the system. But tire width should have absolutely zero affect on it to the best of my knowledge.
Can someone please elaborate?
      08-15-2017, 06:39 PM   #43
mrgolf100
Drives: 2014 328d
I have 119,XXX miles on my 2014 328d purchased new in December 2013. I have had 3 transfer cases replaced (warranty) at 50k, 90k and 115k. Car left me stranded on the highway each time..Dealer can't explain it but it doesn't seem to be that prevalent on internet searches. Anyway, other than a broken horn, i've done maintenance as CBO suggests. Nothing more, nothing less and runs great.
      08-15-2017, 06:59 PM   #44
Gabreigns
Gabreigns's Avatar
439
Drives: F3x
Wow that is crazy! Sorry to hear.
What are your tire sizes? And in what wheels?
