02-21-2016, 11:40 PM | #1 |
Rep 233
Loud Squeaking from M Brakes, dealer says BMW Corp says its normal...
UPDATE - See video below I took today:
So I have a '14 335i with the M Brakes and I've had to take my car in twice already for extremely loud embarrassing squeaking every time I come to a stop... First time I took it to the dealer, the squeaking came back within a month so I decided to go to a different dealer since the first one had bad service as well... Second Dealer, as soon as I drove off the service center, it was squeaking badly even though the said they had done whatever they could... Service Guy told me that BMW Corporate was aware of this and wouldn't allow them to do much about it other than to the basic clean the brakes and rotors service... Who's had this issue too? Can we all write a petition and send it off to Corp? How does a 50-60k luxury car make these ridiculous noises when a $500 Ford from 20 years ago doesn't???? P.S. I will post a video when I get a chance...
Current: '14 335i Msport
Past: '10 370Z Roadster, 06 G35coupe, 02 Mustang GT, 02 Focus SVT, 96 Probe GT Last edited by kingc0bra; 02-24-2016 at 02:03 AM.. |
02-22-2016, 08:34 AM | #3 | |
Rep 90
sygazelle11347.00 |
02-22-2016, 08:56 AM | #4 |
Rep 410
Drives: One car with good steering ;)
Dealer fixed it by replacing pads and rotors but I suspect that it will come back in the near future. Many, many people have complained about this for the M Sport brakes. I'd rather have noisy brakes than have ones that stop less.
02-22-2016, 09:25 AM | #5 |
Rep 4,981
This is normal squeaking for those brakes/pads:
http://www.turnermotorsport.com/t-br...fferences.aspx
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
02-22-2016, 09:55 AM | #6 |
Rep 6,990
There was also a SIB out awhile back on noisy rear brakes where some brackets for the calipers needed replacing. I have "standard" brakes (the blue M-brakes weren't available when I bought my car), and the replacement of those brackets fixed my issue.
There are aftermarket pads that might help the situation somewhat, along with different rotors (slotted, etc.). Also, there used to be a sticky compound you could apply to the piston side of the brake pads that would keep them from vibrating when the brakes are lightly applied. This worked for me in other vehicles, although it may or may not help in this situation.
02-22-2016, 12:10 PM | #7 |
Rep 378
Drives: '16 340, ex e92 335, ex e46 M3
02-22-2016, 12:48 PM | #8 |
Rep 7,047
Squeaky pads are very common in many different cars.
The greatest and best success I've ever had is to get a brake pad set with "shims", they may also be called "anti-vibration/rattle" pads. These pads/shims help to quell the onset of squeal or vibration, and they work nicely too. If you get a pad set with the shims/pads included, then do install them and follow the directions. If the pad set doesn't have them, then get a stand alone shim set that will fit your pad. Many, if not most, of the kits include a high temp grease. This grease gets smeared onto the OUTSIDE of the shim, the side that is AWAY from the pad. This the true anti vibe/squeal ingredient as it stops the repetitive oscillation that can set in and create the squeal. If you can't find shims to fit your brake pad, there is still one trick left that has worked for me in the past. BUT, you have to be REALLY REALLY careful when doing the install, so that you do NOT get any grease on the working side of the brake pad of the rotor. This technique/trick requires some of the same type of high temp grease. It's easy to find in an auto parts store. When assembling the pad simply put a coat of the high temp grease on the back side of the pad. The grease coating will help decrease the squeal if not remove it completely. Just do NOT get any grease on the disc or the working side of the pad. Here is some more helpful info: http://www.knowyourparts.com/technic...es/brake-shim/ |
02-22-2016, 12:58 PM | #9 |
Rep 233
So you don't mind driving people around who think your car is a POS even though its a newer BMW luxury car??
Past: '10 370Z Roadster, 06 G35coupe, 02 Mustang GT, 02 Focus SVT, 96 Probe GT |
02-22-2016, 01:02 PM | #10 | |
Rep 233
02-22-2016, 01:04 PM | #11 | |
Rep 233
02-22-2016, 01:57 PM | #13 |
Rep 233
How is this acceptable? I know many cars that have had Brembo brakes from the factory that did not have this issue, why is that ok in BMWs world?
02-22-2016, 02:22 PM | #14 |
Rep 1,418
Generally speaking and to my experience having had several M3's w M brakes you're being too soft on your brakes. Get on them. Go hard every now and then. If you're engine braking or feathery with your braking 90% of the time they will squeal like a pig. Use them like they are M brakes!
dL.78.50 |
02-22-2016, 08:55 PM | #17 | |
Rep 1,029
I had the same issue with the M brakes, the noise got too loud and I decided to take it to the dealer. I didn't want to hear that "it was a normal thing with the M brakes". what they ended up doing was to round off the edge of the all of the pads. I forgot what the procedure is called, but it fixed the problem 100%. its been over a month and the brakes are as silent as they should be. the issue with the pads is that brake dust builds up on the sharp edges of the pads and that's the cause of all of the noise. FYI: I did the slamming on the brakes at high speed (in a safe area) and the noise stopped for a few days. Not the proper solution in my case.
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK). |
02-23-2016, 07:20 AM | #18 | |
Pace Car Driver
1548
Rep 3,164
02-23-2016, 07:37 AM | #19 |
Rep 6,990
Yes - Service Information Bulletin, I think. I'm not sure at all where you'd find those, other than doing something like a Google Search or asking your dealership's service dept. This particular one came out in early 2014. It may or may not apply to your build date, though, but it was fixed for my car under that SIB as warranty work.
02-23-2016, 09:35 AM | #20 |
Rep 410
02-23-2016, 09:47 AM | #21 |
Rep 1,114
I have the MSport Brakes, and mine don't squeak. only when I have just washed 'em. And that isn't very loud.
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
