12-23-2017, 01:49 AM | #1 |
Rep 118
NBT2 VO coding locked
Hi all,
Someone knows how to resolve the VO coding locked HU_NBT2 ? I deleted all FSC, then flashed successfully the HU to ID5, but the last step for CAFD deploy fails. I injected 170 FSC that was accepted. Then tried to VO code the HU without success. I can FDL the HU without problem, but VO coding is blocked. The HU is not in component protection (No error about that in FS_Lesen) I do coding in the bench with CAN Bridge and ZGW2. The HU was flashed with its factory VO & VIN. 170 FSC is also accepted with the factory VIN, and the ZGW is flashed with the same VIN and implements factory FA of the HU. Attached some pictures- |
12-24-2017, 12:45 AM | #2 |
Rep 1,975
Drives: 2020 G20 320i M Sport
What's on the label of this HU_NBT2? Does the serial number start with a B211 or B143?
You can't flash a B143 sample to to ID5. It will not work with VO coding otherwise. You can FDL code all the parameters but it will be tedious.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
Nickco431456.00 |
12-24-2017, 06:25 AM | #3 | |
Rep 118
Now, even if we try to FDL parameters, very hard (was impossible for me) to making work the CID (No Signal). |
12-27-2017, 04:05 PM | #4 |
Rep 1,975
There's likely something in your FA that doesn't agree with the HU. If it's a B240, it's likely from a G chassis vehicle and you'll have to use an FA of that type to flash it.
12-17-2018, 05:18 AM | #6 | |
Rep 1,975
I'm guessing this is a European unit that you have?
01-03-2019, 07:02 AM | #7 |
Rep 16
i had a problem with NBT EVO in flashing, it stayed 14 days in progress, has anyone had this problem before.
i tried again after this with a different system (Esys & Icom) but a fault in ethernet connection appeared. Can anyone has an experience in this clarify this problem & what should i do ? IS there any data or user manual for TAL Execution ? @steve@codemybimmer Last edited by tonyhhandler; 01-08-2019 at 09:14 AM.. |
01-05-2019, 11:24 AM | #8 |
Rep 1
Install/flash ID6 on NBT EVO
hello my friends,
i contact you for know how could i have the files ECU HU-H NBTEVO, MEDIA, ... for could reinstall ID6 system for NBT EVO with E-SYS. My car is BMW 3 series f30 320d with HUD. How could i do it ? Thanks the friends |
01-08-2019, 11:04 AM | #9 | |
Rep 1,975
01-11-2019, 04:15 AM | #10 | |
Rep 244
do i need oabr connection to vo coding it ? |
01-11-2019, 05:38 AM | #11 | |
Rep 16
I was flashing the unit in the car using an icom, what do you mean with OABR wired correctly ? or how should i do it. The OABR Ethernet is available inside the vehicle between the Gateway and the HU, What should i do ? Thanks in advance |
01-11-2019, 12:28 PM | #12 | ||
Rep 765
01-12-2019, 02:47 AM | #13 | |
Rep 16
I've got what you mean but it's not a retrofit, it's an original stock nbt evo in 2018 f30 |
01-12-2019, 10:07 AM | #14 | ||
Rep 765
