12-11-2018, 01:56 PM | #45 | ||
Rep 1,827
12-11-2018, 02:15 PM | #46 | |||
Rep 5,984
12-11-2018, 02:16 PM | #47 | |
Rep 406
I'm asking how stiff the suspension is in an F30 in Sport Mode with Adaptive Suspension as compared to non-adaptive suspension F30 with the M-Sport package. I have adaptive suspension and I feel likes it's stiffer in sport mode than non-adaptive M-Sport suspension.
Specs: '16 340i|6sp MT|Silver Metallic|Black Leather with Oyster Highlights|Aluminum Hexagon Trim. Options: M-Sport|Cold Weather|Technology|Track Handling|Power Rear Sunshade|Driving Assistance |Driving Assistance Plus|Lighting|Harman Kardon|Surround View Pics of my car |
12-11-2018, 02:19 PM | #48 | ||
Rep 1,827
12-11-2018, 02:26 PM | #49 | |
Rep 216
12-11-2018, 02:29 PM | #50 |
Rep 9
12-11-2018, 02:44 PM | #51 |
Rep 406
Exactly. This is my question. What mode in an F30 M-Sport with Adaptive Suspension is most close to the suspension you get in an F30 M-Sport without Adaptive Suspension.
12-11-2018, 02:48 PM | #52 | |
Rep 5,984
12-11-2018, 03:08 PM | #53 |
Rep 3,859
Stiffness order:
Adaptive Suspension - Comfort M-sport (non-Adaptive) Adaptive Suspension - Sport / Sport+
Hammer Werke101.50 |
12-11-2018, 03:40 PM | #54 |
Rep 406
This seems about right. I do think that adaptive suspension sport mode is stiffer than non-adaptive M-Sport suspension.
12-11-2018, 04:27 PM | #55 |
Rep 337
The msport springs are the same with or without adaptive damping. The damping makes all the difference though.
So on a normal drive the adaptive is softer as although it rides on the same springs, it softens the damping and let's the car float a little. The moment you build any sort of dynamic forces, it will tighten up the damping. I have real life experience of this, my old adaptive f31 was softer on the daily drive and more taught in the bends than my standard f36! Both m sport. Hope that helps. |
12-11-2018, 09:25 PM | #56 |
Rep 63
It makes the car sound alot bettter at the cost of a few mpg's.
Last edited by cefiro8701; 12-11-2018 at 09:29 PM.. Reason: not enough coffee today. |
12-12-2018, 06:59 AM | #57 |
Rep 3,859
What do you mean by "sound a lot better"? Better than what (Sport?) and in what way?
12-12-2018, 11:19 AM | #58 |
Rep 15,858
As there is a compromise around spring rate with adaptive damping, it is logical that Comfort will be softer, Sport will be firmer, than a passive damper tuned to the M-sport spring rate. (Sport + is not relevant to the damping rate).
12-12-2018, 12:01 PM | #59 | |
Rep 337
Spring rate is always a compromise, but adaptive damping can do a lot to stop the car feeling too firm or soft at the wrong time. |
12-12-2018, 02:07 PM | #60 |
Rep 1,062
My '17 340i xDrive with MPPSK -
Sport+ in D and S modes does hold the gears longer and downshifts more aggressively than Sport. Because of this, there are more pops and crackles from the exhaust. But in M mode, manually shifting, Sport and Sport+ are basically the same - the only difference being DSCOff for Sport+. The suspension, steering and throttle mapping are identical. The engine noises are identical. As far as I can tell... |
12-12-2018, 02:15 PM | #61 | |
Rep 5,984
12-12-2018, 02:23 PM | #62 | |
Rep 1,062
I got a couple tickets this summer, so I've toned down my ... spirited driving a bit. Less Sport+ mode for me. xDrive is OK. It does raise the car some, which doesn't look great. And it takes some getting used to being able to hammer the throttle mid-corner and just power out of the turn. I generally put All Seasons on in the winter rather than Winters. I think tires like Michelin Pilot Sport A/S 3+ have better cold dry/wet traction than winters, just less traction on actual snow & ice, which I rarely drive on. Plus I go on road trips in the winter that take me south into temps well into the 50s and 60s. If I could wave a magic wand and go back to RWD I would. |
12-12-2018, 02:26 PM | #63 | ||
Rep 5,984
12-12-2018, 02:32 PM | #64 | |
Rep 1,062
In a lot of cases, I have more usable power off the line than an M3 or M2. |
12-12-2018, 02:39 PM | #65 | ||
Rep 5,984
12-12-2018, 02:57 PM | #66 |
Not stock
472
Rep 617
Right but what I mean was that turning off chassis mode for sport only affected "Sport", not "Sport+"
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
