06-05-2018, 08:05 AM | #155 |
Rep 817
Drives: bmw M3 F80
06-07-2018, 09:26 PM | #156 |
Rep 71
Yay!!
Another f30 without sun-rooof successfully alarm retrofitted!! Thanks to roxxor for the tutorial and infinitely grateful with Jhnblckwood, David51 and Jalami for all the guidance and valuable help!!
If someone is interested I have one module for a car "with sunroof" on sale, thank you
Gabo
06-08-2018, 11:50 AM | #157 | |
Rep 765
Did u end up getting that roof module I sent the link for? Either way glad u got it working bro |
06-08-2018, 01:04 PM | #158 | ||
Rep 71
Gabo
06-16-2018, 02:04 PM | #161 | |
Rep 14
06-16-2018, 06:18 PM | #162 |
Rep 14
For that matter- is anyone selling any of the components? Or if anyone likes helping people with the installation over the internet or in person?? (can thank with paypal of course !)
06-17-2018, 12:04 AM | #163 | ||
Rep 71
Gabo
09-22-2018, 09:34 AM | #165 |
Rep 765
10-02-2018, 10:46 AM | #166 |
Rep 24
Hi, does this DIY include tilt detection?
Some say the sensors are inside the roof module. Tilt detection = when someone tries to steel your wheels by jacking up the car. |
10-05-2018, 07:53 AM | #167 |
Rep 24
For those interested. There is also a "OEM" BMW retrofit kit for ALARM system.
Partnumber: 65752448362 You will have a extra module (instead of coding) Interior motion sensors included (instead of replacing roof internal light dome) I prefer the real OEM way, including coding. |
10-06-2018, 04:03 AM | #168 |
Rep 765
The sensors in the roof module are the motion sensors. The tilt I believe is in the alarm horn itself. On ebay it says alarm with tilt sensor.
10-07-2018, 01:52 AM | #169 |
Rep 13
So I thought I would come back and explain where I screwed up and how this cause my alarm to go off after a certain period of time. I finally went back and double checked all my work and realized I wired into the fuse box on 130 instead of 103. Needless to say though after I fixed that, everything was working great.
10-08-2018, 12:36 PM | #170 | |
Rep 71
Gabo
10-12-2018, 04:28 AM | #171 | |
Rep 24
Please correct me if I am wrong. Minimum wiring requirements for OEM alarm. Connector A21*1B needs to be wired: 1 - ground 2 - power (via F62 30A) 3 - to mirror for LED 11 - signal IN from Siren 14 - K_can2_H 15 - K_can2_L my case: I have no sunroof, so there is no power supply (pins 1+2 empty) But pins 14 and 15 have wires. Pin 11 will get signal wire. Q1: Do I only need to power FZD? Q2: Do I really need 30A, as it seems only relevant for Sunroof motor. It is safe/worth trying to use power and ground from connector A21*2B. I don't care if 5A fuse will die, just don't want a dead FZD module. Q3: Is it possible to simply add a red LED diode to PIN 3. I don't want to change rear view mirror. link to wiring diagram: https://www.newtis.info/tisv2/a/en/f...tem/1VnYSzkO9x thanks! Last edited by manitaci; 10-12-2018 at 04:47 AM.. |
10-12-2018, 08:13 PM | #172 | |
Rep 817
Drives: bmw M3 F80
yes you have to feed the FZD you can try to reconnect to the power supply A21*2B or use the original power supply A21*1B (2)F62 and put a 5A fuse in place of the 30A. I have never tested but you can try with a led |
10-15-2018, 07:52 AM | #173 | |
Rep 24
Looks like the FZD module allready gets power from A21*2B. Pin 14 and 15 seems crucial. Everything works fine, only to test a external LED next weekend. UPDATE: LED diode works directly on PIN3 and ground somewhere. Last edited by manitaci; 10-16-2018 at 03:22 AM.. |
10-15-2018, 08:06 AM | #174 | ||
Rep 817
Drives: bmw M3 F80
12-29-2018, 05:14 PM | #175 |
Rep 202
Drives: 2011 M3 6sp
Sorry for bringing up something that's a tad old, but i noticed that I am missing 14,15 pins which are for kcan, I believe this is why I am not seeing the module in the ecu, has anybody else tried running 14,15 to somewhere on the kcan2 bus and had the FZD module appear afterwards in esys?
12-31-2018, 04:43 PM | #176 | |
Rep 765
Goodluck bro. |
