06-01-2022, 05:38 PM | #287 |
Rep 732
06-12-2022, 07:57 PM | #288 |
Rep 4,877
Finally got a situation where I could bang through all the gears in sport+. Wow... HUGE difference on sport+ vs sport on the Stage 2 tune. Shifts are insanely crisp.
06-13-2022, 05:27 PM | #289 |
Rep 558
I am also on stage 2, but haven't had a chance to try that. Street :-|
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
06-13-2022, 05:58 PM | #290 |
Rep 4,877
06-13-2022, 07:00 PM | #291 |
Rep 558
I need to find a long, empty entrance ramp... without
Wires1645.50 |
06-28-2022, 07:14 PM | #292 |
Rep 103
Hi guys, I have a stock 440i, just did the stage 2 Xhp flash. What I didn't see is the 50 mile recommendation. I went with through 3rd a few times the first day. car fel great at first, by the end of the day 3rd/4th gear just feels flat, like it's down 50hp or so. I have since driven 200 miles driving normally with the occasional pulls from 1st to 4th. same deal.
Did I screw up the trans learning? Should I flash back to stock for 100mi and just start over? sorry for the newb question, I haven't seen anyone ask something similar. Erik |
06-30-2022, 11:11 AM | #293 |
Rep 2,067
Do you have gear display option set, and do you have the digital cluster?
If so then in S/M mode where xHP shows gear display is shown (because gear display option is for all D/S/M modes), that information is "redundant", isn't it to the gear information already shown by the car? If redundant, then "would have been" nice to just have gear # information displayed only in D-mode. |
ocdx30.00 |
07-04-2022, 09:12 AM | #294 |
Rep 1,457
Currently running the Stage 2. For example when I'm cruising at 70 mph and hit the pedal to the metal with the shift lever set to S mode, is it normal for it to down shift to 4th gear for a couple seconds then down shift to 3rd gear? I can't recall the stock flash doing this. I'm wondering if i set the stock shift points through XHP it will fix this.
07-04-2022, 10:05 AM | #295 | |
Rep 329
07-07-2022, 04:02 PM | #296 |
Rep 558
Recently, after carefully reading the OTS map details, I switched from stg3 to stg2 because there are some features in stg3 that I didn't want/need.
However, I found the stg2 OTS shift maps for D and S to be too close together. There didn't seem to be enough difference between them. So, I decided to try the "Relaxed" and "Sportive" OTS shift maps. I found those to be too far apart and the "Sportive" was too aggressive for my tastes. So, then I decided to try the shift map editor feature. My goal was to make the stg2 Drive map a little more relaxed and the Sport map a little more aggressive. I used the settings below and am happy with the results. Now, there is a noticeable difference between D and S, but it's not "too much". I thought I'd share my settings in case someone else feels the same about the stg2 OTS shift maps and might want to try my settings. Enjoy!
07-09-2022, 11:58 PM | #297 |
Rep 329
installed xhp on friday and let it adapt over 100 miles ..
first impression it feels really good since my car is on mhd stg 2 so it feels like there is no bottle neck when i wanna have some fun .. but holy in just reg drive mode the shift points are extreme .. ill be doing 38 and its in 7th .. like bruh i get it maybe in eco .. but man who the hell coded the reg drive to be so shift happy .. anyway to fix this ? the stock reg drive mode was pretty good i also feel a jolt maybe from the trans at first it was very noticeable , now its kind of subtle , not sure what it is Edit: jolt went away .. think the trans learned the new flash completely and jolt is gone Last edited by nosam1g; 07-24-2022 at 12:55 AM.. |
mountaineer106.50 |
07-10-2022, 08:05 AM | #298 | |
Rep 558
RTFM ;-) https://rbttuning.atlassian.net/wiki...Custom+Options
07-15-2022, 07:45 PM | #299 |
Rep 23
I just flashed my F32 with xHP last night. I just finished doing the drive-in period today so tomorrow I plan on running it harder with Sport+ to see how it feels. I'll report back, but even under moderate driving and some quick take offs here and there, its def much snappier, even in comfort.
07-15-2022, 08:32 PM | #300 | |
Rep 1,457
07-16-2022, 11:43 AM | #302 | |
Rep 23
I feel like the car should downshift a little bit easier even in comfort. Do these settings feel a little smoother and easy on the powertrain when just doing normal daily driving? |
mountaineer106.50 |
07-18-2022, 09:51 AM | #303 | |
Rep 558
07-18-2022, 09:57 AM | #304 | |
Rep 558
However, it's important to note that the "stock" shift maps may not be exactly what your car came with from the factory because xHP does not keep a backup of your original settings. It uses the current factory settings that xHP has for your trans code.
mountaineer106.50 |
07-18-2022, 01:46 PM | #305 | |
Rep 23
Ill have to give this a shot this weekend when Im free from work and have time to mess with it. Other than that everything has been fun and fast. |
07-18-2022, 02:12 PM | #306 | |
Novice
303
Rep 695
mountaineer106.50 |
07-19-2022, 07:12 PM | #307 | |
Rep 329
07-19-2022, 09:17 PM | #308 |
Novice
303
Rep 695
enable the stock shift points. It won't completely fix the problem but it works. Most of the time it shifts between 1.5K-2K RPMs and only goes in 7th/8th when on the highway or if I'm cruising with very light throttle w/ 40mph max speed limit.
