05-06-2019, 10:11 PM | #1 |
Rep 30
F36 440i GC XDrive 19" and 20"
Will this combo work without rubbing on stock M Sport suspension?
Front: 8.5x19 ET35 235/40R19 Rear: 9.5x19 ET35 275/35R19 Could I run 20's by decreasing the aspect ratio by 5 on both front and rear? Last edited by Superlative; 05-06-2019 at 10:24 PM.. |
05-06-2019, 10:44 PM | #2 | |
Rep 30
Looks like the last option is best: 0% ratio for Xdrive and fill wheel gap. I don't plan to lower as the car is a lease. Now, if I go from OEM 19 to this 20 setup, the aspect ratios go from 3.5" down to 3.2". Am I going to "feel" a big change with that 0.3" delta? Will pot holes destroy me more? Last edited by Superlative; 05-07-2019 at 06:21 AM.. |
05-07-2019, 05:55 AM | #3 | |
Rep 30
05-07-2019, 08:42 AM | #4 |
A family of bimmers
2745
Rep 7,741
id do 235/265 combo with et35 front and rear for your GC. could theoretically get away with an et30 up front if you wanted very flush.
yes mine is an f30 and i didnt plan to lower so i went et45 out back. i could have fit et35-40 without issue but at stock height it would look like its poking. Since the F36 gives more room out back like the F32 you can do et35
05-07-2019, 12:53 PM | #5 | |
Rep 30
05-07-2019, 01:30 PM | #6 | ||
Rep 216
05-07-2019, 01:35 PM | #7 | |
Rep 30
BTW, "you're are?" Last edited by Superlative; 05-02-2020 at 02:13 PM.. |
05-07-2019, 01:47 PM | #8 | ||
Rep 216
05-07-2019, 02:27 PM | #9 |
A family of bimmers
2745
Rep 7,741
not square... 265 cannot fit a 8.5
i was referring to et35 if you were going 8.5 f and 9.5 rear.
05-07-2019, 04:16 PM | #10 |
Rep 30
