07-09-2018, 02:54 PM | #1 |
Rep 603
Automatic Transmission Oil Leak
Gents
While installing DV+, FMIC and Charge Pipe a few days ago, I recognized that some oil is leaking in the torque converter housing. I'm pretty sure it is transmission oil not engine oil (by the smell and because I did not have to refill engine oil since the last oil change a few thousend miles ago). It was quite juicy around the rubber cap under the housing. It looks to me, like it could be a problem with the front o-rings of the transmission (V or Y on this pic). https://www.realoem.com/bmw/enUS/sho...diagId=24_1143 Is there any way to check the transmission oil level by board computer or physically? I assume on the above link screw plug "3" could be the refill and oil level plug? Am I right? Car has 55'000 Kilometer / 34'000 miles on. Is this a known problem? Just would like to know better before heading to the dealer. Thanks
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
07-10-2018, 05:16 AM | #3 | |
Rep 3,949
07-10-2018, 07:00 AM | #4 |
Rep 5,457
Drives: F30
I had a similar issue and it ended up being the transmission cooler lines leaking at the fittings. Fixed under warranty.
