04-09-2018, 08:59 AM | #1 |
Rep 1,862
Drives: powered by bootmod3
bootmod3 New Feature Release - DME Read (Backup) ***
Hey guys just wanted to let you know about a new feature released over the weekend. We've finalized work updating our DME Read feature available on the Diagnostics screen. Its a neat way to back up (read out) the DME and make the contents into a re-flashable map in the list of your maps, making it behave just like any BM3 OTS map or custom map.
Who needs this? If you invested in a flash tune before, a custom tune or OTS, and you'd like to to go with bootmod3 to use its features you'll be able to back up the current tune as a map and be able to flash back to it at a later point if you choose to do so. Our User Adjustables screen that's in the works will also apply to these maps just like any other map in the account, more on that here: http://f80.bimmerpost.com/forums/sho....php?t=1480183 Previous tune data that is backed up will not be editable or viewable and is simply a backup of your previous tune. Cheers |
04-10-2018, 01:48 AM | #2 |
Rep 67
Drives: 2015 Black sapphire metallic
Hey Guys,
I have the BM3 with the N26 and a downpipe. Do you guys recommend that I change my map to the new OTS? My car is running great and I don't have a FMIC.
VRSF downpipe ST coilovers 435 MPE exhaust Bootmod3 stg2, ER comp series FMIC, ER charge pipe, ER turbo to inter cooler charge pipe, GFB dv+, NGK LI plugs K&N air filter
04-10-2018, 08:43 AM | #3 |
Rep 2,382
I would update to the latest map. That being said, are you on stage 1 or stage 2? It's recommended you have both an FMIC and DP, but the key part is the DP. You can run stage 2 without the upgraded FMIC, but don't expect it to keep up with boost at some points.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-12-2018, 07:36 PM | #4 |
Rep 67
I have a VRSF downpipe and I'm running a stage 2 map. Looks like my next upgrade will be the FMIC.
04-12-2018, 09:48 PM | #5 |
Rep 67
Just updated to new map, the burble is pretty aggressive when downshifting in manual.
bm3, bootmod3 |
