05-15-2020, 07:32 PM | #23 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
I honestly am still stuck at stun mode, around 23 PSI. Really want 25/26 for kill mode.
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
Techno 9000518.00 |
05-15-2020, 09:01 PM | #24 | |
Rep 585
In Kickdown#2 torque limiter 131072 activates at 4520 RPM and WGDC is still at 100%. Load Actual at 228 exceeds Load Target of 219 and at 4945 RPM (the next data point) boost overshoots target of 22.4 PSI, hitting 24.9 PSI, throttle closure and WGDC reducing from 100 to 75. I think the torque limiter activated because WGDC was still at 100% when load exceeded target. An interesting observation looking at your logs, it seems like the Dorch Stage 2 has an internal pressure relief valve that activates around 3500 PSI, similar to the stock HPFP, because between 5600 - 6100 RPM in Kickdown#1 the rail pressure hits and holds 3585 PSI. It's good to know it's got the same protection for your injectors as the stock HPFP. I don't think there's any evidence of gearbox/TCU intervention, looks to be all DME and xHP is doing it's job. There's a little bit of lag from the Pure800, about 1 second from the time you go 100% accelerator car changes from 4th to 2nd RPM goes to about 3000 in 2nd and boost only comes to the party after 4200 RPM. Wedge may be able to assist spool by retarding timing? MHD in their OTS maps have retarded timing, even negative, during spool up since V3 and improved stock spool by maybe 200 RPM.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
Supr3me551.00 |
05-15-2020, 09:06 PM | #25 | |
Rep 684
2020 X3M
les anderson145.50 |
06-22-2020, 06:43 AM | #26 |
Rep 56
Surprised this thread doesnt get more attention. Mapped my car to BM3 2+ and XHP st3 on basic settings, tried to launch twice and managed a 3.69 0-100 (3.54 0-60 mph). Not too bad, will be improved hopefully when i adjust the settings.
06-22-2020, 08:56 AM | #27 |
Rep 684
Honestly I'm still focused on the engine tuning side of things and making sure things are running strong and reliably on that front before spending a lot of time working on launches etc. Just received my dragy this week so I will probably start fiddling with it soon.
2020 X3M
540iSUP704.00 |
07-13-2020, 07:20 AM | #28 | |
Rep 18
I'm finding anything above 420Nm in 2nd gear will intermittently cause slip depending on the road surface. Setting it at 400Nm will almost always grip on 245 wide Michelin PS4 tyres for a LCI M135i on MHD Stage 2+ 98RON. 1st gear I've left alone since I'm running always launch from 2nd gear. 3rd gear always seems to hook up, even with ~600Nm+ at the clutch; the RWD preset for 720Nm is never reached anyway, so the limiting factor seems to be 2nd gear slip for me at least. Being on a prepped surface like Willowbank will probably let you use higher 2nd gear torque limits (Sticky Tyres preset?). Just trying to see what torque limit values you might've set for street use. |
OzBMR574.50 |
07-14-2020, 01:44 AM | #29 | |
Rep 585
Thanks for posting your results. When I get around to testing I'll post back here too. I agree that a prepped drag strip and Hoosier radials will allow a higher torque setting.
Dazz4C11.00 |
08-18-2020, 07:17 AM | #30 |
Rep 519
Bumping this again. Just flashed stage 3.
How's everyone liking their settings?
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
08-18-2020, 01:22 PM | #31 |
Rep 684
Honestly I'm struggling with launch. I've been to the dragstrip twice and done some back road launches and my times in auto with LC enabled are WAY slower than doing a manual brake boost launch and shifting manually. Like, mid 12's vs mid 11's on the quarter.
I have my LC moved up to +15% and like, +5% torque scaling after launch. Everything just seems softer in auto mode.
2020 X3M
09-29-2020, 07:25 AM | #32 | |
Rep 5
I will definitely try your settings out of curiosity but at the moment I am loving the manual shifts as well as driving in comfort mode.
JordanTuned E85 / Dorch Engineering Stage 2 HPFP / Rogue Performance Downpipe / Michelin Pilot Super Sport / XHP Transmission Flash Stage 3
OzBMR574.50 |
10-04-2020, 12:11 PM | #33 |
Rep 1,154
I seem to be losing my transmission on the 2-3 shift. After many launches with my xdrive w bm3 stage2+ and xHP. I've heard a siren noise coming from the tranny and it won't go into 3rd. I have many logs.
2016 340i xdrive
2009 335i |
10-09-2020, 01:42 PM | #34 | |
Rep 9
I've been holding back for fear of long term problems like this. |
10-10-2020, 05:17 PM | #35 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
Has anyone long termed / launched with xHP at +40% consistently?
I had a B48 and have been launching with +40% sliders and am a bit worried as there is a warning for stress on AWD. Curious if any B58s had noticed any stress in chassis or issues |
10-28-2020, 02:21 PM | #36 | |
Rep 919
Drives: F30 328d Sport Line
Anyway, are the 0-60 and 0-100 data points read from the xHP app or from Dragy or another app? TIA! |
04-16-2021, 02:15 AM | #38 | ||||
///Mflight Member
Rep 7
Drives: 2023 M340i Xdrive
Happened to me this evening...what do we need to adjust? |
10-15-2021, 07:23 PM | #40 |
Rep 99
10-17-2021, 07:46 PM | #41 |
Rep 2,358
Drag Mode - anyone? I tried it - pretty crazy and will definitely get the job done, but not very refined like the DCT torque punch (hoped it would be like that).
(A Dane in China) |
01-14-2022, 11:49 AM | #42 |
Rep 7
Anybody still read this thread? New(ish) to the platform. I could really use some advice/help with the XHP. I have it on stock settings and I’m not very happy with it. I feel like I hit 4th gear before even passing an intersection from a red light on medium acceleration.
Located in chandler,az. 2016 340I RWD MHD stage 2 |
10-11-2022, 01:08 AM | #43 |
Rep 97
https://datazap.me/u/bradvol/launch-...6-19-20&solo=3
Any idea why my boost would only be 2.1 psi before launch? xDrive 440 GC with MHD stage 2, high flow DP, intake, and xHP stage 3 with LC set to 15% for both settings. I get lag when I let go of the brake and then it kicks in after a delay. This was 4.14 0-60 and should be quicker I would think. |
10-11-2022, 11:28 AM | #44 | |
Rep 52
