01-15-2021, 07:06 PM | #1 |
Rep 17
Timing Chain Noise?
Hello all,
Unfortunately, I believe I have begun to fear the worst. I have been hearing an extremely loud wailing/whining sound while accelerating in my car since last night and into today. Just started running BM3 Stage 2 with FBO supporting mods and turbo back straight pipe. Car is at 113k miles now and has had regular maintenance all around. I have included videos of the sounds I have been hearing: Is my timing chain on the way out the door, or is there some type of boost leak? I know having a straight pipe setup with an intake can really bring the turbo sound out, but I don't think that's the sound I'm hearing. It isn't related to the accessory belt, I've already replaced the tensioner assembly and belt and I still get this wailing sound. I only get the wail when throttle is being applied and have only observed the sound at lower RPMs. As of right now, the car drives extremely smoothly otherwise so I am very confused. Someone mentioned that it might be my PCV getting stuck, as I had a valve cover gasket leak that I had fixed but didn't change the cover itself. In my opinion, I don't think it sounds like this: Any input is appreciated. Thanks. Last edited by Three20i; 01-16-2021 at 08:53 AM.. |
01-16-2021, 08:55 AM | #3 |
Rep 17
Thanks for the reply man. With that being said, I don't get the notorious "whine" upon startup or when standing in the position in the video above.
I just edited my post to say that someone mentioned that it might be my PCV getting stuck, being that I fixed a valve cover gasket leak and not the valve cover itself. They also think the turbo could be going bad. |
01-17-2021, 12:46 AM | #4 |
Rep 943
Drives: F30 328i Msport
doesnt sound like TC to me
01-17-2021, 02:26 AM | #5 |
Rep 103
Anyone that has slack on their timing chain or hears the whine or loud timing chain, please go to www.nhtsa.gov and file a complaint.. timing chains failing at 50k to 80K miles is unacceptable especially from a pricey brand like bmw. There needs to be a recall.
01-17-2021, 08:49 AM | #7 |
Rep 103
Because we have guys like you saying there wont be a recall? Do you work for bmw or something? Timing chain failing at 100k or 110K miles when you have changed the oil every 5k miles and haven't abused the car is still unacceptable. If you can't support the cause and us as consumers don't comment at all.
01-17-2021, 11:05 AM | #8 |
Rep 16,054
I don't work for BMW. I did work for Ford. If there was basis for a recall it would have happened long ago. There are hundreds of components in any car that have a service life of 100k miles or less. The timing chain is one of them.
01-17-2021, 12:30 PM | #9 | |
Rep 298
01-18-2021, 06:59 AM | #10 |
Rep 17
I love this community so much. Thanks for the responses, guys. You've (mostly) quelled my main fear. Too bad I'm mainly a lurker, haha.
@zeikei, I had my intake out the other day for cleaning and so I went ahead and ran my hands all along the charge pipes, inlet pipe, etc just to confirm no leak while I was in there and found no such breach, thankfully. I'm having the car looked at today. I've started with ordering the PCV valve repair kit and will likely have that installed tomorrow. I will report back with the verdict. |
01-18-2021, 05:23 PM | #11 | |
Rep 17
01-19-2021, 09:45 AM | #12 | |
Rep 83
01-19-2021, 10:41 AM | #14 |
Rep 17
Yeah, unfortunately I don't have SULEV anyway.
I'm satisfied with having gone almost 120k miles on the stock snail. It was clearly time for a swap—found a lightly used turbo on Automotix for $235 shipped. |
01-19-2021, 12:38 PM | #15 |
Rep 65
I thought recalls were for safety issues (brakes, windshield wipers, cruise control, tail lights, frame cracking, bad wiring) not just because something breaks before it really should. I could be wrong. However, I do support the TC issues and forcing BMW to make it right since it is such a fatal failure for most of us.
2016 328i 6MT, M Sport Brakes, Suspension, Steering and Track Handling Package
MODS: BM3 Stage 2/93 Octane OTS, Active Autowerke BMW F Chassis Intercooler, VSRF Catless Down Pipe, GFB DV+, Injen Evolution Intake, Red Line MTL for Transmission, NGK SILZKBR8D8S gapped at .24", Dinan Shockware, Cooper ZEON RS3-G1's and Hawk HPS 5.0 Brake Pads all the way around. |
01-19-2021, 03:51 PM | #16 |
Rep 100
Drives: F30 328i BMW
No value to my post, but in your first video it sounds like R2D2
Thanks for sharing the remedy! |
