BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for 6NR BMW Apps?
      10-12-2018, 08:12 AM   #89
albertosky86
albertosky86's Avatar
Italy
Drives: e92 LCI
Hello Shawnsheridan,
I'm a bit confused.
I own an '10 e92 LCI with combox. I see ConnecteDrive menu in my CIC, but actually can't see any app and bmw online doesn't work.
I would like to have bmw apps, and whatever I can..
Could you please help me explaining what needed?
Many thanks
      10-12-2018, 08:14 AM   #90
shawnsheridan
shawnsheridan's Avatar
I'm a bit confused.
Many thanks
You need a 9C FSC Enabling Code and car coded for 6NR BMW Apps.
      10-12-2018, 08:26 AM   #91
albertosky86
Italy
Drives: e92 LCI
Does 6NR BMW Apps coding mean FRM coding? I discovered I have a faulty FRM which may brick during flash.
I don't know where/how to get 9c FSC code...
      10-12-2018, 10:57 AM   #92
shawnsheridan
No. You would code Head Unit and Combox. PM sent.
      11-11-2018, 10:28 PM   #93
schweeded
Drives: X5 F15 xDrive30D
Hi Guy, I am really new to this coding thing. I am about to purchase the FSC code for the maps. is it the same code for the BMW App activation?
      11-11-2018, 10:32 PM   #94
shawnsheridan
No. Totally different and far more expensive. I replied to your same PM.
      12-04-2018, 02:15 AM   #95
Alxscott
Drives: BMW 135M
I joined to ask the same question!
I generated a ‘Lifetime’ FSC code following a DIY a couple years ago... can the same software be used to generate the FSC code required? Also I scanne through this post and count see where to enter the FSC code in E-Sys?
I would have PM’d but I don’t have the privileges!
Thanks in advance
Alex
      12-04-2018, 07:29 AM   #96
shawnsheridan
Thanks in advance
Alex
You cannot generate a 9C FSC Code like you can a Map FSC Code. They are totally different. PM sent.
      01-01-2019, 02:42 PM   #97
Andrei525
Drives: BMW 525d
Hi shawnsheridan
I have read the way to do it but just to be sure as I am beginner with BMW and coding is on a F10 with navi pro 609 and combox with BT is possible to ad 6NR?
My car was made in October 2010.
      01-01-2019, 02:51 PM   #98
shawnsheridan
Originally Posted by Andrei525 View Post
Hi shawnsheridan
Yes, after you add 9C FSC Code it is possible.
      01-02-2019, 01:08 AM   #99
Andrei525
Drives: BMW 525d
Many thanks for guidance.
As I try to get the best from it would be possible to have Connected Drive services with another FSC code?
      01-02-2019, 06:40 AM   #100
shawnsheridan
You can add 9C. PM sent.
      01-30-2019, 05:00 AM   #101
rogankushaf
Drives: 118i f20
hi all, i have a f20 118i 2015 with hu_entrynav, and i'm trying to code bmw apps, i suppose i need a fsc code but i didn't understand where to get it and then what i need to code exactly, can someone of you help me pls?
thanks a lot
      01-30-2019, 06:33 AM   #102
shawnsheridan
thanks a lot
PM sent.
      03-01-2019, 08:03 PM   #103
satianv
Drives: X5, E70 and 323 E90
CIC keeps rebooting
I have a CIC.16 and one of those lucky ones that don't need the FSC for apps activation I believe.
I have FA_WRITE the FA/VO with $6NR and then SG_Codieren to CIC and Media.
The CIC Head Unit now shows BMW Connected Drive with Apps Sub Menu. When I connect the phone using the USB in armrest and start the "BMW Connected" App on the phone, I see "BMW Apps Loaded" on the CIC.
And then it reboots, it does this every time without fail. Tried two different genuine Apple USB cables with same results.
Any ideas?. ALso checking the SG_Codieren Job on the CIC and media doesnt need to have any MAN or TRC files correct?
      03-01-2019, 08:25 PM   #104
shawnsheridan
Is CIC.16 v.41.0 firmware?
      03-01-2019, 08:28 PM   #105
satianv
Sorry if this is a silly question, how do i validate the firmware version. Using the NCS expert process ECU?
      03-01-2019, 08:30 PM   #106
shawnsheridan
No idea. I don't do any E-Series work myself.
      03-02-2019, 12:00 AM   #107
satianv
CIC keeps rebooting
Hi Shawn,
I have tried all the tools I have got, except ISTA, cant seem to see beyond the CIC.16.
Anyway the question is, assuming I have the correct version what could I be possibly doing wrong to have the system reboot like that? I am not sure if the Coding I am doing is correct, especially when some folks are saying I need to code with an empty MAN file.
Also how do I validate what version of Daten file I have ? (If you know )
How is it done in the F series anyway?
Thanks again.
      03-02-2019, 02:51 AM   #108
shawnsheridan
Hi Shawn,
Thanks again.
I have no idea why its rebooting.
E-Series or F-Series, it is just VO Coding CIC and CMB_MEDIA Modules for 6NR. Car needs v.41 firmware, of newer firmware combined with a 9C FSC Code. And make sure 6VB is not in FA.
      03-17-2019, 12:08 PM   #109
Elmo111
Drives: BMW 118d Urban
Hi all,
Can somebody confirm to me if either of these 2 VIN numbers support BMW Apps? They both have ConnectedDrive in the menu.
P709274 production date 06.15
VZ29629 production date 07.14
Thanks!
      03-17-2019, 02:26 PM   #110
shawnsheridan
Originally Posted by EmilioB View Post
Hi all,
Thanks!
P709274 production date 06.15 - Not Possible
VZ29629 production date 07.14 - Possible
