06-19-2019, 10:31 AM | #45 |
Rep 1,799
Does the body of the pump have a hole on the opposite side as well? Going by some pics on TDI, it seems they might
06-19-2019, 10:43 AM | #47 |
Rep 1,799
Picture answers the question perfectly, although I didn't word it correctly. Thanks!
07-05-2019, 01:47 PM | #50 |
Rep 368
Ordered new flaps / gasket for the intake manifold, the destructions say they need to be replaced if it's removed. That came innthe other day but I Haven't gotten around to messing with it yet, it's been crazy hot out but probably pretty soon.
07-06-2019, 11:05 AM | #51 |
SQUEAKY
104
Rep 322
Thanks for all of the documentation through all of this. Would you be willing to make a DIY guide after everything is all said and done with?
07-06-2019, 05:01 PM | #52 |
Rep 1,799
It's pretty much the same as the newtis instructions for it.
https://www.newtis.info/tisv2/a/en/f...nit/1VnXVC8jSu
CleanKM103.50 |
07-07-2019, 01:45 PM | #53 | |
Rep 368
CleanKM103.50 |
07-07-2019, 09:25 PM | #54 | |||
SQUEAKY
104
Rep 322
07-08-2019, 12:56 PM | #57 |
Rep 1,799
Good progress!
If it's just a surface buildup like on that flap, that is more or less appropriate buildup for the miles. My old TDI looks about the same and isn't accumulating more.
07-08-2019, 07:18 PM | #58 |
Rep 18
I came across this on an old post (Bimmerfest by God-Follower). Maybe it'll enhance the bleeding process.
" These diesels can be pretty hard to bleed. Usually we crack a line at the top of one of the injectors until we see fuel coming out without bubbles with just a key cycle(no cranking). This purges most of the air out. Torque the nut to spec while the pump is still running to prevent air from being pulled back in when the pump stops. Then it can still take a few cranking cycles before it starts, but takes less time than just cranking it. I have seen over 10 cranking cycles before they would fire without any sort of bleeding. " |
07-08-2019, 07:53 PM | #59 |
Rep 1,799
You do not want to use this procedure on any high pressure system. The air is not enough lubrication for the pump internals when cranking.
You must use diagnostics to activate the lift pump for 3 minutes. It's really simple and it works.
07-09-2019, 08:03 AM | #61 |
Rep 123
Cracking the injector line was a common way to bleed the system back when diesels were equipped with a manually operated priming pump. I don't think you'll find a manual that recommends cracking the line when the fuel system is operating at normal pressures.
07-09-2019, 08:21 AM | #62 |
Rep 368
I could be wrong but I don't think the pump will keep priming if you cycle the key on and off with the newer diesels. The ISTA procedure is probably overkill, but if it's not primed in 3 minutes, it's not going to get primed lol. When I reinstalled my original pump it started right up after the priming procedure.
07-09-2019, 06:31 PM | #63 |
Rep 368
Got the intake pretty well cleaned up. Car started right up with the new pump head. Haven't driven it enough to say, but it seems a little smoother overall. Totally ruined my toothbrush though!
07-09-2019, 06:44 PM | #64 |
Rep 1,799
Good pics.
Now I am curious about your original pump internals, at your mileage.
07-13-2019, 02:12 PM | #66 |
Rep 18
My new pump is coming this next week and I'm going over the newtis instructions.
It does not mention anything about the front strut brace which you obviously need to remove. Are there any torque specs for it or just "tighten well"? Other than that, are the instructions missing anything else? Thanks for your help everyone! |
