02-13-2020, 04:07 AM | #1 |
Rep 56
New speakers, now leakage :(
Changed my doorspeakers recently from Base to aftermarket Focal speakers.
Used spacers for extra clearance and added rubber isolation, but still waters/moist comes through. What do you advice for extra isolation? |
02-13-2020, 04:31 PM | #2 |
No 55mph
1622
Rep 8,476
If the water you speak of is definitely coming from between the door & spacers - put some sort of gasket between the spacer and door
Like foam tape with adhesive one side, or strip caulk BTW, if you have the base or HiFi audio system - throwing only hi end speakers at it won't make the sound much better...
02-14-2020, 05:39 AM | #3 |
Rep 56
Thanks! I already added a rubber tape between the door and spacer...but no foam tape or something between the spacer and speaker.
Will do that this weekend. I keep wondering why it's even possible that the backside of the speaker can get wet |
02-14-2020, 06:49 AM | #4 |
No 55mph
1622
Rep 8,476
Only way is if your door window felts along top edge of door are leaking
Manufacturers usually prepare for this to happen - that's why there are little holes along the bottom of your door to allow any water that gets in to drain
02-14-2020, 07:10 AM | #5 |
Rep 16,122
Water seeps past the window seals into the door. It's normal. That's why the door is sealed to prevent water from going into the door liner, and why there are drainage holes in the bottom of the door.
