09-21-2016, 10:16 PM | #134 |
Rep 346
I am not aware of any other solution if you purchased the wrong rear rotors. I am not sure if there is a 330mm rear rotors with smaller inner drum dia that can fit as over here, it is very limited.
I guess if you do handbrake turns etc, there maybe an issue?. For me, the handbrake is not used at all except parking on an incline so i had no issue after using for 20k km. Anyway, I am just sharing what my workshop did to overcome the wrong rear rotors. |
10-02-2016, 02:04 AM | #135 |
Rep 1,170
if you have a m sport brake un painted
Can you fit a larger rotor Yes.? Or No.!? I'm guessing I have a 340 right now since my rotor was unpainted I have a 335i
bmw m2
10-02-2016, 02:49 AM | #136 |
Rep 266
Typically an m sport could not be unpainted.
Always is blue monte carlo. However a std version brake of x35i is coming with unpainted brembo 4pot rotors fronts that only can be equiped with 340mm diameter rotors . So answer is NO ! For 370mm rotors (or 380mm on f8x series) brembos are coming with different version/dimensions . Hope this helps |
10-29-2016, 04:20 AM | #138 |
Rep 4,516
10-29-2016, 04:25 AM | #139 |
Rep 266
11-17-2016, 05:41 PM | #140 | |
Rep 1,986
11-18-2016, 03:17 AM | #141 |
Rep 603
Thanks for the information.
Could you try again please with the new link below. https://1drv.ms/x/s!AqdJMMUQxA-nhZs6_JWYyQG6amQ0jA
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
Kabrich354.00 |
12-31-2016, 10:47 AM | #142 |
Rep 164
I have a 2013 335xi M sport, but do not have the blue M sport brakes. Would like to get the BMW decal to put on my silver calipers. Where is the best place to get the decals. Checked out eBay, but not sure if they are the same as OEM. Thanks.
01-01-2017, 10:27 AM | #143 |
Rep 3,470
That would have to be a hell of a decal, brakes are typically painted with high temperature (resistant) paint and are one of the more abusive places on a car due to all the dust, grime, heat, etc.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
oceanview207.00 Versipellis130.50 |
03-17-2017, 07:24 PM | #144 |
Rep 48
I have a question that I can't seem to find the answer for. I have 2015 328i M Sport with the staggered wheels. (No upgraded brakes).
Can I run 17" wheels for winter? Tire Rack's tool says I need 18" wheels minimum. |
03-19-2017, 10:05 AM | #145 | |
Rep 603
If your car does not have the 18" M Performance Brakes or the "BIG version" Sport Brake upgrade with blue calipers (also with 370mm rotor), you will be fine with 17" wheels.
Spiderm0n38.50 |
04-08-2017, 10:29 PM | #146 |
Rep 87
So I have a question, I recently bought the Msport brake kit and the front was ear but I'm having a problem with the rears. Im trying to replace the rear brake dust shields. Seems like the rear hubs and drum brake assembly needs to be come off completely in order for me to replace the oem dust shield to the bigger dust shield that goes with the big rotors / brake kit. Is there any other way to get the dust shield replaced ?
04-09-2017, 09:34 PM | #147 | ||
Rep 259
Drives: 16' AW 340i xDrive
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
04-10-2017, 10:27 PM | #148 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
If you replace your dust shields, you will just be putting on the same size again. And yes the hubs must be pressed off. Not an easy DIY job.
FBO-PS1 and stuff
05-28-2017, 04:22 AM | #150 |
Rep 603
kemiksiz I think you need to get the whole set like StopTech for example.
https://www.turnermotorsport.com/BMW...big-brake-kits I only looked in my listing what the BMW offers are. For other possible combination there are forum members that know much better than I do. Sorry can't help.
05-28-2017, 11:13 AM | #151 |
Dejan
1753
Rep 4,197
Is what possible?
FBO-PS1 and stuff
05-28-2017, 11:53 AM | #152 |
Rep 598
Ceramic 6 Pots Calipers with 370mm M Performance Discs?
The topic of the message Using these calipers with M Performance 370mm discs on F30 http://cdn3.volusion.com/ofeb6.fdp3x...jpg?1484327020 |
05-28-2017, 11:54 AM | #153 | |
Rep 598
05-28-2017, 02:03 PM | #154 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
