03-05-2019, 09:18 AM | #1 |
Rep 176
UPDATED!! Oil Leak(picture included) where's it coming from?
So i've been all over the forums looking at everyone's leaking engines thanks to innovative BMW engineering and it seems to me I have to replace the OFHG...
I was hoping it would be a cracked or de-threaded oil filter cap but I'm not completely sure if thats where the leak is coming from. I'm tired of looking at this greasy engine bay so I'm ready to replace whatever is causing the issue. I've attached a picture in hopes that someone would be able to identify the culprit. Also, if anyone has done this DIY I'd appreciate any tips... Last edited by F30NFifty5; 03-13-2019 at 10:14 PM.. |
03-05-2019, 09:44 AM | #2 |
Rep 470
That definitely looks like it's from the cap, I thought OFHG leaks happened lower than this.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
03-05-2019, 09:57 AM | #3 | |
Rep 176
https://www.ecstuning.com/b-ecs-part...003296ecs01~a/ |
AcExSpades74.00 |
03-05-2019, 10:01 AM | #4 | ||
Rep 761
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-05-2019, 10:09 AM | #5 | |
Rep 176
How hard is it to get the oil filter cap off without that special tool? anyone...? |
03-05-2019, 10:14 AM | #6 | ||
Rep 761
F30NFifty568.50 |
03-05-2019, 10:32 AM | #7 |
Rep 5,369
Who changes your oil?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-05-2019, 10:35 AM | #8 |
Rep 176
03-05-2019, 10:39 AM | #10 |
Rep 176
03-05-2019, 10:43 AM | #11 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
It is also possible the cap was overtightened. BMW is very specific about the caps torque value.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
03-05-2019, 11:04 AM | #12 |
Modder of everything I own
147
Rep 491
Mine had the same oil leak constantly. I replaced my cap with an aluminum one from ECS and that fixed my issue, no leaks since last summer.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
03-05-2019, 11:36 AM | #13 |
Rep 4,456
03-05-2019, 12:38 PM | #14 |
Rep 5,369
It's likely the cap and/or cap O-rings. It's very likely over torqued and/or possible as a crack in the cap body. Buy a new BMW OEM cap and OEM oil filter kit. Replace the cap, install a new oil filter, install the two new O-rings provided in the kit, and torque the cap to the proper torque, nothing more.
03-05-2019, 02:19 PM | #15 | |
Rep 176
I got the o ring and the ECS oil cap... as well as a new side mirror being that they took it off my car while i was at work. Courtesy of the south bronx i guess. Last edited by F30NFifty5; 03-05-2019 at 02:43 PM.. |
03-05-2019, 03:43 PM | #16 |
Rep 95
F30NFifty568.50 |
03-06-2019, 08:04 AM | #18 |
No 55mph
1619
Rep 8,476
Just a heads up - that nice black anodized ECS cap will soon turn purple from engine heat & look like a$$
Been there, done that on my E92
03-06-2019, 09:07 AM | #19 |
Rep 117
03-07-2019, 07:25 AM | #20 |
Rep 176
03-07-2019, 07:28 AM | #21 |
Rep 117
Haha it did look interesting! I did really like the additional 17mm hex on the top that made getting the cap off so much easier just using a ratchet so that's a plus!
03-13-2019, 09:50 PM | #22 |
Rep 176
Update!
So I finally got around to installing the oil cooler gasket as well as the ecs oil cap in hopes to fix my leaking engine. Install was pretty straight forward. It's a shame shops charge so much to do something so simple. The old gasket didn't seem brittle or damaged at all, which leads me to believe it might have been the oil cap. Took me longer to clean up all the oil than it did to actually take the housing apart.
After install i started up the car and everything looked good until I saw the car was leaking coolant. Turns out as I was tightening the 10mm bolt for the oil lines, i accidentally leaned on the upper radiator hose and snapped it. FML... Going to check BMW tomorrow to see if I can just pick it up, if not ill be ordering from here. https://www.pelicanparts.com/More_In...-8-570-061-BOE |
Rebound152.50 |
gasket, oil, oil filter housing gasket, oil leak |
