09-06-2018, 12:36 PM | #1 |
Rep 777
Bimmercode coding help needed
Can anyone tell me where in the app I can find the code to change the resolution size for the on screen display,having seen all the posts I am going to change my info screen from 6.5 to 8.5 but I cant find the screen size change in Bimmercode I can see where it says Breites display but where do I change the settings
09-06-2018, 12:54 PM | #2 |
Rep 3,860
Best thread title ever!
I am sure it will be extremely helpful for the next one with your question to find it!
09-06-2018, 01:12 PM | #4 |
Rep 3,860
The issue "BimmerCode" as per title?
09-06-2018, 01:31 PM | #6 |
Rep 4,935
Drives: 340i MPPSK
You can edit the thread title if you want, just go to your first post and click the Edit button, then click Go Advanced and above the message body you'll see a box where you can edit the title.
(Entirely up to you - I'm not taking sides)
Life is a state of mind |
09-06-2018, 01:51 PM | #7 |
Rep 32,881
You will need to go into expert mode and code these two things:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display |
09-06-2018, 02:31 PM | #8 | |
Rep 777
I went into expert mode and found the Breites display but couldn't find the display size resolution many thanks to you I have found display size it is already set to 8.8 1280x480 Cheers. |
09-06-2018, 02:36 PM | #9 |
Rep 777
09-06-2018, 02:45 PM | #10 |
Rep 32,881
02-19-2020, 10:52 AM | #11 |
Rep 2
Hi, I have the same issue, in bimmercode I don't find the "display size resolution". In demo mode it apears, but when I connect to the car It doesn't show, can you please help me?
08-02-2022, 04:29 AM | #12 | |
Rep 3
I'm in same case. I didn't find how to change resolution. My car is BMW F10 535i Xdrive built by BMW on Spt 2012. I'm just on the limite of change from CIC to NBT. I have the CIC car radio system but the screen has a NBT connector (6 pins). Thanks |
08-13-2023, 12:26 PM | #13 |
Rep 2
I have a 2014 BMW X3 under 3000 HMI there is no display size resolution option available. I do see the breites_display under the 3001 options. Any ideas on why I'm not seeing Display size resolution as an option?
