12-21-2020, 10:02 PM | #1 |
Rep 49
Eibach Pro Kit for RWD vs XDRIVE
Hi all - currently have a 340i xdrive adaptive with Eibach kit (for xdrive).
Back sits nicely but front seems a bit too high. I have seen several on here put the RWD version Eibach springs on the XDRIVE to get a bit lower. Do you think it's possible for me to just swap the front springs? (both xdrive kit and rwd kit advertises 0.6 drop in the back) Possibly the E10-20-031-05-22 kit and E10-20-031-02-22 kit uses the same springs in the rear? |
12-22-2020, 12:09 AM | #2 |
Rep 481
did you follow instructions to cut the front bump stops for an inch or so, check the eibach kit instruction....
https://www.suspensionconnection.com...h-bmw-340.html Last edited by MEN54; 12-22-2020 at 12:37 AM.. |
12-22-2020, 08:04 AM | #3 | |
Rep 49
12-22-2020, 03:37 PM | #4 |
Rep 177
12-24-2020, 08:12 AM | #7 |
Rep 49
Posted this in another thread but will post here too.
Seems the problem is that I in fact have the 06/22 kit (common in North America) not the 05/22 kit (common in Europe) After doing a lot of research between the 05/22 and 06/22 Eibach kit, it appears the only difference is the front springs. E10-20-031-05-22 kit spring part numbers - Front - F11-20-030-03-VA Rear - F11-20-031-03-HA E10-20-031-06-22 kit spring part numbers - Front - F11-20-031-06-VA Rear - F11-20-031-03-HA So it seems the difference between these 2 kits is wether or not you want a slightly lower front, which matches the rear; or the slightly higher front (some reverse rake). I personally have the 06/22 kit and am wanting to swap the fronts to 05/22 as I don’t like the reverse rake. Ride quality is perfect for a daily driven car, and no issues with the Dinan bump stops. I’m just not satisfied with the reverse rake look. Last edited by spooned_n55; 12-24-2020 at 11:37 AM.. |
12-25-2020, 08:08 AM | #9 |
Rep 5,393
FYI- All Dinan is doing is reselling BMW bump stops made for other models and marking the price way up. It's a racket. That's why they won't allow returns. You could just read the part numbers off them and even order them from a BMW dealer. Dinan created a way for BMW dealer parts to be considered "inexpensive".
12-28-2020, 09:54 AM | #10 | |
Rep 481
12-28-2020, 07:33 PM | #11 |
Rep 98
spooned_n55 is right...I too didn't want the reverse rake and did the same research and ended up with the 05-22 spring kit, but used the F80 M3 bump stops. The ride quality is good for a daily driver...this is how the car should have come from factory.
The 05-22 front springs are lower than the 06-22...but not so low as scrapping the factory chin spoiler while parking or with curbs |
bigdnno98288.00 |
12-31-2020, 10:35 PM | #12 | |
Rep 49
01-03-2021, 07:04 PM | #14 | |
Rep 49
I think Eibach makes a great kit for a daily driven car. Very happy with my kit in every way - other than the reverse rake! Can't wait to install this one. |
01-06-2021, 12:05 PM | #16 |
Rep 10,256
01-18-2021, 08:19 PM | #17 | ||
Rep 1,067
01-18-2021, 10:15 PM | #18 |
Rep 98
Hey CntryClub007 ,
The only place I found was https://www.tunershop.com/ Springs feel tighter than factory...but not stiff at all. |
CntryClub007489.50 |
01-28-2021, 01:08 PM | #20 |
Rep 1,909
Does anyone have actual pictures of the 06-22 kit installed? is the gap in the front still that bad?
I ordered an 06-22 kit from tirerack a month or two ago and its just been sitting in my basement waiting for winter to be over. if the 05-22 kit fits and works fine, i might try to grab one and unload the kit i already purchased...
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
02-01-2021, 07:39 PM | #21 |
Rep 101
02-02-2021, 10:05 PM | #22 |
Rep 98
Hey uhdimzy
I purchased directly from my local BMW dealership's parts department. The arrived in two days. Fronts: 31-33-6-859-768...$40ish Rears: 31-33-7-847-662...$25ish |
